dnsmasq problem after upgrading wheezy to jessie
Posted: Wed Jun 07, 2017 11:19 am
I have upgraded my rPi2 from wheezy to jessie... it boots and seems OK, except dnsmasq fails after boot with:
I can start dnsmasq with sudo dnsmasq and it works.
Any ideas on where to look?
sudo service dnsmasq status
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: failed (Result: timeout) since Wed 2017-06-07 19:55:39 AEST; 24min ago
Process: 1526 ExecStop=/etc/init.d/dnsmasq systemd-stop-resolvconf (code=killed, signal=TERM)
Process: 626 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS)
Process: 558 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
Main PID: 634 (code=exited, status=0/SUCCESS)
Jun 07 19:52:22 rpiserver dnsmasq[558]: dnsmasq: syntax check OK.
Jun 07 19:52:22 rpiserver dnsmasq[634]: started, version 2.72 cachesize 150
Jun 07 19:52:22 rpiserver dnsmasq[634]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP con...detect
Jun 07 19:52:22 rpiserver dnsmasq[634]: using nameserver 180.181.127.4#53
Jun 07 19:52:22 rpiserver dnsmasq[634]: using nameserver 180.181.127.3#53
Jun 07 19:52:22 rpiserver dnsmasq[634]: using local addresses only for domain localnet.grenkowitz.net
Jun 07 19:52:22 rpiserver dnsmasq[634]: no servers found in /var/run/dnsmasq/resolv.conf, will retry
Jun 07 19:52:22 rpiserver dnsmasq[634]: read /etc/hosts - 7 addresses
Jun 07 19:54:09 rpiserver systemd[1]: dnsmasq.service start-post operation timed out. Stopping.
Jun 07 19:55:39 rpiserver systemd[1]: dnsmasq.service stopping timed out. Terminating.
Jun 07 19:55:39 rpiserver systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Jun 07 19:55:39 rpiserver systemd[1]: Unit dnsmasq.service entered failed state.
