JackElliott
Am i working with a corrupted image here?
Tue Jun 06, 2017 8:07 pm
A bit of a panic now. Help!
I have a Raspberry Pi 3 that I've set up to be used an Icecast stream source to send the audio from an upcoming music festival to our community radio station for rebroadcast.
It was working perfectly, but I managed to corrupt the SD card (long story, irrelevant to what I'm dealing with now).
Fortunately I had a backup/clone SD card and it worked. I used dd (in Linux) to make an image of that card to my computer hard drive, and cloned a new SD card from it. It worked, too. Just to play it safe (or to show how dimwitted I can be), I copied back the image from the working SD card and overwrote the previous image on my hard drive.
But now that working card, and all the cards I make from that image, don't boot. I get a little blinky green light on the Pi's PCB. If I put the cards into my linux computer, it only mounts boot. I get these errors:
undefinedUnable to mount root: Error mounting /dev/sdb7 at /media/jack/root: Command-line `mount -t "ext4" -o "uhelper=udisks2,nodev,nosuid" "/dev/sdb7" "/media/jack/root"' exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock on /dev/sdb7,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or soundefined
Unable to mount 1.3 GB Volume: Error mounting /dev/sdb1 at /media/jack/6436-3031: Command-line `mount -t "vfat" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,shortname=mixed,dmask=0077,utf8=1,showexec,flush" "/dev/sdb1" "/media/jack/6436-3031"' exited with non-zero exit status 32: mount: /dev/sdb1: can't read superblock
Unable to mount SETTINGS: Error mounting /dev/sdb5 at /media/jack/SETTINGS: Command-line `mount -t "ext4" -o "uhelper=udisks2,nodev,nosuid" "/dev/sdb5" "/media/jack/SETTINGS"' exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock on /dev/sdb5,
       dmesg | tail  or so
dmesg | tail reports:
[18649.104968] sd 20:0:0:0: [sdb] Attached SCSI removable disk
[18650.149816] EXT4-fs (sdb5): ext4_check_descriptors: Block bitmap for group 0 not in group (block 6321408)!
[18650.149829] EXT4-fs (sdb5): group descriptors corrupted!
[18650.415073] FAT-fs (sdb1): error, fat_get_cluster: invalid cluster chain (i_pos 1)
[18650.415085] FAT-fs (sdb1): Filesystem has been set read-only
[18650.503837] FAT-fs (sdb6): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[18650.715068] EXT4-fs (sdb7): ext4_check_descriptors: Inode bitmap for group 0 not in group (block 709303602)!
[18650.715082] EXT4-fs (sdb7): group descriptors corrupted!
The show starts in one week. A little help solving this would go a long way. My worry is that the disk image is corrupted.
wh7qq
Re: Am i working with a corrupted image here?
Wed Jun 07, 2017 8:09 pm
Try SD Card Copier from the desktop main menu>accessories catagory. It probably uses "dd" in its script but dd can be tricky and dangerous.
