Raspi Zero hardly reachable with the hostname
Posted: Tue Jun 06, 2017 7:06 pm
by bismosa
I'm just trying to set up my new Raspberry Zero.
I have changed the hostname but it takes over 20 seconds to get the user prompt in ssh. I have also installed an Apache Web Server. Here is the same problem. It takes over 20 seconds to get the start page.
If i use the IP- Address from the raspi the login prompt (or the start page) comes immediately.
I have also 2 other Raspberrys with different hostnames (but not updated over one Year). I can easily reach this via the hostname.
I have used the Raspian Jessie Lite Image (Version:April 2017 Release date:2017-04-10 Kernel version:4.4). I have changed the Hostname via raspi-config. Also i have
nano /etc/hostname
cam
nano /etc/hosts
127.0.0.1       localhost
::1             localhost ip6-localhost ip6-loopback
ff02::1         ip6-allnodes
ff02::2         ip6-allrouters
127.0.1.1       cam
I have also executed: sudo /etc/init.d/hostname.sh
And many times rebooted.
I have found in a other Forum a solution:
nano /etc/ssh/sshd_config
UseDNS=no
But this line still exists.
What can i do to resolve this problem?
Thanks! Bismosa
Re: Raspi Zero hardly reachable with the hostname
Posted: Wed Jun 07, 2017 4:30 pm
by bismosa
i have now installed the Raspian full Image. But the problem is the same.
If i use the hostname "cam" it takes more than 20 seconds.
If i use the hostname "campi" or any other name with more characters it will work immediately.
I cant find any restriction in the minimum length of a hostname.
It seems to be a bug?
Regards
Bismosa
Posted: Wed Jun 07, 2017 5:34 pm
by bismosa
Ok. Now i found the solution.
I have found this article (in German)
https://marcowue.wordpress.com/2012/07/ ... alsch-auf/
I have changed the DHCP IP-Range and now it works with "cam".
So it is a Bug in the FritzBox...
Regards
Bismosa
