Glitches on hardware pwm
Posted: Tue Jun 06, 2017 8:18 am
by piveloper
I have connected the Rapsberry Pi to a Stepper driver which controls a stepper motor. Recently I observed step losses on the motor every second or two. This is only noticable at higher RPM (>500 Hz PWM). With a scope I can see that the raspberry pi skips rectangle pulses (see screenshot). Are these glitches normal or is my raspbbery pi broken? Any Ideas if a misconfiguration of the pi can lead to this phenomena?
I used following code to produce the pwm in the screenshot:
import RPi.GPIO as GPIO
import sys  # exit program
import time
import signal
GPIO.setmode(GPIO.BCM)
pin_step = 18
GPIO.setup(pin_step, GPIO.OUT)
pwm = GPIO.PWM(pin_step, 1)
pwm.start(10.0)
freq = 1000
pwm.ChangeFrequency(freq)
def signalHandlerSIGINT(signal, frame):
    pwm.stop()
    GPIO.cleanup()
    sys.exit(0)
signal.signal(signal.SIGINT, signalHandlerSIGINT)
while True:
    time.sleep(10)
Best regards
Re: Glitches on hardware pwm
Posted: Tue Jun 06, 2017 8:48 am
by MaxK1
Which O/S and is it fully up-to-date? What Pi model? Overclocked or not? What else is connected? What else is running?
Posted: Tue Jun 06, 2017 8:52 am
by mattmiller
AFAIK - although pin 12 (BCM18) is capable of using hardware PCM - the RPi.GPIO library treats it like all the others and uses software PWM on it
Try using pigpiod if you need hardware pwm on pins
Posted: Thu Jun 08, 2017 2:31 pm
by piveloper
mattmiller wrote:AFAIK - although pin 12 (BCM18) is capable of using hardware PCM - the RPi.GPIO library treats it like all the others and uses software PWM on it
Thanks for this information! Using pigpiod I was able to get a much more stable pwm signal. Unfortunately pigpiod needs a daemon already running in the background which consumes 5-10% of the cpu time.
I resolved this issue using wiringpi+hardwarepwm:
https://raspberrypi.stackexchange.com/q ... /9725#9725
import wiringpi
pin = 18
freq = 50
wiringpi.wiringPiSetupGpio()
wiringpi.pinMode(pin, 2)
wiringpi.pwmSetMode(wiringpi.PWM_MODE_MS)
piPwmClock = 19.2e6
range_value=200
clock_value=int(piPwmClock / ( range_value*freq))
wiringpi.pwmSetClock(clock_value)
wiringpi.pwmSetRange(range_value)
dutyCycle = 0.5
value = int(dutyCycle*range_value)
wiringpi.pwmWrite(pin,value)
The code above results in a stable hardware pwm with 50 Hz.
I was only able to get the hardware pwm on channel 13 and 18 simultaneously with same frequency. Is there a way to have two hardware pwms with different frequencies on my rpi3 model B?
Posted: Thu Jun 08, 2017 3:06 pm
by joan
There are two hardware PWM channels: channel 0 and channel 1. Each channel can have its own frequency. Channel 0 can be fed to GPIO 12/18, channel 1 can be fed to GPIO 13/19.
pigpio will let you set the frequency and duty cycle (e.g. http://abyz.co.uk/rpi/pigpio/pigs.html#HP ).
Posted: Thu Jun 08, 2017 3:30 pm
by piveloper
joan wrote:There are two hardware PWM channels: channel 0 and channel 1. Each channel can have its own frequency. Channel 0 can be fed to GPIO 12/18, channel 1 can be fed to GPIO 13/19.
I want to avoid running pigpio running in the background as is consumes 5-10% CPU time permanently. But if pigpio can use both hardware pwms there must be a way to use them without pigpio daemon, right?
I searched for it a lot, but I could not find any python code snippet on the internet which enables two hardware pwms (one on BCM18 and one on BCM13).
Posted: Thu Jun 08, 2017 4:00 pm
by joan
piveloper wrote: ...
You pays your money and you takes your choice. :D
http://abyz.co.uk/rpi/pigpio/python.html#hardware_PWM
Posted: Thu Jun 08, 2017 5:31 pm
by piveloper
:roll: well, for that I still need pigpio daemon running. Would be great if there is a solution without a CPU consuming background task.
Posted: Thu Jun 08, 2017 5:50 pm
by joan
It would be quite easy to do. You could take the appropriate parts of gpioHardwarePWM from pigpio.c and incorporate it into http://abyz.co.uk/rpi/pigpio/examples.h ... nimal_gpio
Posted: Thu Jun 08, 2017 6:42 pm
by piveloper
joan wrote:It would be quite easy to do. You could take the appropriate parts of gpioHardwarePWM from pigpio.c and incorporate it into http://abyz.co.uk/rpi/pigpio/examples.h ... nimal_gpio
That may work. But it will take some time for me to figure out how to do it, since I never wrote a c package for python.
Thank you!
