haileyw
Error Taking Photos With Pi Camera
Mon May 29, 2017 6:24 pm
I'm trying to take a time lapse with the raspberry pi camera module V2, but I keep getting the following error when I try to run the python:
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
File "gpioTest.py", line 13, in <module>
camera = picamera.PiCamera(resolution=(3264,2448))
File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 431, in __init__
self._init_camera(camera_num, stereo_mode, stereo_decimate)
File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 460, in _init_camera
"Camera is not enabled. Try running 'sudo raspi-config' "
picamera.exc.PiCameraError: Camera is not enabled. Try running 'sudo raspi-config' and ensure that the camera has been enabled.
I'm confused because the command works for the pi camera attatched to the actual pi board.
Online I saw people saying to reconnect the sunny connector which I tried (although it doesn't say sunny on my cameras) and the same error still shows up. I think I need to reconnect/add the cameras to the pi on the terminal but I'm not sure how to do that. Any thoughts?
DirkS
Re: Error Taking Photos With Pi Camera
Mon May 29, 2017 6:30 pm
Have you tried to enable the camera again in raspi-config (or the GUI configuration utility)?
What is the output of
vcgencmd get_camera
Can you also post /boot/config.txt?
Did you make any (manual) changes to that file?
haileyw
Mon May 29, 2017 6:31 pm
It says:
supported=1 detected=0
B.Goode
So how is the camera connected if it isn't "attached to the actual pi board"?
PS: editted to observe that detected=0 indicates some sort of cable/connection problem.
Strider64
Mon May 29, 2017 6:34 pm
do you have the cable running from the Pi Camera to the rPi in correctly?
"Insanity Is Doing the Same Thing Over and Over Again and Expecting Different Results" ~ Albert Einstein
haileyw
Mon May 29, 2017 6:44 pm
Okay, I think the issue is that the cameras are not connected to the actual board. I have one board set up and 4 cameras, will this work or do I need to attach more boards?
DirkS
Mon May 29, 2017 6:45 pm
haileyw wrote:Okay, I think the issue is that the cameras are not connected to the actual board. I have one board set up and 4 cameras, will this work or do I need to attach more boards?
So what board exactly is the camera connected to?
haileyw
Mon May 29, 2017 6:49 pm
The raspberry pi 3 is the main board with one camera immediately attached to it. The other 3 cameras are not physically connected.
B.Goode
Mon May 29, 2017 7:34 pm
I don't think I understand what you are trying to accomplish.
But I think I am right in saying the the connection between an RPi board and an 'official' camera module is a One-to-one option only.
That is: an RPi board can only connect to a single camera, and a camera module can only connect to a single RPi.
Does that 'break' what you are planning to do?
haileyw
Tue May 30, 2017 12:56 pm
So I realized that the cameras were not capturing pictures because they disconnected from the pi zeros I have set up. Now I'm able to take picture time lapses but for some reason when I try to take a video, the videos that it takes are just of a black screen (which I know is not what it should look like since when I take photos it is not just a black screen). Any ideas on why this is happening?
DirkS
Tue May 30, 2017 1:29 pm
Do you use python + picamera module for video?
Have you tried if it work with raspivid?
haileyw
Thu Jun 01, 2017 2:50 pm
Raspivid worked perfectly for what I need, thanks!
One more similarly related question: When I try and take photo timelapses, I get an error saying my pi failed to create a camera component and I was wondering if any of you knew how to fix this?
I've already tried doing sudo raspi-config and enabling the camera but this does not change anything.
