tux007
max resolution is 1888x1048
Mon May 29, 2017 3:46 pm
My system is a Pi3 with Rasbian jessy lite and manual installed Xserver + LXDE.
I want to use the Pi on a TV and want to have the resolution 1920x1080p.
I tried some values in the /boot/config.txt
e.g.
hdmi_group=1
hdmi_mode=31
But whatever I do, the max resolution is 1888 x 1048
Whats wrong? Do I need any other driver?
beta-tester
Re: max resolution is 1888x1048
Mon May 29, 2017 3:58 pm
for the different HD TVs (1920x1080p 60Hz via HDMI) i found/used, i use these settings my config.txt:
disable_overscan=1
hdmi_force_hotplug=1
config_hdmi_boost=4
hdmi_drive=2
no hdmi_mode, no hdmi_groupe enties
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
drgeoff
Mon May 29, 2017 5:51 pm
tux007 wrote:Hi,
e.g.
hdmi_group=1
hdmi_mode=31
Read the 'Overscan' section at https://www.raspberrypi.org/documentati ... -config.md.
beta-tester
Tue May 30, 2017 3:40 pm
:oops: oops, didn't realized that the size difference is exactly the amount of the overscan pixels.
tux007
Wed May 31, 2017 1:14 am
Yes, the difference is exact the overscan.
With the overscan I can use the full size of the screen, but 1920 x 1080 are not available. :roll:
aBUGSworstnightmare
Wed May 31, 2017 7:56 am
Why not use
hdmi_group=2
hdmi_mode=82
should give you 1080p once overscan is disabled.
