rganeyev.work
Read only file system
Fri May 26, 2017 5:53 am
[384562.914979] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 6, block bitmap and bg descriptor inconsistent: 15748 vs 16194 free clusters
[384562.931061] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384563.068808] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 272, block bitmap and bg descriptor inconsistent: 21448 vs 21621 free clusters
[384563.114549] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384563.119010] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384565.957574] EXT4-fs error (device mmcblk0p2): ext4_find_dest_de:1829: inode #32258: block 8353: comm systemd: bad entry in directory: rec_len is smaller than minimal - offset=0(0), inode=0, rec_len=0, name_len=0
[384588.459492] EXT4-fs error (device mmcblk0p2): ext4_find_dest_de:1829: inode #32258: block 8353: comm systemd: bad entry in directory: rec_len is smaller than minimal - offset=0(0), inode=0, rec_len=0, name_len=0
[384594.288076] EXT4-fs error (device mmcblk0p2): ext4_find_extent:900: inode #17215: comm kworker/u8:1: pblk 34846 bad header/extent: invalid magic - magic 0, entries 0, max 0(0), depth 0(0)
[384594.309672] EXT4-fs (mmcblk0p2): Delayed block allocation failed for inode 17215 at logical offset 22 with max blocks 1 with error 5
[384594.324564] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
[384594.337071] EXT4-fs error (device mmcblk0p2): ext4_find_extent:900: inode #17159: comm kworker/u8:1: pblk 35873 bad header/extent: invalid magic - magic 457f, entries 17996, max 257(0), depth 1(0)
[384594.359837] EXT4-fs (mmcblk0p2): Delayed block allocation failed for inode 17159 at logical offset 22 with max blocks 1 with error 5
[384594.375011] EXT4-fs (mmcblk0p2): This should not happen!! Data will be lost
[384594.390229] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 43, block bitmap and bg descriptor inconsistent: 4690 vs 4687 free clusters
[384599.361929] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384599.366949] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384605.210785] EXT4-fs error (device mmcblk0p2): ext4_find_dest_de:1829: inode #32258: block 8353: comm systemd: bad entry in directory: rec_len is smaller than minimal - offset=0(0), inode=0, rec_len=0, name_len=0
[384621.958211] EXT4-fs error (device mmcblk0p2): ext4_find_dest_de:1829: inode #32258: block 8353: comm systemd: bad entry in directory: rec_len is smaller than minimal - offset=0(0), inode=0, rec_len=0, name_len=0
[384632.855571] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 18, block bitmap and bg descriptor inconsistent: 2826 vs 4848 free clusters
[384632.874535] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.535369] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 288, block bitmap and bg descriptor inconsistent: 21460 vs 21726 free clusters
[384641.553615] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.553677] EXT4-fs error (device mmcblk0p2): ext4_free_inode:339: comm systemd: bit already cleared for inode 2277236
[384641.612322] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 48, block bitmap and bg descriptor inconsistent: 21623 vs 21690 free clusters
[384641.629835] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.657958] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 80, block bitmap and bg descriptor inconsistent: 20894 vs 21068 free clusters
[384641.675568] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.693030] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 160, block bitmap and bg descriptor inconsistent: 21446 vs 21533 free clusters
[384641.710629] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.711644] EXT4-fs error (device mmcblk0p2): ext4_lookup:1581: inode #132701: comm systemd: 'gulp-util' linked to parent dir
[384641.739962] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 96, block bitmap and bg descriptor inconsistent: 21408 vs 21523 free clusters
[384641.757598] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.789841] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 224, block bitmap and bg descriptor inconsistent: 21444 vs 21529 free clusters
[384641.807468] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.849965] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 32, block bitmap and bg descriptor inconsistent: 23068 vs 23099 free clusters
[384641.867507] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.869654] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.882076] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.905492] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384641.982716] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384642.000181] EXT4-fs warning (device mmcblk0p2): ext4_empty_dir:2787: bad directory (dir #132704) - no `.' or `..'
[384642.023296] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384642.044678] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384642.052785] EXT4-fs warning (device mmcblk0p2): ext4_empty_dir:2787: bad directory (dir #132728) - no `.' or `..'
[384642.052816] EXT4-fs warning (device mmcblk0p2): ext4_rmdir:3042: empty directory has too many links (4)
[384642.052890] EXT4-fs warning (device mmcblk0p2): ext4_empty_dir:2787: bad directory (dir #132705) - no `.' or `..'
[384642.062685] EXT4-fs warning (device mmcblk0p2): ext4_empty_dir:2787: bad directory (dir #132673) - no `.' or `..'
[384642.062709] EXT4-fs warning (device mmcblk0p2): ext4_rmdir:3042: empty directory has too many links (3)
[384642.088245] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384642.104598] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384642.270174] JBD2: Spotted dirty metadata buffer (dev = mmcblk0p2, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
[384642.382242] EXT4-fs warning (device mmcblk0p2): ext4_empty_dir:2787: bad directory (dir #132700) - no `.' or `..'
[384642.428280] EXT4-fs warning (device mmcblk0p2): ext4_empty_dir:2787: bad directory (dir #132703) - no `.' or `..'
[384642.428317] EXT4-fs warning (device mmcblk0p2): ext4_rmdir:3042: empty directory has too many links (3)
[384642.462909] EXT4-fs warning (device mmcblk0p2): ext4_empty_dir:2787: bad directory (dir #132684) - no `.' or `..'
[384643.094192] JBD2 unexpected failure: jbd2_journal_revoke: !buffer_revoked(bh);
[384643.094214] inconsistent data on disk
[384643.094225] EXT4-fs: ext4_free_blocks:4683: aborting transaction: IO failure in __ext4_forget
[384643.094664] EXT4-fs error (device mmcblk0p2): ext4_free_blocks:4683: error -5 when attempting revoke
[384643.107197] EXT4-fs (mmcblk0p2): Remounting filesystem read-only
[384643.115003] Aborting journal on device mmcblk0p2-8.
[385793.626936] EXT4-fs (mmcblk0p2): pa 9c179288: logic 173, phys. 1431341, len 83
[385793.635883] EXT4-fs error: 32 callbacks suppressed
[385793.635904] EXT4-fs error (device mmcblk0p2): ext4_mb_release_inode_pa:3772: group 43,
[385793.644972] EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:757: group 39,
[385793.644979] block bitmap and bg descriptor inconsistent: 5263 vs 5281 free clusters
[385793.645023] EXT4-fs (mmcblk0p2): pa b65d5318: logic 434, phys. 1279154, len 78
[385793.645029] EXT4-fs error (device mmcblk0p2): ext4_mb_release_inode_pa:3772: group 39,
[385793.645033] free 78, pa_free 36
[385793.659799] EXT4-fs (mmcblk0p2): pa b65d52d0: logic 390, phys. 1583900, len 122
[385793.659814] EXT4-fs error (device mmcblk0p2): ext4_mb_release_inode_pa:3772: group 48,
[385793.659818] free 122, pa_free 82
[385793.695066] free 83, pa_free 19
[432919.817550] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1000: inode #32258: block 8353: comm systemd-tmpfile: bad entry in directory: rec_len is smaller than minimal - offset=0(8192), inode=0, rec_len=0, name_len=0
B.Goode
Re: Read only file system
Fri May 26, 2017 6:27 am
You have created one and you are proud to show what you have done?
Or you have encountered one by accident and don't know what to do next?
Or something else... ?
