BarryMoon wrote:Thanks both for your replies.
I'm a total beginner with electronics and all things Pi, so I'll have to read up on some of the things you've mentioned. I wouldn't be confident wiring anything up right now!
I have tried another HDMI cable and the symptoms are the same. My TV is grounded, but the Pi itself is not (my power-supply is a "double isolated" unit). Could one solution be to find a supply that does have a ground connection?
I am puzzled about how to tell whether this is an issue with my particular Pi, or my set-up.
Presumably this is not a common problem, and most people are able to use Ethernet and a HDMI connection simultaneously?
obviously yes.
I don't think additionally grounding the PI should matter, nobody else has the need to do so.
If you have a digital volt meter I would measure again the voltage of the input power the PI receives, as you know (bu other readers might not) to that end there are two testpoints (TP1 and TP2) on the PI, one is in between the RCA plug and the pinheader, the other one is near RG2. TP1 is 5V, and TP2 is GND. Between the two you should see something very close to 5V. Earlier you said that you measure 4.77 V, but measure with and without the HDMI cable connected, is there any difference? Also, what happens when you connect the PI to a TV using the Composite connector, do you also get ethernet problems then?
Measure AC voltage between Earth (a water tap perhaps, or the Ground prong of your mains) and the GND (TP2) of the PI, do you see a large AC voltage, what if you disconnect the HDMI cable? What if you disconnect the ethernet cable?
Did you ground the ethernet device that is at the other end of the ethernet cable? It could be that that device carries a high voltage relative to earth, and when the PI isn't grounded it simply "floats" with the high AC voltage, but if you ground the PI, it cant "float" anymore, and the high AC voltage that then exists between the ethernet cable and the PI might disrupt communication, it should not, but I have seen it happen anyway with other Ethernet sporting devices.
