Killertechno
Ssh hangs after password
Sun May 14, 2017 5:13 pm
Hi to all, I'm lucky owner of a new Raspberry Zero W (using latest SD image downloaded from Raspberrypi.org).
I'm trying to access using ssh but after entering password it hangs:
OpenSSH_7.2p2 Ubuntu-4ubuntu2.1, OpenSSL 1.0.2g  1 Mar 2016
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: resolving "192.168.1.95" port 8022
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 192.168.1.95 [192.168.1.95] port 8022.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/michele/.ssh/id_rsa type -1
debug1: identity file /home/michele/.ssh/id_rsa-cert type -1
debug1: identity file /home/michele/.ssh/id_dsa type -1
debug1: identity file /home/michele/.ssh/id_dsa-cert type -1
debug1: identity file /home/michele/.ssh/id_ecdsa type -1
debug1: identity file /home/michele/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/michele/.ssh/id_ed25519 type -1
debug1: identity file /home/michele/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1 Raspbian-5+deb8u3
debug1: match: OpenSSH_6.7p1 Raspbian-5+deb8u3 pat OpenSSH* compat 0x04000000
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 192.168.1.95:8022 as 'lzer0'
debug3: put_host_port: [192.168.1.95]:8022
debug3: hostkeys_foreach: reading file "/home/michele/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /home/michele/.ssh/known_hosts:42
debug3: load_hostkeys: loaded 1 keys from [192.168.1.95]:8022
debug3: order_hostkeyalgs: prefer hostkeyalgs: [email protected],[email protected],[email protected],ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: [email protected],ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,ext-info-c
debug2: host key algorithms: [email protected],[email protected],[email protected],ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,[email protected],[email protected],ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos: [email protected],aes128-ctr,aes192-ctr,aes256-ctr,[email protected],[email protected],aes128-cbc,aes192-cbc,aes256-cbc,3des-cbc
debug2: ciphers stoc: [email protected],aes128-ctr,aes192-ctr,aes256-ctr,[email protected],[email protected],aes128-cbc,aes192-cbc,aes256-cbc,3des-cbc
debug2: MACs ctos: [email protected],[email protected],[email protected],[email protected],[email protected],[email protected],[email protected],hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: [email protected],[email protected],[email protected],[email protected],[email protected],[email protected],[email protected],hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,[email protected],zlib
debug2: compression stoc: none,[email protected],zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: [email protected],ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1
debug2: host key algorithms: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256,ssh-ed25519
debug2: ciphers ctos: aes128-ctr,aes192-ctr,aes256-ctr,[email protected],[email protected],[email protected]
debug2: ciphers stoc: aes128-ctr,aes192-ctr,aes256-ctr,[email protected],[email protected],[email protected]
debug2: reserved 0
debug1: kex: algorithm: [email protected]
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: [email protected] MAC: <implicit> compression: none
debug1: kex: client->server cipher: [email protected] MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:GUN/LQ7pnvR5/t11mK5U9vWvsZD/gUuY2gajGivMFf4
debug1: Host '[192.168.1.95]:8022' is known and matches the ECDSA host key.
debug1: Found key in /home/michele/.ssh/known_hosts:42
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug2: key: /home/michele/.ssh/id_rsa ((nil))
debug2: key: /home/michele/.ssh/id_dsa ((nil))
debug2: key: /home/michele/.ssh/id_ecdsa ((nil))
debug2: key: /home/michele/.ssh/id_ed25519 ((nil))
debug3: send packet: type 5
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /home/michele/.ssh/id_rsa
debug3: no such identity: /home/michele/.ssh/id_rsa: No such file or directory
debug1: Trying private key: /home/michele/.ssh/id_dsa
debug3: no such identity: /home/michele/.ssh/id_dsa: No such file or directory
debug1: Trying private key: /home/michele/.ssh/id_ecdsa
debug3: no such identity: /home/michele/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: /home/michele/.ssh/id_ed25519
debug3: no such identity: /home/michele/.ssh/id_ed25519: No such file or directory
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
debug2: we sent a password packet, wait for reply
debug3: receive packet: type 52
debug1: Authentication succeeded (password).
Authenticated to 192.168.1.95 ([192.168.1.95]:8022).
debug2: fd 5 setting O_NONBLOCK
debug3: fd 6 is O_NONBLOCK
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug3: send packet: type 90
debug1: Requesting [email protected]
debug3: send packet: type 80
debug1: Entering interactive session.
debug1: pledge: network
debug3: receive packet: type 91
debug2: callback start
debug2: fd 3 setting TCP_NODELAY
debug3: ssh_packet_set_tos: set IP_TOS 0x10
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug3: send packet: type 98
debug1: Sending environment.
debug3: Ignored env XDG_VTNR
debug1: Sending env LC_PAPER = it_IT.UTF-8
debug2: channel 0: request env confirm 0
debug1: Sending env LC_ADDRESS = it_IT.UTF-8
debug3: Ignored env XDG_SESSION_ID
debug3: Ignored env XDG_GREETER_DATA_DIR
debug1: Sending env LC_MONETARY = it_IT.UTF-8
debug3: Ignored env CLUTTER_IM_MODULE
debug3: Ignored env SESSION
debug3: Ignored env GPG_AGENT_INFO
debug3: Ignored env TERM
debug3: Ignored env VTE_VERSION
debug3: Ignored env XDG_MENU_PREFIX
debug3: Ignored env SHELL
debug3: Ignored env QT_LINUX_ACCESSIBILITY_ALWAYS_ON
debug3: Ignored env WINDOWID
debug1: Sending env LC_NUMERIC = it_IT.UTF-8
debug3: Ignored env QTDIR
debug3: Ignored env UPSTART_SESSION
debug3: Ignored env GNOME_KEYRING_CONTROL
debug3: Ignored env GTK_MODULES
debug3: Ignored env USER
debug3: Ignored env LS_COLORS
debug3: Ignored env QT_ACCESSIBILITY
debug1: Sending env LC_TELEPHONE = it_IT.UTF-8
debug3: Ignored env XDG_SESSION_PATH
debug3: Ignored env XDG_SEAT_PATH
debug3: Ignored env SSH_AUTH_SOCK
debug3: Ignored env SESSION_MANAGER
debug3: Ignored env DEFAULTS_PATH
debug3: Ignored env XDG_CONFIG_DIRS
debug3: Ignored env DESKTOP_SESSION
debug3: Ignored env PATH
debug3: Ignored env QT_IM_MODULE
debug3: Ignored env QT_QPA_PLATFORMTHEME
debug1: Sending env LC_IDENTIFICATION = it_IT.UTF-8
debug3: Ignored env XDG_SESSION_TYPE
debug3: Ignored env PWD
debug3: Ignored env JOB
debug3: Ignored env XMODIFIERS
debug3: Ignored env GNOME_KEYRING_PID
debug1: Sending env LANG = en_US.UTF-8
debug3: Ignored env GDM_LANG
debug3: Ignored env MANDATORY_PATH
debug1: Sending env LC_MEASUREMENT = it_IT.UTF-8
debug3: Ignored env COMPIZ_CONFIG_PROFILE
debug3: Ignored env IM_CONFIG_PHASE
debug3: Ignored env GDMSESSION
debug3: Ignored env SESSIONTYPE
debug3: Ignored env GTK2_MODULES
debug3: Ignored env SHLVL
debug3: Ignored env HOME
debug3: Ignored env LANGUAGE
debug3: Ignored env GNOME_DESKTOP_SESSION_ID
debug3: Ignored env UPSTART_INSTANCE
debug3: Ignored env UPSTART_EVENTS
debug3: Ignored env XDG_SESSION_DESKTOP
debug3: Ignored env LOGNAME
debug3: Ignored env COMPIZ_BIN_PATH
debug3: Ignored env DBUS_SESSION_BUS_ADDRESS
debug3: Ignored env XDG_DATA_DIRS
debug3: Ignored env QT4_IM_MODULE
debug3: Ignored env LESSOPEN
debug3: Ignored env INSTANCE
debug3: Ignored env UPSTART_JOB
debug3: Ignored env XDG_RUNTIME_DIR
debug3: Ignored env DISPLAY
debug3: Ignored env XDG_CURRENT_DESKTOP
debug3: Ignored env GTK_IM_MODULE
debug3: Ignored env LESSCLOSE
debug1: Sending env LC_TIME = it_IT.UTF-8
debug1: Sending env LC_NAME = it_IT.UTF-8
debug3: Ignored env XAUTHORITY
debug3: Ignored env _
debug2: channel 0: request shell confirm 1
debug2: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
If I try to connect to another (old) Pi in same network, after last message I got:
debug3: receive packet: type 99
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: channel 0: rcvd adjust 2097152
debug2: shell request accepted on channel 0
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
The same (hangs after password) if using Putty from Windows.
Any ideas and/or known bugs?
Thanks.
SurferTim
Re: Ssh hangs after password
Mon May 15, 2017 11:03 am
I don't know about the Ubuntu OS with ssh, but I had problems with Raspbian. Maybe the fix will be the same.
If your login hangs after the password entry, and you are using wifi as the network device, then edit /etc/ssh/sshd_config and add this to the end:
IPQoS cs0 cs0
hortimech
Mon May 15, 2017 11:13 am
Does /home/michele exist on the zero ?
Killertechno
Mon May 15, 2017 5:42 pm
SurferTim wrote:I don't know about the Ubuntu OS with ssh, but I had problems with Raspbian. Maybe the fix will be the same.
IPQoS cs0 cs0
Ok, done through something similar (taken from https://expresshosting.net/ssh-hanging-authentication):
on both
/etc/ssh/ssh_config
just append
IPQoS 0x00
Thanks for suggestion
timrowledge
Wed May 24, 2017 9:27 pm
Unfortunately this doesn't seem to help me with what looks like the same problem. The really odd part is that on one occasion I simply fed up waiting and hit ctl-c (in the Mac terminal) and... suddenly I had a working connection. Adding the IPQoS line made no difference to this.
This is what I get as debug output -
$ ssh [email protected] -vvv
OpenSSH_7.4p1, LibreSSL 2.5.0
debug1: Reading configuration data /Users/tim/.ssh/config
debug1: /Users/tim/.ssh/config line 17: Applying options for *
debug2: resolving "192.168.1.103" port 22
debug1: Connecting to 192.168.1.103 [192.168.1.103] port 22.
debug1: identity file /Users/tim/.ssh/id_rsa type -1
debug1: identity file /Users/tim/.ssh/id_rsa-cert type -1
debug1: identity file /Users/tim/.ssh/id_dsa type -1
debug1: identity file /Users/tim/.ssh/id_dsa-cert type -1
debug1: identity file /Users/tim/.ssh/id_ecdsa type -1
debug1: identity file /Users/tim/.ssh/id_ecdsa-cert type -1
debug1: identity file /Users/tim/.ssh/id_ed25519 type -1
debug1: identity file /Users/tim/.ssh/id_ed25519-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.4
debug1: Authenticating to 192.168.1.103:22 as 'pi'
debug3: hostkeys_foreach: reading file "/Users/tim/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /Users/tim/.ssh/known_hosts:5
debug3: load_hostkeys: loaded 1 keys from 192.168.1.103
debug2: KEX algorithms: curve25519-sha256,[email protected],ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c
debug2: reserved 0
debug2: reserved 0
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:GzbCaPGhYdRgLlmmarPCKHulSGcUmRG1ZEVKNTBhgwg
debug1: Host '192.168.1.103' is known and matches the ECDSA host key.
debug1: Found key in /Users/tim/.ssh/known_hosts:5
debug2: key: /Users/tim/.ssh/id_rsa (0x0)
debug2: key: /Users/tim/.ssh/id_dsa (0x0)
debug2: key: /Users/tim/.ssh/id_ecdsa (0x0)
debug2: key: /Users/tim/.ssh/id_ed25519 (0x0)
debug3: preferred publickey,keyboard-interactive,password
debug1: Trying private key: /Users/tim/.ssh/id_rsa
debug3: no such identity: /Users/tim/.ssh/id_rsa: No such file or directory
debug1: Trying private key: /Users/tim/.ssh/id_dsa
debug3: no such identity: /Users/tim/.ssh/id_dsa: No such file or directory
debug1: Trying private key: /Users/tim/.ssh/id_ecdsa
debug3: no such identity: /Users/tim/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: /Users/tim/.ssh/id_ed25519
debug3: no such identity: /Users/tim/.ssh/id_ed25519: No such file or directory
[email protected]'s password:
Authenticated to 192.168.1.103 ([192.168.1.103]:22).
debug1: pledge: exec
debug2: x11_get_proto: /opt/X11/bin/xauth  list /private/tmp/com.apple.launchd.plIhIRbtyZ/org.macosforge.xquartz:0 2>/dev/null
debug1: Requesting X11 forwarding with authentication spoofing.
debug2: channel 0: request x11-req confirm 1
debug1: Requesting authentication agent forwarding.
debug2: channel 0: request [email protected] confirm 0
debug2: X11 forwarding request accepted on channel 0
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed May 24 14:20:15 2017 from 192.168.1.65
debug3: receive packet: type 90
debug1: client_input_channel_open: ctype x11 rchan 4 win 65536 max 16384
debug1: client_request_x11: request from ::1 58192
debug2: fd 7 setting O_NONBLOCK
debug3: fd 7 is O_NONBLOCK
debug1: channel 1: new [x11]
debug1: confirm x11
debug3: send packet: type 91
and then after ctl-c
debug3: receive packet: type 82
debug3: receive packet: type 96
debug2: channel 1: rcvd eof
debug2: channel 1: output open -> drain
debug2: channel 1: obuf empty
debug2: channel 1: close_write
debug2: channel 1: output drain -> closed
debug1: channel 1: FORCE input drain
debug2: channel 1: ibuf empty
debug2: channel 1: send eof
debug3: send packet: type 96
debug2: channel 1: input drain -> closed
debug2: channel 1: send close
debug3: send packet: type 97
debug3: channel 1: will not send data after close
^Cdebug3: channel 1: will not send data after close
debug3: receive packet: type 97
debug2: channel 1: rcvd close
debug2: channel 1: is dead
debug2: channel 1: garbage collecting
debug1: channel 1: free: x11, nchannels 2
debug3: channel 1: status: The following connections are open:
  #0 client-session (t4 r0 i0/0 o0/0 fd 4/5 cc -1)
  #1 x11 (t4 r4 i3/0 o3/0 fd 7/7 cc -1)
[email protected]:~$
At that point I have working ssh connection (so far as I can tell without knowing clever tests) but I keep getting debug output like this -
[email protected]:~$ debug3: send packet: type 80
Given that until recently a plain
ssh 192.168.1.103
worked perfectly well, I'm a bit irritated. It works ok from Pi to Pi, by the way.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
