Arkantos1908
Audio noise
Wed Apr 26, 2017 7:00 pm
Whenever I use the 3.5 mm audio jacket I get a lot of background noise even when I'm not playing any sounds. Can I fix this by buying the analog audio extentsion board or is there a simpler (and cheaper) solution?
Thanks in advance.
MaxK1
Re: Audio noise
Thu Apr 27, 2017 5:31 am
Well, one person reported that pushing the 3.5mm plug in all the way cured it for him... ;-) Certainly a cheap solution!
You didn't mention what version of the Pi and how you are powering it. Are you feeding headphones or an audio amp?
If it's an audio amp, how is it powered?
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Arkantos1908
Re: Audio noise
Thu Apr 27, 2017 9:25 pm
Thank you for answering.
I am using the Raspberry pi 3. It will be conected to headphones.
