elatllat
mount hangs
Sun Sep 23, 2012 4:42 am
1) Anyone know what the stack trace in this link means?:
https://bugs.launchpad.net/raspbian/+bug/1054768
2) Anyone else having problems with mount?
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
elatllat
Re: mount hangs
Tue Sep 25, 2012 8:00 pm
The workaround (until the kernel is fixed) is to use an old kernel:
"rpi-downgrade":
#!/bin/bash
set -o nounset
set -o errexit
UPDATE=${UPDATE:-1}
ROOT_PATH=${ROOT_PATH:-"/"}
BOOT_PATH=${BOOT_PATH:-"/boot"}
SKIP_KERNEL=${SKIP_KERNEL:-0}
FW_REPOLOCAL="${ROOT_PATH}/root/rpi-firmware"
FW_PATH="${BOOT_PATH}"
FW_MODPATH="${ROOT_PATH}/lib/modules"
FW_RAM=${1:-0}
function detect_split() {
	if [[ -f "$FW_PATH/start.elf" && ${FW_RAM} -eq 0 ]]; then
		echo "Autodetecting memory split"
		FW_RAM=240
		for R in 128 192 224 240
		do
			if [[ -f "$FW_PATH/arm${R}_start.elf" ]]
			then
      				if diff "$FW_PATH/arm${R}_start.elf" "$FW_PATH/start.elf" >/dev/null
      				then
        				FW_RAM=$R
        				break
      				fi
			fi
		done
	fi
	FW_GPU=$((256-FW_RAM))
function update_modules {
	if [[ ${SKIP_KERNEL} -eq 0 ]]; then
		cp -R "${FW_REPOLOCAL}/modules/"* "${FW_MODPATH}/"
		find "${FW_REPOLOCAL}/modules" -mindepth 1 -maxdepth 1 -type d | while read DIR; do
			depmod -b "${ROOT_PATH}" -a $(basename "${DIR}")
		done
	fi
function update_sdk {
	if [[ -f /etc/init.d/vcfiled ]]; then
		/etc/init.d/vcfiled stop
	fi
	ELFOUTPUT=$(readelf -a "${ROOT_PATH}/bin/bash")
	if [ "${ELFOUTPUT}" != "${ELFOUTPUT/VFP_args/}" ]; then
		echo "Using HardFP libraries"
		cp -R "${FW_REPOLOCAL}/vc/hardfp/"* "${ROOT_PATH}/"
	else
		echo "Using SoftFP libraries"
		cp -R "${FW_REPOLOCAL}/vc/softfp/"* "${ROOT_PATH}/"
	fi
	cp -R "${FW_REPOLOCAL}/vc/sdk/"* "${ROOT_PATH}/"
		/etc/init.d/vcfiled start
	fi
function set_split {
	cp "${FW_PATH}/arm${FW_RAM}_start.elf" "${FW_PATH}/start.elf"
function update_firmware {
	cp "${FW_REPOLOCAL}/"*.elf "${FW_PATH}/"
	cp "${FW_REPOLOCAL}/"*.bin "${FW_PATH}/"
		cp "${FW_REPOLOCAL}/"*.img "${FW_PATH}/"
	else
		echo "Skipping kernel/modules updated as requested"
	fi
function finalise {
	ldconfig -r "${ROOT_PATH}"
	sync
function do_backup {
	cp -a "${FW_PATH}" "${FW_PATH}.bak"
	cp -a "${FW_MODPATH}" "${FW_MODPATH}.bak"
function do_update {
	update_firmware
	update_modules
	update_sdk
	set_split
	finalise
	echo "If no errors appeared, your firmware was successfully $1"
	if [[ "${ROOT_PATH}" == "/" ]]; then
		echo "A reboot is needed to activate the new firmware"
	fi
if [[ ${EUID} -ne 0 ]]; then
	echo "This tool must be run as root"
	exit 1
fi
if [[ ( "${ROOT_PATH}" == "/"  &&  "${BOOT_PATH}" != "/boot" ) ]] ||
[[ ( "${BOOT_PATH}" == "/boot"  &&  "${ROOT_PATH}" != "/" ) ]]; then
	echo "You need to specify both ROOT_PATH and BOOT_PATH, or neither"
	exit 1
fi
if [[ ! -d "${FW_PATH}" ]]; then
	echo "${FW_PATH} doesn't exist"
	exit 1
fi
if [[ ! -f "${FW_PATH}/start.elf" ]]; then
	echo "${FW_PATH}/start.elf doesn't exist."
	exit 1
fi
if [[ ! -d "${FW_MODPATH}" ]]; then
	echo "${FW_MODPATH} doesn't exist"
	exit 1
fi
command -v readelf >/dev/null 2>&1 || {
	echo "This tool requires you have readelf installed, please install it first"
	echo "In Debian, try: sudo apt-get install binutils"
	echo "In Arch, try: pacman -S binutils"
	exit 1
detect_split
if [[ ${FW_RAM} -ne 240 ]] &&[[ ${FW_RAM} -ne 224 ]] && [[ ${FW_RAM} -ne 192 ]] && [[ ${FW_RAM} -ne 128 ]]; then
	echo "RAM value must be one of: 240, 224, 192, 128"
	exit 1
fi
echo "Using ARM/GPU memory split of ${FW_RAM}MB/${FW_GPU}MB"
apt-get update
apt-get upgrade
cd ~/
apt-get install -y git
git clone http://github.com/Hexxeh/rpi-firmware.git
cd rpi-firmware
git checkout 8c628900aabe4a15743d8a11cb6169ad0bf1918e
if [[ -f "${FW_REPOLOCAL}/.git/config" ]]; then
	do_update "updated"
else
	echo "no local repo"
fi
shutdown -r now
elatllat
Re: mount hangs
Wed Sep 26, 2012 8:17 pm
By the way as of this post:
Latest Linux kernel:
3.5.4
Latest Linux kernel for the rpi:
3.2.27
Latest Linux kernel for the rpi that will mount a device mapper:
3.1.9
elatllat
Re: mount hangs
Fri Jun 07, 2013 2:55 am
This is now fixed ( tested in kernel 3.6.11 )
