paulwratt
raspberrypi.fritz
Thu Apr 20, 2017 1:26 am
why do I have a TCP connection with HTTPS over "local host" to raspberrypi.fritz (IP address is foreign)
(top 3 lines of "netstat" output)
Paul
paulwratt
Re: raspberrypi.fritz
Thu Apr 20, 2017 9:37 am
is this one of those BotNet hacks people have been talking about lately?
I check for "fritz" as a package and get nothing
The IP addresses were foreign and connected, before I blocked the host name in /etc/hosts
over SSH, is it a VPN?
the only thing on google is references to:
raspberrypi.fritz.box
anyone have any ideas?
Paul
mfa298
Thu Apr 20, 2017 7:54 pm
sudo netstat -ntp
will show the process owning a particular connection (this is one of the times when you do need sudo)
If the name from netstat isn't that useful then ps -ef or looking at /proc/PID might help. e.g looking at one of my Pis. You can also use dpkg -S to see what package owns a file.
[email protected]:~ $ sudo netstat -nutp
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0     88 192.168.1.76:22        192.168.1.254:50883    ESTABLISHED 843/sshd: pi [priv]
[email protected]:~ $ sudo ls -l /proc/843/exe
lrwxrwxrwx 1 root root 0 Apr 19 23:29 /proc/843/exe -> /usr/sbin/sshd
[email protected]:~ $ dpkg -S /usr/sbin/sshd
openssh-server: /usr/sbin/sshd
paulwratt
Tue Apr 25, 2017 10:19 am
thankyou for that
if I un-hosts the url I might be able to see which process it is attached to, but I have already disabled "sshd"
if there is more interest in tracking the IP address associated with the (vpn style) local url, I would be happy to investigate it further
seems no one is interested tho..
Cheers
Paul
RaTTuS
Tue Apr 25, 2017 10:27 am
have you opened up your RPI to the internet via your router ?
if so what instructions did you follow ?
have you changed your pi password from raspberry ?
remove the sdcard burn a new image on afresh one - update it
copy any data you have on the old one - not programs
learn to security
Covfefe
ghans
Tue Apr 25, 2017 10:35 am
Do you actually own a FritzBox (or a rebadge from your ISP) ? They automatically make any connected device reachable under hostname.fritz.box.
It is a convenience function , i don't think it's malicious.
ghans
