Will_35
I forgot my password...
Tue Apr 11, 2017 4:20 pm
I am pretty sure I know my username but I have forgotten my password I am running raspbian and I do not have a micro SD capable PC and do not want to get an adapter it has been months since I used my pi please help
Re: I forgot my password...
Tue Apr 11, 2017 5:17 pm
USB adapters cost a quid.
Is this a NOOBS system or a plain Raspbian system?
If NOOBS hold or tap the [SHIFT] key during boot and you get the recovery system with a config.txt and command line (cmdline.txt) editor.
Change cmdline.txt from
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=84fa8189-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet
to
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=84fa8189-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet init=/bin/sh
boot that and you'll get a root shell. Mount your rootfs and you can use the passwd pi command to reset your password.
If it's plain Raspbian you're going to need another computer (or another SDCard for your Raspberry) and a £1 USB reader. You can make the same edit on Windows using notepad+ or editpadlite7 or notepad++ or wordpad.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Will_35
Tue Apr 11, 2017 5:44 pm
DougieLawson wrote:USB adapters cost a quid.
to
Yes it is noobs and I have done that but it just goes to the normal password screen as though I have done nothing
Tue Apr 11, 2017 6:06 pm
Then you're not editing the right cmdline.txt.
Mounting the SDCard in another Linux system is going to be your best option. Or just reformat in your camera, get a copy of NOOBS 2.4 on it and start from a clean install.
Or use the NOOBS recovery system to trash everything and re-install.
Your choice. £6 (£5 for an 8GB SDCard & £1 for a USB reader) or trash and start from a blank newly installed system.
Will_35
Wed Apr 12, 2017 8:13 am
Sorry I'm a complete beginner on Linux and pi I have gotten into the command prompt but I don't know what you mean by mount your roots. Sorry but any help would be much appreciated
Wed Apr 12, 2017 8:43 pm
Scrap your SDCard and start with a fresh copy of NOOBS 2.4. You're venturing into territory where experts fear to tread. Recovery of a lost password isn't something I'd expect a new or novice user to be able to do.
If you go with a new SDCard and a USB reader you may be able to retrieve stuff you did before losing your password.
If you change your password write it down or store it in a secure password safe. Having a non-disclosed password is only important if you're running an internet server.
jmslee_2000
Thu Apr 27, 2017 3:10 pm
Hey, I wrote down my password after I installed Pure-FTPd but I cannot login my Pi via SSH, it always report me failed password, I tried to connect to FTP but password doesn't work. Does it help to edit cmdline.txt to reset password?
Will_35
Fri Apr 28, 2017 5:45 pm
I tried that I got to command prompt I'm probably really stupid I can change the password there right?
romermsp
Sun Aug 13, 2017 2:44 pm
hi all,
i try to reset my password because it was changed by a hacker.
when i input : mount -o remount,rw /,
it echo an error: can`t find partuuid=xxxxx,but i had already check that the partuuid is in the fstab,
so what's the problem?
beta-tester
Sun Aug 13, 2017 8:35 pm
what uuid does the partition has - you can get with blkid?
and what uuid is in the /etc/fstab (and what uuid is in the cmdline.txt)?
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B, RPi3B, RPi3B+, RPiZeroW, ...
romermsp
Mon Aug 14, 2017 4:33 am
hi beta-tester,
blkid:
/dev/mmcblk0p1: label ="boot" uuid="50a6-027f" type="vfat"
/dev/mmcblk0p2: uuid="5c01c1ce-fe60-428a-8e68-0be0e8ed6b7a" type="ext4"
/etc/fstab:
partuuid=96c161cb-01 /boot .......
partuuid=96c161cb-02 / .......
cmdline.txt:
root=PARTUUID=96c161cb-02 rootfstype=ext4
elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
init=/bin/sh
beta-tester
Mon Aug 14, 2017 10:11 am
oops, i thought, blkid will show the PARTUUID as well. on my pi, it shows me the PARTUUID.
why do you have to remount the root / as read-write, isn't it mounted as rw already?
i think it is quicker (and safer) to reflash & reinstall the SD card... specially when you say, you were hacked - who know, what else was hacked.
RaTTuS
Mon Aug 14, 2017 10:14 am
hi all,
start again from a fresh install , a hacked system leaves you exposed to too much stuff,
with the new install do not expose the user pi to the internet without changing it's password at the very least
Covfefe
romermsp
Tue Aug 15, 2017 12:40 pm
set init=/bin/sh in cmdline.txt to boot ,the file system is read only.
the reason I try to reset the password is that I want read the log more convenient by ssh,to know when and how did he hacker attack me.
ok,I decide to reinstall now. thanks
romermsp
Tue Aug 15, 2017 12:46 pm
hi all,
yes ,I kept the default password and map the port 80 to the route...
you are right ,thanks
