davy128
Stretch kill wifi, bluettoth rpi3
Fri Mar 31, 2017 3:24 am
I wanted to install the latest version of bluez and followed this instructions in order to install bluez from stretch: http://raspberrypi.stackexchange.com/a/59436
With stretch enabled I did a: sudo apt-get upgrade, that kill raspbian.
So I formatted the sd card and make a clean install. But the wifi adapter and the Bluetooth adapter don't work.
Does anyone know how to solve this problem?
davy128
Re: Stretch kill wifi, bluettoth rpi3
Fri Mar 31, 2017 4:30 am
executing dmesg gives:
mmc1: error -110 whilst initialising SDIO card
and ip a doesn't show the wifi interface
youness
Fri Mar 31, 2017 7:58 am
I don't remember where I read that, but when you upgrade Raspbian to Stretch, you may loose the firmwares for WiFi and Bluetooth, a matter of license or something like that, anyway.
Try to download the firmware and copy/past them in the corresponding locations:
lib/firmware/brcm/brcmfmac43430-sdio.bin
lib/firmware/brcm/brcmfmac43430-sdio.txt
lib/firmware/BCM43430A1.hcd
davy128
Fri Mar 31, 2017 6:01 pm
As I made a clean install I have those files in my systems. Nevertheless, I downloaded from github those files and replace them but it didn't work. Both wifi and Bluetooth adapters not found. :cry:
youness
Tue Apr 04, 2017 10:49 am
Why did you replace them?
The ones coming with fresh install work fine.
