Hey there, Raspberry community.
I have a problem and I can't pinpoint a source of it.
Quick description:
1 - I have a 4GB SD card and a 8GB SD card.
2- I tried burning Jessie Lite on both cards with Etcher. On "Validation" stage it always said "Image was burned on SD card but it cannot be read to be validated".
3 - I started running Etcher as admin and both image burning and just uploading NOOBS dist is working on my 4GB memory card (sadly I can't install desktop GUI on it because it's only 4GBs).
4 - Validation error still persists on 8GB one. (Etcher. Windisk32 doesn't show any errors but RPZ doesn't boot either way.)
5 - I checked 8GB with card MiniTool Partition Wizard for errors - all sectors and SD card appears to be fully functional but somehow nothing happens when I plug in my RPZ into USB on my computer for power - no leds turning on and the monitor doesn't show me the booting up process. If I put my 4GB SD with burnt Jessie Lite - everything is fine.
I formatted it to FAT32, exFAT (which should work AFAIK) and even split it into two FAT (4GBs cluster, prime and logical) to try if it will work that way but to no success.
What do I do? Throw away that brand new SD card? It is functional - I can upload pics, vids and so on, and MiniTool PW didn't find any errors.
Tried using search engine on both google and this forum to no avail - google just doesn't have any info on this matter and this forum doesn't allow you to search for words "card" and "sd" because one is too common and the other one is less than 3 letters long.
Thanks.
