Right then my Pi arrived the other day. I had the foresight to get hold of an 8GB SD card (class 10) and followed the instruction i found on you tube to install an operating sustem image on the SD; this is what i did using my XP based net book:
Downloaded raspian wheezy
Checked it against SHA-1 and validated download
Used Win32 Disk imager to write the OS to SD
Pi turned up i plugged in the SD and connected a 5v 0.7A (700mA) power supply; after hooking up the HDMI to the tv and plugging my mouse, note no keybpoard as still inbound courtesy of delayed mail.
Red light is on and steady indicating constant power supply, after an hour nothing happened. Taken the SD card out of Pi to see if I could re-write the OS but now I cannot see the SD card in my XP machine or my windows 7 laptops.
Can any body suggest why i am not able to see my SD card, even with auto run enabled or disabled there is no sign of SD so i cannot even check to see if the OS is on there. I checked viruses on both laptops but i am completely at a loss here.
Any help would be greatlfully appreciated. Please note that i searched the forum but any search that includes the words OS/SD/disk image etc returns too many results to display.
Kind regards
Craig
