Laen
Pi Zero W identifying as "B Rev 2"
Thu Mar 23, 2017 9:17 pm
I recently purchased some Pi Zero W's from Adafruit, and I'm having trouble with one of them. When I boot it up, there's no wlan0, and the "Revision" in /proc/cpuinfo us 000f, which I believe indicates "Model B Rev 2". The same memory card in another PiZeroW works properly.
The bottom silkscreen on the board says It's a Pi Zero W v1.1.
Is this something that can be fixed with a firmware update, or should I return it to Adafruit?
Thanks,
-Laen
OSH Park
Laen
Re: Pi Zero W identifying as "B Rev 2"
Thu Mar 23, 2017 11:27 pm
I went through all 10 of the Pi Zero W's I purchased, and 5 of them are "bad".
I've tried running "rpi-update" on a bad one, and that didn't fix it.
Here's /proc/cpuinfo on a "bad" one:
processor	: 0
model name	: ARMv6-compatible processor rev 7 (v6l)
BogoMIPS	: 697.95
Features	: half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2835
Revision	: 000f
Serial		: 000000000a59fd89
Here it is on a good one:
processor	: 0
BogoMIPS	: 697.95
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 9000c1
Serial		: 0000000040a07aef
"Hardware" and "Revision" are different.
arraybytes
Fri Mar 24, 2017 2:31 am
did you get the W's form the same source?
did you buy them all at the same time?
Laen
Fri Mar 24, 2017 3:36 am
Yes. All 10 came from Adafruit in the same order.
Physically, the non-working ones look exactly like the working ones. Chip markings are all the same, they all say "Pi Zero W 1.1" on the bottom silkscreen.
Laen
Fri Mar 24, 2017 6:18 am
Okay, getting closer.. It looks like the wrong device tree is being selected by uBoot on the "bad" ones. I don't yet know how uBoot chooses which one to select.
Bad:
001399.502: Read command line from file 'cmdline.txt'
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles modules-load=dwc2,g_ether
001710.700: Loading 'kernel.img' to 0x8000 size 0x3f1128
001710.750: No kernel trailer (run mkknlimg to fix) - assuming DT-capable
001714.426: Loading 'bcm2708-rpi-b.dtb' to 0x3f9128 size 0x36ba
001774.871: dtparam: audio=on
001791.638: Loaded overlay 'dwc2'
002719.211: Device tree loaded to 0x1bfec400 (size 0x3bd7)
002720.480: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
003761.568: vchiq_core: vchiq_init_state: slot_zero = 0x5b880000, is_master = 1
003766.307: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
003771.899: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x00000004
Good:
001769.777: *** Restart logging
001772.896: Read command line from file 'cmdline.txt'
002050.004: Loading 'kernel.img' to 0x8000 size 0x3f1128
002053.688: No kernel trailer (run mkknlimg to fix) - assuming DT-capable
002056.197: Loading 'bcm2708-rpi-0-w.dtb' to 0x3f9128 size 0x39ba
002120.073: dtparam: audio=on
002137.952: Loaded overlay 'dwc2'
003164.265: Device tree loaded to 0x17fec100 (size 0x3eff)
003165.646: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
004196.051: vchiq_core: vchiq_init_state: slot_zero = 0x57880000, is_master = 1
004200.771: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
Paul Webster
Contact: Twitter
Fri Mar 24, 2017 7:12 am
Laen wrote:Yes. All 10 came from Adafruit in the same order.
Interesting side issue .... looks like the 1 Zero-W per order was relaxed.
Martin Frezman
Fri Mar 24, 2017 8:18 am
Not necessarily. My understanding is that the "1 per" limit is only on purchases of "Just the Zero". If you buy some kind of kit that includes the Zero, then you can buy as many as you want. Adafruit, in particular, sells lots of different such kits. I'm guessing that's what OP did.
Fri Mar 24, 2017 8:57 am
Are you sure your SDCard is loaded with the right version of Raspbian or NOOBS to support your shiny new hardware?
Adafruit are notorious for shipping SDCards loaded with pre-historic versions of NOOBS that aren't updated for the new hardware they ship them with. (Someone should give them a slap for doing that.)
Try reformatting your SDCards and loading them up with 2017-03-02 Raspbian of NOOBS 2.3.
gregeric
Fri Mar 24, 2017 9:41 am
Sounds like the revision hasn't been written to OTP at the factory. See viewtopic.php?f=43&t=160611
Laen
Fri Mar 24, 2017 2:10 pm
DougieLawson wrote:Are you sure your SDCard is loaded with the right version of Raspbian or NOOBS to support your shiny new hardware?
Yes. I've been doing all my testing with 2017-03-02.
Laen
Fri Mar 24, 2017 2:14 pm
gregeric wrote:Sounds like the revision hasn't been written to OTP at the factory. See viewtopic.php?f=43&t=160611
Ah ha! Yes. That's it.
Fri Mar 24, 2017 3:55 pm
Can you try adding
force_board_rev=0x9000c0
to the /boot/config.txt file?
Might help, might not.
See this github thread..
https://github.com/raspberrypi/firmware/issues/758
Laen
Tue Apr 04, 2017 10:54 pm
Adding "force_board_rev=0x9000c0" to the config.txt file resulting in a non-booting system.
Is flashing the OTP something I can do on my own, or should I return these units to my vendor?
Wed Apr 05, 2017 9:19 am
It needs to be RMA'd. Looks like a badly programmed device.
wesleyfurr
Mon Jul 24, 2017 1:34 am
Just a quick note to anyone else who runs into this...I've got a Zero W that does the same thing. The symptom I first noticed was that the power/activity LED did not light up. Second was that wifi would not work and wlan0 did not appear under ifconfig.
Forcing board to 0x9000c0 causes a blinking LED (four slow, four fast, repeat) and no boot.
Forcing it to the plain Zero board ID of 0x900093 makes the power LED work properly. I have not tested a camera to see if that works. Still no dice on the wireless, but at least it could be used as a plain Zero...and presumably the camera connector would work...
The Zero W I'm having trouble with was purchased at the St. Louis Microcenter store less than two weeks ago. Unfortunately, I live on the east coast...so it looks like I got a $10 Pi Zero...unless I can make it to the Washington DC area store within the return window...
johnlane
Tue Sep 19, 2017 10:32 am
For anyone else reading this thread after seeing the wrong hardware reported in `/proc/cpuinfo`, I saw this on a Zero and I believe it is due to the kernel version.
Kernel 4.4 reports BCM2708
$ cat /proc/cpuinfo
Hardware        : BCM2708
$ uname -a
Linux foo 4.4.48-2-ARCH #1 Mon Feb 13 19:53:47 MST 2017 armv6l GNU/Linux
Kernel 4.9 reports BCM2385
$ cat /proc/cpuinfo
Hardware        : BCM2385
$ uname -a
Linux bar 4.9.33-1-ARCH #1 SMP Sun Jun 18 02:10:01 UTC 2017 armv6l GNU/Linux
I tried two sdcards with different builds of ArchLinux on two different Pi Zeros.
I also tried the same two sdcards on an early (revision 2) model B with the same result. So it isn't a hardware nor zero-specific problem, but more of a a kernel problem.
Raspberry Pi Utilities: https://github.com/johnlane/rpi-utils
For Raspberry Pi and Arch Linux
Tue Sep 19, 2017 10:51 am
It's not a kernel problem, it's a choice by the upstream kernel developers to label ALL raspberries as BCM2835 devices. It's been in 4.9 kernels forever.
The software that uses that for device ID needs to change.
It's more reliable to parse the virtual file /sys/firmware/devicetree/base/model.
Martin Frezman
Tue Sep 19, 2017 11:06 am
Provided that file exists. On one of my machines, I get:
$  nl /sys/firmware/devicetree/base/model
nl: /sys/firmware/devicetree/base/model: No such file or directory
HawaiianPi
Sun Apr 29, 2018 1:54 am
Interesting. I wonder how many of these slipped through the cracks? It seems like this could be at least one cause for WiFi problems that a small number of people seem to be having. Mine shows the correct info.
~ $ cat /sys/firmware/devicetree/base/model;echo
Image Raspberry Pi Zero W Rev 1.1 Image
davidcoton
Sun Apr 29, 2018 11:02 am
:shock: That is so very wrong. It is not a Banana Pi. :roll:
Sun Apr 29, 2018 1:12 pm
It does happen occasionally, and each time it does the reports are fed back to the factory, in an effort to stop it happening.
