elkberry
[SOLVED] Pi0W: gadget mode: dwc2_hsotg_enqueue_setup: faile
Wed Mar 22, 2017 9:12 pm
I'm using the recent Raspbian image with support for the Raspberry Pi Zero W. It has wifi set up and connects to my home wireless LAN. So far, so good.
Next, I wanted to add USB ethernet gadget support. So I followed these instructions given here: https://gist.github.com/gbaman/975e2db1 ... e45e8fd40a ... the overlay gets activated, the drivers loaded.
After the Pi 0 W has booted, I see that it has loaded the g_ether from the list of loaded kernel modules. Unfortunately, neither my Linux system nor my Windows box recognizes the Pi0W when connecting it to these boxes using a normal A-microB cable. dmesg turns up with ugly thing here:
dwc2 20980000.usb: dwc2_hsotg_enqueue_setup: failed queue (-11)
I've searched the forum and googled around, but didn't find anything that helps me getting my Pi0W working as intended. Any help greatly appreciated -- I might have not searched correctly.
From ZX81 to Raspberry Pi, but wait ... where's the 7805 gone?
elkberry
Re: Pi0W: gadget mode: Ethernet: dwc2_hsotg_enqueue_setup: f
Wed Mar 22, 2017 9:34 pm
I've checked with a second Pi0W luckily I could get my hands on ... and guess: the other Pi0W works as advertised. Looks as if there are faulty batches in the pipeline. Grrr.
UPDATE: looks like there is now a driver fix (whatever), because previously non-working RPi0W's start to work for me. See below.
baseman101
Re: [SOLVED] Pi0W: gadget mode: dwc2_hsotg_enqueue_setup: fa
Thu Mar 23, 2017 4:03 am
I have the same problem - I guess I'll have to take a trip to Microcenter and get a new one :/.
grmpyninja
Fri Mar 31, 2017 11:07 am
Is it actually an official solution to this problem? Are you sure it's not because of some issues with the kernel?
I got the same issue in logs, but a single USB gadget always works. Checked HID, Mass Storage, Ethernet. However, when I try to configure two (or more) gadgets at the same time, it looks like only the first one is recognized.
Also I'm using libcomposition instead of older g_ether/g_hid and so on.
elkberry
Fri Mar 31, 2017 4:30 pm
No, if you read my post then you will notice that I tried the same physical mSD in two Pi Zero Ws. No, it's not a kernel issue at this time, there's no patch available. And no, I never wrote about a single USB ethernet adaptor attached using a OTG cable, but I mentioned USB Ether gadget mode. But then, everything boils down to what I wrote in the beginning.
A free replacement Pi Zero W is already on its way to me.
elkberry
Tue Apr 04, 2017 4:33 pm
Got my replacement RPi0W, which unfortunately is broken too: USB gadget mode does not work either! Cross-checked the same mSD in the working RPi0W: there, it works correctly. I've only now noticed that the good one also shows the error message in dmesg, so the presence of this error doesn't seem to be a clear indication. Good one works, can be ping'ed. Bad ones cannot be ping'ed and cannot ping.
elkberry
Tue Apr 04, 2017 5:42 pm
Recent raspbian update now fixes the RPi0W's that previously failed to work correctly in USB Ethernet gadget mode. With these updates I can now successfully ping and ssh into the problematic RPi0W by connecting it with a microB<->A cable to my Linux and Windows boxes.
So I stand corrected that it is now clear that this is a driver issue, and not a hardware issue (albeit you may still get a faulty unit, but this ain't a widespread issue).
