Hi all,
I just bought a new RPi Model3B for a project im working on. I have run into an issue, which I havnt found in any forum yet, either I am bad at searching, or I'm doing something terribly wrong.
To the problem: I used, (yes I followed the video-setup-tutorial step-by-step), an 8gig-microSD, on which I moved the contents of the noobs v2_3_0-archive (unziped n everything ofc). When I insert this micro-SD into my RPi and launch it, I get into the menu where you can select what OS to install. When I select the standard one (or the lite version from network-install, tried both), after the install-progress-screen its suddenly reboots, and I end up in the menu again, where I can select whatever system I want to install.
- I tested the booting with a preinstalled microSD from a friends 3B, and there I can boot and login, so tahts not a problem.
- The rapsberry Pi is new, so it should technically work.
- The same behaviour occured with my SD-card on my friends RPi-3B
- I have tried 2 different microSD cards, same behavior on both
If anyone has an Idea wehre the issue could be, or if anyone needs other information, I'm happy for any help that I can get.
Regards
Nyro
