Sir FICO
updated mosquitto not working
Sun Mar 19, 2017 4:09 pm
I had mosquitto running as a broker on my rpi. All was running just fine. A couple of hours ago to ensure I was up to date I did the apt-get update and apt-get dist-apdate stuff and it seems to update the mosquitto to 1.4.11.
Now the mosquitto service does not work. I can see a mosquitto service running (and i have rebooted since the update) but I get a Error: Connection refused message when I do a subscribe from a terminal window (i.e. $ mosquitto_sub -d -t hello/world)
When if I start mosquitto in the foreground in one terminal window and subscribe in another then all works OK (as does a publish in another terminal window.) When starting mosquitto from a terminal I get the following:
1489938989: Using default config.
1489938989: Opening ipv4 listen socket on port 1883.
1489938989: Opening ipv6 listen socket on port 1883.
However, when I look at the running mosquitto service (when the foreground process has not bee started) I see the following
$ ps -ef | grep mosquitto
pi 2890 783 0 16:04 pts/0 00:00:00 grep --color=auto mosquitto
and nothing about listening sockets etc.
So after the update something must have changed in the auto startup service of mosquitto I guess.
I'm a noob in all this stuff and wonder if anyone could give a suggestion as to what to look at.
Re: updated mosquitto not working
Sun Mar 19, 2017 4:20 pm
What's in your mosquitto config? My mosquitto 1.4.11 system runs with just
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
nothing else.
This is a doctor free zone.
Sir FICO
Sun Mar 19, 2017 4:27 pm
Hi Dougie,
my mosquitto.conf file is exactly as your example. I also checked the conf.d directory and that only contained a file called README which indicated that files in this directory would also be read on startup, but no other files are present.
Sun Mar 19, 2017 4:44 pm
Then it should come up and run on port 1883 by default.
What do you get from sudo netstat -tlnp | grep 1883?
Sir FICO
Sun Mar 19, 2017 5:06 pm
Hi Dougie
Well well, I though I would delete the mosquitto log file and reboot so as not to confuse the entries with the background and foreground services. On reboot the logfile showed
' 1489941227: mosquitto version 1.4.11 (build date Mon, 20 Feb 2017 22:47:27 +0000) starting '
and that was it.
Sometime later I then did your suggestion of sudo netstat -tlnp | grep 1883 and I got
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 424/mosquitto
tcp6 0 0 :::1883 :::* LISTEN 424/mosquitto
so that looked promising and a re-examination of the log then showed
1489941227: Config loaded from /etc/mosquitto/mosquitto.conf.
1489941227: Opening ipv4 listen socket on port 1883.
1489941227: Opening ipv6 listen socket on port 1883.
And mosquitto is working again - albeit after a very long 'starting' phase.
But my woes are not over yet. I see another service, the z-way-server service that connects to my raspberryZwave board is showing as a ? and whist I can log in to my local zwave web page I can no longer see the zwave devices.
Something horrible is going on, but I hav'nt a clue what it could be. I thank you kindly for your suggestions on the mosquitto stuff.
Sun Mar 19, 2017 5:14 pm
Look at logs /var/log/daemon.log /var/log/messages and /var/log/syslog
Try running your "Zwave" server from a command line.
Sir FICO
Sun Mar 19, 2017 5:46 pm
Thanks for the pointer to the logs directory, its now registered in my crib sheet for rpi. :D
The messages file shows
Mar 19 17:33:38 p2zwave kernel: [ 363.413371] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered.
So the rpi update did something. I was looking at some other internet posts on this and see this has cropped up in the past and I think this must have a bearing on the zwave board, but have not yet got a pointer on what to do to resolve this. Any noob type pointers would be gratefully received.
Sun Mar 19, 2017 5:55 pm
Ah, the 1-wire driver can be a fickle thing.
Take a look in /boot/overlays/README where there's lots of docs for w1-gpio.
