micksulley
Under Voltage Detection - Early Pi - Resolved
Fri Mar 17, 2017 7:39 pm
I used some code I found here - viewtopic.php?f=29&t=82373&hilit=under+ ... l&start=75
#!/usr/bin/python
#from https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=82373&hilit=under+voltage+via+terminal+terminal&start=75
import RPi.GPIO as GPIO , time
from subprocess import call
import shlex
import sys
import signal
def handler(signum, frame):
#   call(shlex.split("echo -ne '\e[u''\e[0m'"))
   sys.exit()
signal.signal(signal.SIGINT, handler)
redLED=35
GPIO.setmode(GPIO.BCM)
GPIO.setup(redLED, GPIO.IN)
powerlow=0
#call(shlex.split("echo -ne '\e[s'"))
while True:
   if(GPIO.input(redLED)==0):
      call(shlex.split("echo -ne '\e[s''\e[1;56H''\e[1;31m'POWER dipped below 4.63v'\e[u''\e[0m'"))
      powerlow += 1
   else:
      powerlow = 0
      call(shlex.split("echo -ne '\e[s''\e[1;78H''\e[1;31m'ON'\e[u''\e[0m'"))
   if (powerlow  > 3):
      break
   time.sleep(1)
#call(shlex.split("echo -ne '\e[u''\e[0m'"))
print "Low power for " + str(powerlow) + " seconds"
to detect under voltage. It works fine on my newer Pi's but I have just added a hard drive to an older one (UK board (c) 2011.12) and it detects under voltage (POWER dipped below 4.63v). I have a genuine 2.5A Pi supply, and when I measure the voltage it is 5.01 +/-0.02
Is there a problem using this code with an older Pi? If so is there some code that will work?
Re: Under Voltage Detection - Early Pi
Fri Mar 17, 2017 8:04 pm
The very early Pi had no voltage detection circuit. There is no code that will work on them. The earliest Pi that had that circuit was the A+/B+
micksulley
Fri Mar 17, 2017 8:32 pm
Thanks for the reply. Out of interest how can I tell which model it is? cpuinfo has this-
processor	: 0
model name	: ARMv6-compatible processor rev 7 (v6l)
BogoMIPS	: 697.95
Features	: half thumb fastmult vfp edsp java tls
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 000e
Serial		: 0000000026047082
Fri Mar 17, 2017 8:39 pm
Easiest is cat /sys/firmware/devicetree/base/model which tells you in nice words rather than the strange arcane coded value from cat /proc/cpuinfo.
This is a doctor free zone.
Fri Mar 17, 2017 8:43 pm
You can look on here for some models http://www.raspberrypi-spy.co.uk/2012/0 ... d-version/
Your 000e revision says that it is a Raspberry Pi B rev 2 with 512MB RAM, which came before the B+.
You can also get the version with this command
cat /sys/firmware/devicetree/base/model;echo
Fri Mar 17, 2017 8:47 pm
micksulley wrote:Thanks for the reply. Out of interest how can I tell which model it is? cpuinfo has this-
processor	: 0
BogoMIPS	: 697.95
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xb76
CPU revision	: 7
Hardware	: BCM2708
Revision	: 000e
000e model B 512MB
http://elinux.org/RPi_HardwareHistory
Retired disgracefully.....
......to a more gentile life !
micksulley
Fri Mar 17, 2017 11:06 pm
Just in case anyone else is interested I have modified the code to check the revision and exit if it does not have the capability to detect voltage, based on revision must be more than hex 000f
#!/usr/bin/python
#based on code from https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=82373&hilit=under+voltage+via+terminal+terminal&start=75
import shlex
import sys
import signal
# Voltage detection only available after revision code 000f
rev = ''
searchfile = open('/proc/cpuinfo', "r")
for line in searchfile:
    if "Revision" in line:
        rev = line.split(':')[1]
searchfile.close()
if int(rev,  base = 16) < 16:
    print 'Voltage detection not available on this model'
    exit()
   sys.exit()
redLED=35
powerlow=0
while True:
      powerlow += 1
   else:
      powerlow = 0
   if (powerlow  > 3):
      break
   time.sleep(1)
Thanks for your help
Mick
