bholland84
Cannot ping or ssh over WiFi
Tue Mar 14, 2017 3:56 am
The subject says it all. I booted up my pi using the vanilla SD card that came with the pi, attempted to ssh into it over wifi, it didn't work. I tried to ping it. That didn't work. I plugged it into my router, both work.
When it isn't plugged into the router, I can access anything online, including the apt-get raspbian repos.
Is there something wrong with the default sshd configuration? I find it a bit strange that I can't even ping the device out of the box but the device has internet.
And yes, I googled this and didn't find an answer that worked.
Thanks!
~Ben
Re: Cannot ping or ssh over WiFi
Tue Mar 14, 2017 10:56 am
bholland84 wrote:The subject says it all. I booted up my pi using the vanilla SD card that came with the pi, attempted to ssh into it over wifi, it didn't work. I tried to ping it. That didn't work. I plugged it into my router, both work.
Thanks!
~Ben
Raspbian Jessie SSH is disabled by default:
https://www.raspberrypi.org/blog/a-secu ... bian-pixel
adeguntoro
Tue Mar 14, 2017 2:18 pm
you need to enable via raspi-config, so it mean you must boot into raspi with monitor..
Tue Mar 14, 2017 2:45 pm
adeguntoro wrote:you need to enable via raspi-config, so it mean you must boot into raspi with monitor..
Poppycock, do not need to attach a Monitor, please read the link I posted, especially:
. If you want to enable SSH, all you need to do is to put a file called ssh in the /boot/ directory.
adeguntoro
Wed Mar 15, 2017 9:19 am
seriuosly ??all the time i always attach a monitor just for enable SSH, nice info :D
Khackee
Fri Mar 17, 2017 6:25 pm
I had the exact same issue. I checked to make sure SSH was enabled and it was.. My problem was on my apple airport router. When I set it up, I created 2 logins, one for my equipment (password protected), and one for my visiting family members.
My rpi was connected to my guest account, and once i switched it to the main router login, my issue was resolved.. Just thought I would share my noobie mistake.
