[RPi 3] Wifi connected but only occasional internet
Posted: Fri Mar 10, 2017 12:02 pm
A couple days ago I received my Raspberry Pi 3 on which I installed Raspbian. Ethernet works well, but I'd like to use Wifi as unfortunately my university network is limited to 40 GB a month. On the university network 'eduroam' I have no data limitations.
After setting up the wpa-supplicant file with the required info I can connect just fine. However, though being connected, I often do not have internet access. Chromium reports 'Name resolution failed', but I'm pretty sure it has nothing to do with DNS as I can't even connect to IP addresses (e.g. my server).
I've tried turning off power management on the on-board wifi as this caused problems in the past for many here, but to no avail. Someone asked a similar question and got asked to post the output of a bunch of stuff, so here it is:
Internet working:
I will post the same output once it stops working once again. Here are my WPA supplicant and interfaces files, in case that sheds any light:
I changed 'iface wlan0 inet dhcp' to 'iface wlan0 inet manual' later on, but the result is the same. The tunnel file refers to a reverse ssh tunnel I use to SSH into my RPi from outside the network (and also inside as I can't connect to other internal IP's).
I'm also not sure if this matters, but I noticed that sometimes 'hostname -I' shows one IP address, and sometimes two. Now it's working it shows one, but it also worked before with two, so not entirely sure what that means.
Here are the results of iwconfig, ifconfig and 'route -n':
I read somewhere that it could be that the gateway is not working properly, but although sometimes there are three entries (usually the first one twice), there is no consistency between working/not working.
Any help would be much appreciated!
Internet working:
pi@raspberrypi:~ $ ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:02:08:bf brd ff:ff:ff:ff:ff:ff
inet6 fe80::6538:ceac:3e0a:12d7/64 scope link tentative
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:57:5d:ea brd ff:ff:ff:ff:ff:ff
inet 10.46.151.110/17 brd 10.46.255.255 scope global wlan0
inet6 fe80::4a12:48bd:5635:feb7/64 scope link
valid_lft forever preferred_lft foreverCode: Select all
pi@raspberrypi:~ $ ip route
default via 10.46.255.254 dev wlan0 metric 303
10.46.128.0/17 dev wlan0 proto kernel scope link src 10.46.151.110 metric 303Code: Select all
pi@raspberrypi:~ $ sudo ping -c3 $(ip route | awk '/default/ {print $3})
pi@raspberrypi:~ $ sudo ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=44 time=15.3 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=44 time=14.7 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=44 time=15.5 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 14.710/15.204/15.545/0.371 msCode: Select all
pi@raspberrypi:~ $ sudo ping -c3 google.com
PING google.com (172.217.17.142) 56(84) bytes of data.
64 bytes from ams15s30-in-f14.1e100.net (172.217.17.142): icmp_seq=1 ttl=54 time=9.89 ms
64 bytes from ams15s30-in-f14.1e100.net (172.217.17.142): icmp_seq=2 ttl=54 time=11.1 ms
64 bytes from ams15s30-in-f14.1e100.net (172.217.17.142): icmp_seq=3 ttl=54 time=11.8 ms
--- google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 9.896/10.968/11.891/0.830 msCode: Select all
pi@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
domain *****************
nameserver 134.58.126.3
nameserver 134.58.127.1Code: Select all
update_config=1
country=BE
network={
ssid="eduroam"
key_mgmt=WPA-EAP
pairwise=CCMP
group=CCMP TKIP
eap=PEAP
ca_cert="/home/pi/.cat_installer/ca.pem"
identity="****"
domain_suffix_match="****"
phase2="auth=MSCHAPV2"
password="****"
scan_ssid=1
}Code: Select all
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
pre-up wpa_supplicant -B -Dwext -i wlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
post-up /home/pi/tunnel
post-down killall -q wpa_supplicantI'm also not sure if this matters, but I noticed that sometimes 'hostname -I' shows one IP address, and sometimes two. Now it's working it shows one, but it also worked before with two, so not entirely sure what that means.
pi@raspberrypi:~ $ hostname -I
10.46.151.110Code: Select all
pi@raspberrypi:~ $ iwconfig
wlan0 IEEE 802.11bgn ESSID:"eduroam"
Mode:Managed Frequency:2.462 GHz Access Point: 5C:83:8F:F2:F3:C0
Bit Rate=72.2 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=61/70 Signal level=-49 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:59 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
eth0 no wireless extensions.Code: Select all
pi@raspberrypi:~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:02:08:bf
inet6 addr: fe80::6538:ceac:3e0a:12d7/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:9860 errors:0 dropped:0 overruns:0 frame:0
TX packets:9860 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1192125 (1.1 MiB) TX bytes:1192125 (1.1 MiB)
wlan0 Link encap:Ethernet HWaddr b8:27:eb:57:5d:ea
inet addr:10.46.151.110 Bcast:10.46.255.255 Mask:255.255.128.0
inet6 addr: fe80::4a12:48bd:5635:feb7/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:33462 errors:0 dropped:5571 overruns:0 frame:0
TX packets:4076 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4645220 (4.4 MiB) TX bytes:985611 (962.5 KiB)Code: Select all
pi@raspberrypi:~ $ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 10.46.255.254 0.0.0.0 UG 303 0 0 wlan0
10.46.128.0 0.0.0.0 255.255.128.0 U 303 0 0 wlan0Any help would be much appreciated!
