Minecraft Pi through VNC black screen problem
Posted: Mon Mar 06, 2017 9:42 pm
by Vairetz
Hi guys, I configured vnc on my Raspberry Pi and all work perfectly except Minecraft. When I start the game all that I see is a black sreen but if I connect raspberry pi to a monitor with HDMI Minecraft works perfectly. How can I solve the problem?
Re: Minecraft Pi through VNC black screen problem
Posted: Mon Mar 06, 2017 10:58 pm
by sconemad
Hi, assuming you're using the RealVNC software that comes installed by default with Raspbian, you need to go to the vnc options > troubleshooting and enable experimental direct capture mode. That allows you to see Minecraft and other directly rendered content.
Posted: Mon Mar 06, 2017 11:49 pm
by fruitoftheloom
Vairetz wrote:Hi guys, I configured vnc on my Raspberry Pi and all work perfectly except Minecraft. When I start the game all that I see is a black sreen but if I connect raspberry pi to a monitor with HDMI Minecraft works perfectly. How can I solve the problem?
RealVNC recently had an updated release:
https://www.raspberrypi.org/blog/get-ba ... nc-connect
Posted: Tue Mar 07, 2017 5:43 pm
by Vairetz
Yes I'm using RealVNC and now I enable the troubleshooting option and now it works! Thank you very much, you can also tell me what option modify to get better the streaming quality?
