Audiotek
Can't Change /etc/network/interfaces file
Mon Mar 06, 2017 4:45 am
I'm trying to change the config on /etc/network/interfaces using nano but no matter what I do it doesn't save the file when I reboot. It's on a Raspberry Pi 2 using Screenly OSE and I need the Pi to go on DHCP All I have in the file is
generated by Screenly Network Manager
auto lo
iface lo inet loopback
I tried to change the loopback to dhcp with the following code
iface eth0 inet dhcp
CTRL+X , Y, ENTER
and reboot
ifconfig I get the old DHCP address when I did the initial setup weeks ago. The Pi doesn't seem to be able to get a new dhcp lease and not sure why the old IP address keep showing up and no matter what I change on the /etc/network/interfaces it doesn't save it
What could be wrong?
Re: Can't Change /etc/network/interfaces file
Mon Mar 06, 2017 7:56 am
If things are not getting stored on your SDCard you're either a) exiting the editor incorrectly (try using sudo leafpad in an LXTerminal window), b) you're not using sudo when you need to edit a system file or c) worst case your SDCard has reached end-of-life and has switched to read-only mode.
drgeoff
Mon Mar 06, 2017 9:48 am
You need to have root privilege to edit that file.
sudo nano /etc/network/interfaces
Quis custodiet ipsos custodes?
Audiotek
Mon Mar 06, 2017 7:55 pm
Hi Thanks for the reply! I forgot to mention I use sudo otherwise I get a permission denied error.
Also I can see # of lines written so it sees the lines but can't seem to save.
I installed the whole thing on a different micro SD card and I get the same default settings
auto lo
And that's it nothing else.
With ifconfig I get a dhcp address
Isn't loopback supposed to be 127.0.0.1?
What is the loopback used in that circumstance?
And what should I be seeing when on dhcp when editing /etc/network/interfaces ?
Mon Mar 06, 2017 9:33 pm
Why are you trying to change the interfaces file? Read the first few lines with ahead -6 /etc/network/interfaces command.
pi@viking /mnt $ head -6 /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
pi@viking /mnt $
Audiotek
Mon Mar 06, 2017 9:57 pm
I'd like to know why I get local loopback
Shouldn't I get something like this in the /etc/network/interfaces file?
auto eth0
rpdom
Mon Mar 06, 2017 10:11 pm
Audiotek wrote:I'd like to know why I get local loopback
What do you mean? You always have a lo loopback interface. Things will break if you don't.
auto eth0
Your /etc/network/interfaces should look like this
source-directory /etc/network/interfaces.d
auto lo
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
Mon Mar 06, 2017 10:12 pm
/etc/network/interfaces on Raspbian Jessie should look like
auto lo
allow-hotplug wlan0
allow-hotplug wlan1
DO NOT change it.
