Pi0W and bluetooth speaker ?
Posted: Fri Mar 03, 2017 1:55 pm
by gordon77
How do you get audio out of a BT speaker ?
It appears to pair but then says goto the audio menu. The only menu I can find is the audio device menu, under preferences, which has nothing about BT.
Do I need to install blueman ?
Re: Pi0W and bluetooth speaker ?
Posted: Fri Mar 03, 2017 2:44 pm
by gregeric
No need for extra software, save a fresh dist-upgrade today with a fix for BT speaker.
Once you've paired it, right click on the taskbar's speaker icon & select your BT audio.
If using omxplayer, use -o alsa to get sound over BT.
Posted: Fri Mar 03, 2017 3:51 pm
by gordon77
Thanks.
All appears to connect now BUT I still can't get any audio from it.
Trying omxplayer - o alsa /home/pi/python_games/match4.wav
alsamixer shows PulseAudio as the card
Posted: Sat Mar 04, 2017 4:02 pm
by gordon77
Anyone have any ideas on this ?
The BT speaker is connected and selected.
It doesn't show as a card in aplay -l.
Posted: Sat Mar 04, 2017 4:08 pm
by PiGraham
gregeric wrote:No need for extra software, save a fresh dist-upgrade today with a fix for BT speaker.
Worked for me, Had just done update/upgrade.
I made BT discoverable then add device found BT speaker and I could pair with it. Not sure discoverable is relevant, but first try at add didn't list any devices.
Once paired the BT speaker was listed on speaker right-click menu along with analog and HDMI.
Sound then came out of the speaker. I tried a Python game. 5-block Tetris.
Posted: Sat Mar 04, 2017 4:11 pm
by gordon77
Thanks.
I did the update/upgrade and it found the speaker same as you but no luck with any sound.
What BT speaker have you ?
UPDATE !! sounds works with Tetromino.py from python_games !! :D
More testing required with omxplayer.
Posted: Sat Mar 04, 2017 4:20 pm
by PiGraham
gordon77 wrote:Thanks.
I didn't try omxplayer. My speaker is a small cube speaker from Sainsbury's.
Posted: Sat Mar 04, 2017 5:10 pm
by gordon77
Cheers.
Sadly sound didn't last long, now won't play anything again, and nothing has been changed :roll:
It's a Jam Plus
Posted: Sun Mar 05, 2017 4:15 pm
by gordon77
I can get sound from the BT speaker with:
paplay (WAVs)
speaker-test (tone)
but NOT...
omxplayer
mpg123
pygame.mixer
any thoughts ?
does this show anything ?
[email protected]:~ $ pacmd list-cards
1 card(s) available.
    index: 0
	driver: <module-bluez5-device.c>
	owner module: 24
	properties:
		device.description = "Jam Plus"
		device.string = "F0:13:C3:14:DE:59"
		device.api = "bluez"
		device.class = "sound"
		device.bus = "bluetooth"
		bluez.path = "/org/bluez/hci0/dev_F0_13_C3_14_DE_59"
		bluez.class = "0x040400"
		bluez.alias = "Jam Plus"
		device.icon_name = "audio-card-bluetooth"
	profiles:
		a2dp: High Fidelity Playback (A2DP Sink) (priority 10, available: unknown)
		off: Off (priority 0, available: yes)
	active profile: <a2dp>
	sinks:
		bluez_sink.F0_13_C3_14_DE_59/#1: Jam Plus
	sources:
		bluez_sink.F0_13_C3_14_DE_59.monitor/#1: Monitor of Jam Plus
	ports:
		unknown-output: Bluetooth Output (priority 0, latency offset 0 usec, available: unknown)
			properties:
		unknown-input: Bluetooth Input (priority 0, latency offset 0 usec, available: no)
			properties:
Posted: Mon Mar 06, 2017 5:52 pm
by gordon77
Anyone else used a Jam Plus or recommend a BT speaker that works?
Posted: Mon Mar 06, 2017 6:27 pm
by gregeric
I'm using this http://www.ebay.co.uk/itm/2x3W-Bluetoot ... SwB09YSwQx. No plug is supplied to fit the onboard speaker socket, but I got lucky in that the speakers I salvaged from Samsung LED TVs have a connector which fits, & is wired appropriately.
Posted: Mon Mar 06, 2017 7:52 pm
by recklessfb
How's the bluetooth speaker on the new pizero? Is the connection stable?
I was never able to get a stable connection on the pi 3. I eneded up disabling the onboard bluetooth and using a bt dongle.
Posted: Mon Mar 06, 2017 8:53 pm
by gordon77
recklessfb wrote:How's the bluetooth speaker on the new pizero? Is the connection stable?
Mines stable just no sound with some programmes!
Posted: Fri Mar 24, 2017 10:26 am
by gordon77
I have now tried a different BT speaker, a Juice Sound Square, and same result :(
paplay and speaker-test work but not omxplayer, so I can't play MP3s, anybody got an answer ?
Posted: Fri Mar 24, 2017 11:49 am
by Douglas6
It used to be that omxplayer output directly to the hardware, so no chance for Bluetooth. The newer version has an '-o alsa' flag. Not sure if the new one is in the repo yet, but you can get it on github. Also not sure if it works with Bluetooth, but it's worth a try (I obviously haven't).
Or use mpg321 for .mp3s.
SOLVED - Pi0W and bluetooth speaker ?
Posted: Fri Mar 24, 2017 12:26 pm
by gordon77
Cheers. I've got it playing MP3s now :D
I was testing with a .WAV not a MP3 with omxplayer, it plays MP3s but not WAVs, which will do me.
I used omxplayer -o alsa xxx.mp3
Gordon
Posted: Fri Mar 24, 2017 2:26 pm
by gordon77
I am trying to play MP3s from python using omxplayer as a subprocess
If I enter the following in terminal it plays
omxplayer -o alsa Music/'Athlete'/'Black Swan'/'01 Superhuman Touch.mp3'
if I use the following python it won't play but the response shown in terminal looks identical as if it is playing..
rpistr = "omxplayer -o alsa Music/'Athlete'/'Black Swan'/'01 Superhuman Touch.mp3'"
p = subprocess.Popen(rpistr, shell=True, preexec_fn=os.setsid)
response in terminal...
Audio codec mp3 channels 2 samplerate 44100 bitspersample 16
Subtitle count: 0, state: off, index: 1, delay: 0
any ideas why ?
Posted: Fri Mar 24, 2017 2:38 pm
by Douglas6
Just a guess, but you might have better luck passing Popen a list, like
p = subprocess.Popen(rpistr.split(), shell=True, preexec_fn=os.setsid)
Posted: Fri Mar 24, 2017 2:46 pm
by gordon77
Thanks Douglas6,
If I do that omxplayer just gives me the help screen, clearly doesn't like it.
It appears to be taking my command OK but ignoring the -o alsa ?
Posted: Fri Mar 24, 2017 3:07 pm
by Douglas6
OK, I think the spaces in the file names are messing with things. What about
rpistr = ["omxplayer", "-o", "alsa",  "Music/'Athlete'/'Black Swan'/'01 Superhuman Touch.mp3'"]
And remove the split(), of course.
Sorry, I don't have a Pi setup to test with.
Posted: Fri Mar 24, 2017 3:21 pm
by gordon77
No luck , just the help screen again...
Posted: Sat Mar 25, 2017 1:37 pm
by gordon77
It's baffling, when l use the above code omxplayer seems to acknowledge the -o alsa, and it finds the mp3 and appears to be playing it but it doesn't play it through the BT.
Posted: Sun Mar 26, 2017 11:13 am
by gordon77
Douglas6 wrote:It used to be that omxplayer output directly to the hardware, so no chance for Bluetooth. The newer version has an '-o alsa' flag. Not sure if the new one is in the repo yet, but you can get it on github. Also not sure if it works with Bluetooth, but it's worth a try (I obviously haven't).
Tried mpg321, same issue plays OK from terminal BUT won't play to BT as python subprocess. Appears to be playing but not to BT.
Posted: Wed Mar 29, 2017 2:57 am
by gordon77
Anyone got omxplayer or mpg321 to work with bluetooth as a python subprocess?
