gregeric
Pixel Menu Bar disappearing after today's apt-get upgrade
Wed Mar 01, 2017 4:59 pm
Pi Zero 1.3, CSR4.0 BT dongle, external BT speaker. Old habit, did an upgrade instead of the recommended dist-upgrade to my Raspbian-Pixel installation.
Now, I'm at: Linux pixelzero 4.4.48+ #964 Mon Feb 13 16:50:25 GMT 2017 armv6l GNU/Linux
After several connects/disconnects to the speaker, the menu bar disappears. I'm assuming it's down to the upgrade, and not something else I've fubar'd.
Here's the end of the LXDE log showing the behaviour:
** Message: bt: Name org.bluez owned on DBus
** Message: bt: New agent manager found
** Message: bt: New adapter found
** Message: va: Name org.bluez owned on DBus
** Message: va: Starting PulseAudio
** Message: va: Connecting to /org/bluez/hci0/dev_06_6C_FB_77_E9_46...
** Message: bt: Object manager - object at /org/bluez/hci0 property changed - org.bluez.Adapter1 {'Class': <uint32 524288>}
** Message: bt: Object manager - object at /org/bluez/hci0 property changed - org.bluez.Adapter1 {'UUIDs': <['00001200-0000-1000-8000-00805f9b34fb', '00001800-0000-1000-8000-00805f9b34fb', '00001801-0000-1000-8000-00805f9b34fb', '0000110e-0000-1000-8000-00805f9b34fb', '0000110c-0000-1000-8000-00805f9b34fb', '0000110a-0000-1000-8000-00805f9b34fb', '0000110b-0000-1000-8000-00805f9b34fb']>}
** Message: bt: Object manager - object at /org/bluez/hci0 property changed - org.bluez.Adapter1 {'Class': <uint32 786432>}
** Message: va: Trusted OK
** Message: bt: Object manager - object at /org/bluez/hci0/dev_06_6C_FB_77_E9_46 property changed - org.bluez.Device1 {'Connected': <true>}
** Message: bt: Object manager - object added at path /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd1
** Message: va: Connected OK
(lxpanel:1103): Gtk-CRITICAL **: IA__gtk_menu_popdown: assertion 'GTK_IS_MENU (menu)' failed
** Message: bt: Object manager - object at /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd1 property changed - org.bluez.MediaTransport1 {'State': <'active'>}
** Message: bt: Object manager - object at /org/bluez/hci0/dev_06_6C_FB_77_E9_46 property changed - org.bluez.MediaControl1 {'Connected': <true>}
(lxpanel:1103): GLib-CRITICAL **: g_variant_get_string: assertion 'value != NULL' failed
** Message: app.vala:130: lxpanel exit with this type of exit: 11
** Message: app.vala:148: Exit not normal, try to reload
** Message: app.vala:76: Launching lxpanel
** Message: x-terminal-emulator has very limited support, consider choose another terminal
** Message: Connecting ...
** Message: Status changed to down
** Message: Status changed to opened
** Message: Connected to dhcpcd-6.7.1
** Message: Status changed to connected
** Message: wlan0: Associated with Heaton Mill
** Message: wlan0: Configured 192.168.11.58/24
** Message: wlan0: WPA status connected
** Message: wlan0: Received scan results
** Message: bt: Object manager - object at /org/bluez/hci0 property changed - org.bluez.Adapter1 {'UUIDs': <['00001200-0000-1000-8000-00805f9b34fb', '00001800-0000-1000-8000-00805f9b34fb', '00001801-0000-1000-8000-00805f9b34fb', '0000110e-0000-1000-8000-00805f9b34fb', '0000110c-0000-1000-8000-00805f9b34fb', '0000110a-0000-1000-8000-00805f9b34fb']>}
** Message: bt: Object manager - object added at path /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd2
(lxpanel:1172): Gtk-CRITICAL **: IA__gtk_menu_popdown: assertion 'GTK_IS_MENU (menu)' failed
** Message: bt: Object manager - object at /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd2 property changed - org.bluez.MediaTransport1 {'State': <'active'>}
(lxpanel:1172): GLib-CRITICAL **: g_variant_get_string: assertion 'value != NULL' failed
** Message: bt: Object manager - object added at path /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd3
(lxpanel:1254): Gtk-CRITICAL **: IA__gtk_menu_popdown: assertion 'GTK_IS_MENU (menu)' failed
** Message: bt: Object manager - object at /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd3 property changed - org.bluez.MediaTransport1 {'State': <'active'>}
(lxpanel:1254): GLib-CRITICAL **: g_variant_get_string: assertion 'value != NULL' failed
** Message: bt: Object manager - object added at path /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd4
(lxpanel:1327): Gtk-CRITICAL **: IA__gtk_menu_popdown: assertion 'GTK_IS_MENU (menu)' failed
** Message: bt: Object manager - object at /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd4 property changed - org.bluez.MediaTransport1 {'State': <'active'>}
(lxpanel:1327): GLib-CRITICAL **: g_variant_get_string: assertion 'value != NULL' failed
** Message: bt: Object manager - object added at path /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd5
(lxpanel:1400): Gtk-CRITICAL **: IA__gtk_menu_popdown: assertion 'GTK_IS_MENU (menu)' failed
** Message: bt: Object manager - object at /org/bluez/hci0/dev_06_6C_FB_77_E9_46/fd5 property changed - org.bluez.MediaTransport1 {'State': <'active'>}
(lxpanel:1400): GLib-CRITICAL **: g_variant_get_string: assertion 'value != NULL' failed
** Message: app.vala:156: Application crashed too much, stop reloading
Anyone else with a similar setup seeing the same after updating today?
paulrho
Re: Pixel Menu Bar disappearing after today's apt-get upgrad
Thu Mar 02, 2017 7:32 am
Did an update last night (do this every few weeks) - and I get the same problem. The launching panel is gone, after a few flickers within a few minutes.
(login/logout or reboot restores of course)
Same errors.
spl23
Thu Mar 02, 2017 5:22 pm
Apologies - I've just found the bug that is causing this; we'll get a fix out asap.
Thanks for letting us know.
startrek.steve
Fri Mar 03, 2017 8:19 am
Just installed Raspbian/Pixel on my new Zero W and its doing the same thing on here.
If you disconnect from Bluetooth it comes back.
Strangely my Pi 3 has the same setup and doesnt lose the taskbar?
Steve
Pi 2 running LibreElec Krypton, Pi 2 running Wheezy Desktop, Pi 1 headless Wheezy, downloading Radio, Pi 1 running Picore headless Media Server, Pi Zero to be an Old Time Radio Project. Pi 3 testing. Pi Zero W downloading Radio shows headless.
paulrho
Fri Mar 03, 2017 8:25 am
Updated again. lxpanel was in the list. Looking good! No crashing, the pixel menu bar is still there after 10 minutes, no similar errors showing up in /home/pi/.cache/lxsession/LXDE-pi/run.log
Fantastic stuff! Thanks spl23!
Paul S.
paulrho
Fri Mar 03, 2017 8:35 am
Relevant packages that just got an update (that now works!)
lxpanel-data:armhf (0.7.2-1+rpi18, 0.7.2-1+rpi19),
Full update log:
Start-Date: 2017-03-03 18:07:14
Commandline: apt-get upgrade
Upgrade: libmagickcore-6.q16-2-extra:armhf (6.8.9.9-5+deb8u6, 6.8.9.9-5+deb8u7), raspberrypi-ui-mods:armhf (1.20161206, 1.20170301), raspberrypi-sys-mods:armhf (20170127, 20170302), lxpanel-data:armhf (0.7.2-1+rpi18, 0.7.2-1+rpi19), libmagickcore-6.q16-2:armhf (6.8.9.9-5+deb8u6, 6.8.9.9-5+deb8u7), imagemagick-6.q16:armhf (6.8.9.9-5+deb8u6, 6.8.9.9-5+deb8u7), libmagickwand-6.q16-2:armhf (6.8.9.9-5+deb8u6, 6.8.9.9-5+deb8u7), lxpanel:armhf (0.7.2-1+rpi18, 0.7.2-1+rpi19), imagemagick-common:armhf (6.8.9.9-5+deb8u6, 6.8.9.9-5+deb8u7), imagemagick:armhf (6.8.9.9-5+deb8u6, 6.8.9.9-5+deb8u7)
End-Date: 2017-03-03 18:07:44
spl23
Sat Mar 04, 2017 1:06 pm
FYI, the fix is in lxpanel; specifically in the Bluetooth plugin. I'd recently added some code to force lxkeymap to reload when a Bluetooth keyboard reconnects, and while it worked perfectly in that instance, it caused a segfault due to a compare on a null string when an audio device reconnects...
aquilablu
Sat May 20, 2017 9:04 am
Good morning everybody, on a Pi2 with latest NOOBS (I downloaded it few days ago) I have the same problem: taskbar is blank / empty / missing just after startup. If I re-install the operating system the taskbar appears, but after some reboots (I don't know if one or more) the taskbar is blank and a window on the screen says 'Plumouth has been updated...' (but I didn't issue any sudo apt-get update command)
aquilablu
Sat May 27, 2017 5:50 pm
Hi everybody, I think I found a workaround to the problem of taskbar empty / blank / missing. I read in this thread about the bluetooth plugin, so I removed it. The problem didn't appeared again, till now. I know this is not the solution to the problem (I don't use bluetooth, but others maybe need it) but it can be usefull to temporary solve the issue. This is the package I removed:
pi-bluetooth - Raspberry Pi 3 bluetooth
Bye
aquilablu
aquilablu
Thu Jun 01, 2017 10:27 pm
Good evening everybody, I'm sorry but my workaround doesn't fix the problem. The taskbar became empty this afternoon once again, and I just reinstalled the operating system.
So I wait for a better idea to solve the problem.
Cheerio.
ShiftPlusOne
Thu Jun 08, 2017 11:04 am
It doesn't sounds like you're having the same problem. Might be worth starting a new topic with more details.
