I received a Pi Zero a few days ago and mine won't show anything on the display.
I've plugged the bare board into my Win7 laptop and it bings. It is in the device manager in other devices. It says it couldn't find a driver. I've tried to update the driver but it comes back with "Windows could not find driver software for your device"
I downloaded the latest NOOBs, Raspbian and Jessie Lite but none of them bring the HDMI to life.
I have an original Pi and a Pi3. All the cards I have built work in the Pi3.
So far I have tried the OS's above on two different SD Cards, and I have tried other SD Cards. One with an updated version of Raspbian and one with the Zero's version of RetroPi. In all cases the screen comes shows "No Video Available"
I've never seen the ACT LED when it is flashing an error code so I have nothing to gauge it by but the Zero appears to be booting. The ACT LED is active for 20 - 30 seconds then flicks on and off at irregular intervals. I have a mouse with a speed adjuster on it if I press the button the indicator LEDs light up. The NUM lock and Caps lock on the keyboard work too. There is just nothing to see.
I put the NOOBs card I had built into the Pi3 and ran the various commands to get the monitor info. I have tried all I can think of in the Config.txt to bring it to life but so far nothing. I have also tried the Zero with three different HDMI leads on three TV's and two computer monitors. All failed to give me a display
I don't have another Zero to test the HDMI converter with, so I bought a cable with a standard HDMI on one end and a mini connector on the other but still nothing.
Basically the only thing I can't test is the HDMI on the Zero itself.
I'm getting wound up with myself for not being able to fix this
Any help appreciated.
Regards
Dave
