How to use USB Webcam on Scratch
Posted: Sat Feb 25, 2017 5:53 pm
Hi there,
Finally I found how to use my USB Webcam on Scratch in effective way for recording/playing sound and taking photos. Especially this is very nice in classroom or coder club. I have Raspberry Pi classes of 70 kids age from 9 to 13 to code to learn Scratch, Sonic Pi, Minecraft-Scratch, SunVox or others with GPIO tinkering.
You know, in this situation I have to be cost-sensitive, and to do things in easier and fun method.
Situation:
I would like to use the onboard audio jack to play sound thru, and would like to add an USB webcam, cheap and nice "UVC-compatible" or USB Video Class device to record sound, and of course, also take photos with. I have Logitech C-270 and C-310. The C-270 is cheaper and good enough.
Problem:
I always sadly see the message "Sound Recorder: unable to connect to input device " and no sound recording on Scratch.
Solution:
Survived form the deep forest of ALSA conf, I found the recipe. Only you have to do is to edit the file named ".asoundrc" at home directory or /home/pi/.asoundrc or ~/.asoundrc.
$ nano .asoundrc
Scratch sees only system default input and output device. You can set the onboard audio out as the default output (playback), and the mic in webcam as the default input (capture) device or "sound card" in the ALSA world with the magic words "type asym".
Hey! Now I can use the webcam as a recorder! Bonus:
Taking a photo as a new costume of a sprite:
You can use the webcam to take photos in Scratch. Just go to the Costume tab then you will find the [Camera] button! Taking photos in the script:
1. Start the GPIO server by [ broadcast ( gpioserveron ) ] block.
2. Take a photo by [ broadcast ( photo ) ] block. 3. The photo taken is stored as a new costume.
Enjoy!
naohiro
Situation:
Problem:
Solution:
$ nano .asoundrc
pcm.!default {
type asym
playback.pcm {
type hw
card 0
capture.pcm {
type hw
card 1
ctl.!default {
type hw
card 0
Enjoy!
naohiro
