accidently cancelled dd tool while installing image on SD
Posted: Thu Feb 23, 2017 3:40 pm
UPDATE: problem fixed
A small, affordable computer with free resources to help people learn, make things, and have fun
https://www.raspberrypi.org/forums/
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=175347
thank you it worked. i just had to remove the existing partition and create a new fat32 partition on the unassigned part and it worked again.DougieLawson wrote:Run gparted to remove everything from the card and start with a single FAT32 partition.
When that's done you should be able to run the dd from the beginning.
