wheelman_m5
Problem with hostapd and rsapberry pi running alfa AWUS036H
Sun Sep 16, 2012 1:57 am
Hi, I have been searching high and low for a solution to this problem to no avail.
Info: Raspberry pi model B, Raspbian "wheezy", Lexar 16gb SD 400x, Alfa AWUS036H Power by usb hub
I recently loaded raspbian wheezy onto my pi and got everything loaded and running just fine. I can even "iwlist scan" using my wifi dongle and it shows a bnch of nearby access points.
The problem I have is when i try to use hostapd:
I start with the minimal config:
interface=wlan0
driver=nl80211
ssid=test
channel=1
and get the following errors:
rfkill: Cannot open RFKILL control device
Failed to update rate sets in kernel module
Could not connect to kernel driver.
Using interface wlan0 with hwaddr 00:c0:ca:61:da:70 and ssid 'test'
Failed to set beacon parameters
Here is some more info:
lsusb
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 0bda:8187 Realtek Semiconductor Corp. RTL8187 Wireless Adapter
lsmod
Module Size Used by
8021q 19064 0
garp 6749 1 8021q
stp 2033 1 garp
llc 5726 2 stp,garp
snd_bcm2835 21505 0
snd_pcm 80650 1 snd_bcm2835
snd_seq 59372 0
snd_timer 21638 2 snd_seq,snd_pcm
snd_seq_device 6916 1 snd_seq
snd 57253 5 snd_seq_device,snd_timer,snd_seq,snd_pcm,snd_bcm2835
snd_page_alloc 5347 1 snd_pcm
arc4 1387 2
rtl8187 52177 0
mac80211 251866 1 rtl8187
cfg80211 180452 2 mac80211,rtl8187
eeprom_93cx6 1671 1 rtl8187
I also checked voltage at tp1/tp2=4.65volts
Any ideas on fixing this?
SirLagz
Re: Problem with hostapd and rsapberry pi running alfa AWUS0
Sun Sep 16, 2012 2:29 pm
whats
iw list
command output ?
wheelman_m5
Sun Sep 16, 2012 6:46 pm
Usage: iwlist [interface] scanning [essid NNN] [last]
[interface] frequency
[interface] channel
[interface] bitrate
[interface] rate
[interface] encryption
[interface] keys
[interface] power
[interface] txpower
[interface] retry
[interface] ap
[interface] accesspoints
[interface] peers
[interface] event
[interface] auth
[interface] wpakeys
[interface] genie
[interface] modulation
MmmPi
Sun Sep 16, 2012 11:11 pm
You left out a space in the command.
iw list
wheelman_m5
Mon Sep 17, 2012 12:47 am
Oh my bad, i thought you did that by accident. It doesn't work for me.
[email protected]:/etc/hostapd# iw list
bash: iw: command not found
SirLagz
Mon Sep 17, 2012 12:53 am
install iw and then try again
wheelman_m5
Mon Sep 17, 2012 12:57 am
here is the output of iw list
Wiphy phy0
Band 1:
Frequencies:
* 2412 MHz [1] (20.0 dBm)
* 2417 MHz [2] (20.0 dBm)
* 2422 MHz [3] (20.0 dBm)
* 2427 MHz [4] (20.0 dBm)
* 2432 MHz [5] (20.0 dBm)
* 2437 MHz [6] (20.0 dBm)
* 2442 MHz [7] (20.0 dBm)
* 2447 MHz [8] (20.0 dBm)
* 2452 MHz [9] (20.0 dBm)
* 2457 MHz [10] (20.0 dBm)
* 2462 MHz [11] (20.0 dBm)
* 2467 MHz [12] (20.0 dBm) (passive scanning, no IBSS)
* 2472 MHz [13] (20.0 dBm) (passive scanning, no IBSS)
* 2484 MHz [14] (20.0 dBm) (passive scanning, no IBSS)
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps
* 5.5 Mbps
* 11.0 Mbps
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
max # scan SSIDs: 4
max scan IEs length: 2285 bytes
Coverage class: 0 (up to 0m)
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP (00-0f-ac:4)
Available Antennas: TX 0 RX 0
Supported interface modes:
* managed
* monitor
software interface modes (can always be added):
* monitor
interface combinations are not supported
Supported commands:
* new_interface
* set_interface
* new_key
* new_beacon
* new_station
* new_mpath
* set_mesh_params
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* set_tx_bitrate_mask
* action
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* set_wds_peer
* connect
* disconnect
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0xd0
* managed: 0x40 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* mesh point: 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
Device supports RSN-IBSS.
SirLagz
Mon Sep 17, 2012 1:50 am
Don't think you'll be able to use hostapd with that USB device.
It doesn't support AP mode.
Unless it's the firmware / drivers that you are using that doesn't support AP mode.
Someone using a AWUS036EH has AP mode under their iw list though...
wheelman_m5
Mon Sep 17, 2012 5:45 am
Hey thanks for your help. I just swapped my AWUS036H for another Alfa wifi dongle I had lying around (AWUS036NH) and it works now.
BLL
Thu Apr 03, 2014 8:12 pm
My R-Pi has 2 wifi dongles attached. One is configured as an AP, the other connects to a hotspot. When I set this up last summer, it worked but only after moving the dongles around the hub sockets, so the one to be wlan0 and the one to be wlan1 were assigned correctly. Over the winter, presumably due to upgrades, 2 things have happened:
I found that the dongle which was supposed to be the AP now comes up as wlan0! Swapping them over in their sockets has put it right!! Any ideas on why this should happen?
Secondly, hostapd.conf has the line ieee80211n=1 to set wireless N. That worked fine until the change above. Now, unless I comment out that line, I get the message during boot up "Failed to update rate sets in kernel module" and iw list shows 54kBps as the highest bitrate (non HT) and yet this dongle was running as 802.11n before (Amiko).
Again, any ideas please.
