stbtyman
grep [a-zA-Z] only finds "r"
Thu Feb 16, 2017 9:39 pm
Wondering if anyone else has encountered this issue:
grep [a-zA-Z] filename
This sequence was working, but suddenly stopped (pi 3B). Now it only finds the "r" if the file contains the entire alphabet. All other grep usage seems to work fine and this usage still workes just fine on another ripi. Tried reinstalling grep and latest ripi updates. No change.
stbtyman
Re: grep [a-zA-Z] only finds "r"
Fri Feb 17, 2017 4:37 pm
Suspect file corruption, but lookg for ideas where to check. Otherwise, will be reinstalling Jessie image,php, nginx... (and creating a backup image this time :D
jahboater
Fri Feb 17, 2017 4:46 pm
stbtyman wrote:Wondering if anyone else has encountered this issue:
The pattern [a-zA-Z] will only match a single character. I also suggest quotes to avoid interference from the shell.
Try
grep '[a-zA-Z]*' filename
or something similar.
Paeryn
Fri Feb 17, 2017 4:57 pm
I'd suggest quoting the search string lest the shell interprets the brackets as part of filename expansion.
You could also try using :alpha: which is equivalent to A-Za-z
grep "[:alpha:]" filename
jahboater
Fri Feb 17, 2017 5:19 pm
You might need some extra brackets for that?
drawkula
Fri Feb 17, 2017 5:27 pm
(yeti@kumari:21)~/xyzzy$ ls -l
total 0
...no hats with hidden rabbits...
(yeti@kumari:21)~/xyzzy$ printf '%s\n' {a..e} > filename
(yeti@kumari:21)~/xyzzy$ cat filename
a
b
c
d
e
...no hidden PIgeons too...
(yeti@kumari:21)~/xyzzy$ grep [a-e] filename
a
b
c
d
e
...grepping test data behaves as expected...
(yeti@kumari:21)~/xyzzy$ touch c
c
Boom!
"[a-e]" now expands to "c" because a file named "c" exists.
You have a file named "r" in the directory where you do your "grep"?
