andig2
SSD via USB boot
Thu Feb 16, 2017 7:40 pm
I've followed https://www.raspberrypi.org/documentati ... des/msd.md for setting up USB boot without SSD for Transcend 32GB m.2 SSD via Renkforce adapter.
Unfortunately, after removing the SD card, the Pi3 doesn't come up and flashes green 4 times.
This is the "normal" dmesg output:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.9-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #963 SMP Fri Feb 10 18:14:48 GMT 2017
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 242432
[    0.000000] free_area_init_node: node 0, pgdat 80c6eb00, node_mem_map b9fab000
[    0.000000]   Normal zone: 2131 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 242432 pages, LIFO batch:31
[    0.000000] percpu: Embedded 14 pages/cpu @bb2b1000 s25600 r8192 d23552 u57344
[    0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 240301
[    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x97a9e880 smsc95xx.macaddr=B8:27:EB:A9:E8:80 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939344K/969728K available (7168K kernel code, 483K rwdata, 2000K rodata, 1024K init, 778K bss, 22192K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
    lowmem  : 0x80000000 - 0xbb300000   ( 947 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x80800000   (8160 kB)
      .init : 0x80b00000 - 0x80c00000   (1024 kB)
      .data : 0x80c00000 - 0x80c78cec   ( 484 kB)
       .bss : 0x80c7a000 - 0x80d3cb24   ( 779 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000026] Switching to timer-based delay loop, resolution 52ns
[    0.000323] Console: colour dummy device 80x30
[    0.001261] console [tty1] enabled
[    0.001308] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001377] pid_max: default: 32768 minimum: 301
[    0.001736] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001778] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002784] Disabling cpuset control group subsystem
[    0.002975] CPU: Testing write buffer coherency: ok
[    0.003046] ftrace: allocating 22321 entries in 66 pages
[    0.055391] CPU0: update cpu_capacity 1024
[    0.055458] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.055557] Setting up static identity map for 0x100000 - 0x100034
[    0.057791] CPU1: update cpu_capacity 1024
[    0.057799] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.058511] CPU2: update cpu_capacity 1024
[    0.058517] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.059185] CPU3: update cpu_capacity 1024
[    0.059192] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.059273] Brought up 4 CPUs
[    0.059447] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.059477] CPU: All CPU(s) started in HYP mode.
[    0.059503] CPU: Virtualization extensions available.
[    0.060318] devtmpfs: initialized
[    0.071264] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.071579] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.072099] pinctrl core: initialized pinctrl subsystem
[    0.073016] NET: Registered protocol family 16
[    0.075481] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.084647] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.084696] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.084876] Serial: AMBA PL011 UART driver
[    0.088075] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.088632] uart-pl011 3f201000.serial: could not find pctldev for node /soc/[email protected]/uart0_pins, deferring probe
[    0.156034] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[    0.158028] SCSI subsystem initialized
[    0.158209] usbcore: registered new interface driver usbfs
[    0.158311] usbcore: registered new interface driver hub
[    0.158428] usbcore: registered new device driver usb
[    0.164992] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-02-08 19:33
[    0.166605] clocksource: Switched to clocksource arch_sys_counter
[    0.213377] VFS: Disk quotas dquot_6.6.0
[    0.213486] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.213709] FS-Cache: Loaded
[    0.213972] CacheFiles: Loaded
[    0.226288] NET: Registered protocol family 2
[    0.227203] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.227340] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.227551] TCP: Hash tables configured (established 8192 bind 8192)
[    0.227663] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.227731] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.227976] NET: Registered protocol family 1
[    0.228396] RPC: Registered named UNIX socket transport module.
[    0.228429] RPC: Registered udp transport module.
[    0.228456] RPC: Registered tcp transport module.
[    0.228484] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.229644] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.230877] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.232059] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.248527] FS-Cache: Netfs 'nfs' registered for caching
[    0.249530] NFS: Registering the id_resolver key type
[    0.249581] Key type id_resolver registered
[    0.249609] Key type id_legacy registered
[    0.252038] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.252186] io scheduler noop registered
[    0.252216] io scheduler deadline registered (default)
[    0.252550] io scheduler cfq registered
[    0.257669] BCM2708FB: allocated DMA memory fa910000
[    0.257721] BCM2708FB: allocated DMA channel 0 @ bb80f000
[    0.268141] Console: switching to colour frame buffer device 82x26
[    0.276901] bcm2835-rng 3f104000.rng: hwrng registered
[    0.279268] vc-cma: Videocore CMA driver
[    0.281516] vc-cma: vc_cma_base      = 0x00000000
[    0.283841] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.286136] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.288562] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
[    0.308164] brd: module loaded
[    0.319190] loop: module loaded
[    0.321233] Loading iSCSI transport class v2.0-870.
[    0.323866] usbcore: registered new interface driver smsc95xx
[    0.325960] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.554161] Core Release: 2.80a
[    0.556222] Setting default values for core params
[    0.558286] Finished setting default values for core params
[    0.760724] Using Buffer DMA mode
[    0.762774] Periodic Transfer Interrupt Enhancement - disabled
[    0.764920] Multiprocessor Interrupt Enhancement - disabled
[    0.767099] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.769295] Dedicated Tx FIFOs mode
[    0.771750] WARN::dwc_otg_hcd_init:1053: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
[    0.776192] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    0.787530] dwc_otg: Microframe scheduler enabled
[    0.787580] WARN::hcd_init_fiq:457: FIQ on core 1 at 0x8058bc44
[    0.789883] WARN::hcd_init_fiq:458: FIQ ASM at 0x8058bfb4 length 36
[    0.792201] WARN::hcd_init_fiq:484: MPHI regs_base at 0xbb87c000
[    0.794551] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.796879] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    0.799232] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    0.801544] Init: Port Power? op_state=1
[    0.803794] Init: Power Port (0)
[    0.806165] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.808487] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.810785] usb usb1: Product: DWC OTG Controller
[    0.813029] usb usb1: Manufacturer: Linux 4.9.9-v7+ dwc_otg_hcd
[    0.815292] usb usb1: SerialNumber: 3f980000.usb
[    0.818361] hub 1-0:1.0: USB hub found
[    0.820558] hub 1-0:1.0: 1 port detected
[    0.823272] dwc_otg: FIQ enabled
[    0.823278] dwc_otg: NAK holdoff enabled
[    0.823282] dwc_otg: FIQ split-transaction FSM enabled
[    0.823295] Module dwc_common_port init
[    0.823530] usbcore: registered new interface driver usb-storage
[    0.825883] mousedev: PS/2 mouse device common for all mice
[    0.829063] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.831602] bcm2835-cpufreq: min=600000 max=1200000
[    0.834266] sdhci: Secure Digital Host Controller Interface driver
[    0.836573] sdhci: Copyright(c) Pierre Ossman
[    0.839219] sdhost: log_buf @ ba907000 (fa907000)
[    0.916640] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.941299] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    0.943625] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    0.993840] mmc0: host does not support reading read-only switch, assuming write-enable
[    0.998537] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.001508] ledtrig-cpu: registered to indicate activity on CPUs
[    1.004087] hidraw: raw HID events driver (C) Jiri Kosina
[    1.009916] usbcore: registered new interface driver usbhid
[    1.012354] usbhid: USB HID core driver
[    1.015171] mmc0: new high speed SDHC card at address 0007
[    1.018451] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
[    1.021839] mmcblk0: mmc0:0007 SD8GB 7.42 GiB
[    1.024813] Initializing XFRM netlink socket
[    1.027408] NET: Registered protocol family 17
[    1.030008] Key type dns_resolver registered
[    1.033027] Registering SWP/SWPB emulation handler
[    1.036932] registered taskstats version 1
[    1.042333] vc-sm: Videocore shared memory driver
[    1.044698] [vc_sm_connected_init]: start
[    1.047151]  mmcblk0: p1 p2
[    1.050304] [vc_sm_connected_init]: end - returning 0
[    1.050598] Indeed it is in host mode hprt0 = 00021501
[    1.056253] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    1.061255] of_cfs_init
[    1.063534] of_cfs_init: OK
[    1.082483] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.086973] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.101069] devtmpfs: mounted
[    1.112383] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
[    1.116345] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.120274] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.124093] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.129099] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.130262] random: fast init done
[    1.224479] mmc1: new high speed SDIO card at address 0001
[    1.246648] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    1.249048] Indeed it is in host mode hprt0 = 00001101
[    1.476927] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    1.479330] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.482482] hub 1-1:1.0: USB hub found
[    1.484885] hub 1-1:1.0: 5 ports detected
[    1.545013] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    1.550142] systemd[1]: Detected architecture 'arm'.
[    1.690717] NET: Registered protocol family 10
[    1.694388] systemd[1]: Inserted module 'ipv6'
[    1.699689] systemd[1]: Set hostname to <keller>.
[    1.806679] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    1.946983] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    1.949419] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.954777] smsc95xx v1.0.5
[    2.070749] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a9:e8:80
[    2.122803] systemd[1]: [/lib/systemd/system/certbot.timer:6] Unknown lvalue 'RandomizedDelaySec' in section 'Timer'
[    2.166676] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[    2.253355] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    2.264965] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    2.271037] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.277061] systemd[1]: Starting Remote File Systems (Pre).
[    2.283700] systemd[1]: Reached target Remote File Systems (Pre).
[    2.298314] usb 1-1.3: New USB device found, idVendor=045b, idProduct=0229
[    2.298326] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.298333] usb 1-1.3: Product: uPD720231A
[    2.298339] usb 1-1.3: Manufacturer: Renesas Electronics
[    2.298346] usb 1-1.3: SerialNumber: 4434313734353030303120202020202020202020
[    2.302366] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[    2.308553] scsi host0: usb-storage 1-1.3:1.0
[    3.367621] scsi 0:0:0:0: Direct-Access     TS32GMTS 400              O091 PQ: 0 ANSI: 6
[    3.373157] sd 0:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
[    3.378037] sd 0:0:0:0: [sda] Write Protect is off
[    3.380180] sd 0:0:0:0: [sda] Mode Sense: 33 00 10 08
[    3.380764] sd 0:0:0:0: [sda] No Caching mode page found
[    3.382829] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    3.388426]  sda: sda1 sda2
[    3.393653] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.692643] systemd-udevd[139]: starting version 215
[    4.032416] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    4.334107] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    4.558322] usbcore: registered new interface driver brcmfmac
[    5.056726] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    5.170660] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[    5.192481] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code (0x30 0x30)
[    5.374843] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code (0x30 0x30)
[    5.501848] systemd-journald[142]: Received request to flush runtime journal from PID 1
[    5.780472] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    5.780502] brcmfmac: power management disabled
[    5.922196] uart-pl011 3f201000.serial: no DMA platform data
[    6.573485] Adding 102396k swap on /var/swap.  Priority:-1 extents:3 across:151548k SSFS
[    6.777791] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    8.182322] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xDDE1
[   10.372045] Bluetooth: Core ver 2.22
[   10.372160] NET: Registered protocol family 31
[   10.372167] Bluetooth: HCI device and connection manager initialized
[   10.373324] Bluetooth: HCI socket layer initialized
[   10.373344] Bluetooth: L2CAP socket layer initialized
[   10.373389] Bluetooth: SCO socket layer initialized
[   10.393624] Bluetooth: HCI UART driver ver 2.3
[   10.393636] Bluetooth: HCI UART protocol H4 registered
[   10.393641] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   10.393793] Bluetooth: HCI UART protocol Broadcom registered
[   10.611445] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   10.611455] Bluetooth: BNEP filters: protocol multicast
[   10.611473] Bluetooth: BNEP socket layer initialized
[   79.507676] random: crng init done
[  104.362711] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
Unfortunately I have no idea how to diagnose/ what to try now?
andig2
Re: SSD via USB boot
Fri Feb 17, 2017 7:41 am
Tried some more and added
program_usb_timeout=1
to config.txt, the rebooted for programming and rebooted again without SD.
Raspi booted without SD now, however green led blinks continuously now at a slow pace. Everything else seems to be working, felt performance is better than with SD.
Thanks for MSD boot! :D
Fri Feb 17, 2017 10:43 am
That green blink means it can't find bootcode.bin on an SDCard, a USB drive or by PXE on the ethernet network.
This is a doctor free zone.
