boarddesigner
Using 1.8" TFT as camera viewer
Mon Feb 13, 2017 11:10 pm
I have a sainsmart18 tft up and running on my PI. A couple of problems I have:
1. Cannot get screen to rotate. What do I need to configure for this to work?
2. I am trying to use screen as camera previewer. What do I have to do to get the camera to send image to fb1?
texy
Re: Using 1.8" TFT as camera viewer
Tue Feb 14, 2017 8:44 am
1..assuming you are using fbtft driver for the display, there is a rotate option in the /boot/config.txt file, eg
dtoverlay=hy28b,rotate=270
is used for one type of display.
2..you can 'copy' the hdmi output to fb1 with a background task call fbcp - search the forum or google for it. This app will mirror image from hdmi to your display.
Hope this helps,
Texy
boarddesigner
Thu Feb 16, 2017 1:23 am
Excellent.
This is exactly what I was looking for. Regarding mirroring. I will have to play with some of the settings to get this perfected. it appears my cursor remains in the lower end of display. during mirror session. I will need to work on this.
fbtft
I think I might have done something out of date regarding the boot/config.txt file. I am not using the dtoverlay.
I had found a process on the web that had me put define my fbtft in the ( /etc/modprobe.d/fbtft.conf ) file.
Here is the fbtft driver i am using: sainsmart18
the fbtft.conf file contains this line:
options fbtft_device name=sainsmart18
Should I reconsider this?
Texy,
Thank you so very much for being awesome on this. Big help as I am so new it hurts.
texy
Thu Feb 16, 2017 7:20 am
boarddesigner wrote:Excellent.
fbtft
Texy,
If it's working to your satisfaction, then why change it? But the method has changed from your current solution.
You should find an overlay for your display in /boot/overlays/ if you want to go for the more modern approach.
Here is an example of how to use the device tree method of fbtft :
viewtopic.php?f=45&t=105797
You can ignore the instructions from step 6 onward, assuming your display does not have touch facility.
Texy
boarddesigner
Fri Feb 17, 2017 6:00 pm
Texy,
This is the information I needed. It appears there is no direct overlay for the sainsmart18. I could very well be wrong though. But I did find out how to create an overlay. I will have to look into creating overlays when time allows. Agreed, why change it.
Thanks again.
a-
