tomasz1994
GPS UART connection
Wed Feb 08, 2017 1:28 am
Raspberry : 3 model b
GPS : GLONASS NEO-7M-C UART
https://botland.com.pl/moduly-gps/4472- ... atowe.html
I'm doing all as in link below (highlight the code in boxes and copy to see what is in)
https://cdn-learn.adafruit.com/download ... rry-pi.pdf
when i type : 'sudo service gpsd status' i see "active (running)" - all excellent
but when i type: 'cgps' the status is NO FIX, lat long ect. are 'n/a' and all satelites are 'N' in column "used"
My only one idea is the fact that i'm working on this indoor, not outdoor...
... can someone help me with this issue ?
texy
Re: GPS UART connection
Wed Feb 08, 2017 1:19 pm
Without the gps module or antenna situated either outside, or close to a window, you'll get very poor reception.
In order to prove the setup, are you at least able to temporarily move it outside so that a good signal can prove the setup.
In my experiments I was able to get a good lock being close to a window inside.....
Texy
tomasz1994
Wed Feb 08, 2017 3:17 pm
Thanks I will try, so you think that when all notifications are
- good, active, running and working,
- displays current data time
BUT
-don't displays data as latitude, longitude
- gps see about 10 satelites but can't use them ('N' in column 'used' after cgpsd)
It can be probably signal problem ? Nothing more with configuration or technical dammage?
texy
Thu Feb 09, 2017 7:08 am
tomasz1994 wrote:Thanks I will try, so you think that when all notifications are
BUT
See how you get on with moving the kit and getting a good GPS lock. If you do, you should be able to get valid co-ordinates.
Rgds,
Texy
idk_lol
Wed Apr 11, 2018 2:33 pm
I am having the same problem, I tried at the window side too but getting n/a in every case.
any help will matter a lot.
thanking you.
