no wireless interface when clicking on dhcpcd icon in top
Posted: Sat Feb 04, 2017 12:18 pm
when i click the dhcpcd's "Wireless & Wired network" icon i get "No wireless interfaces found"
this is my interfaces file:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
allow-hotplug lo
iface lo inet loopback
allow-hotplug eth0
auto eth0
iface eth0 inet manual
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
my dhcpcd config file:
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface wlan0
static routers= [ i know the ip ]
inform [ i know what it automaticly configures to ]
interface eth0
static routers=[ i know the ip ]
wpa_supplicant config file:
update_config=1
country=NL
network={
ssid=" [not an ssid for sure] "
psk=" [this is not the password i wont show it] "
key_mgmt=WPA-PSK
disabled=0
i have no clue what is going on i have hostapd installed and i tried to make an AP but i think i screwed up real bad
as you can see i also removed some private stuff
update before post: i removed hostapd
update2:
heres some console output of dmesgh | tail
pi@RaspPi:~ $ dmesg | tail
[ 709.647653] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 709.647695] brcmfmac: power management disabled
[ 709.798867] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 709.863959] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 709.864333] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 710.079009] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 710.183964] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 710.184144] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 726.443663] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 726.448831] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
root@RaspPi:/home/pi# ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:71:6c:50
inet addr:192.168.3.13 Bcast:192.168.3.255 Mask:255.255.255.0
inet6 addr: fe80::ea8f:6aac:73ef:116e/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:8630 errors:0 dropped:0 overruns:0 frame:0
TX packets:6608 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:7595234 (7.2 MiB) TX bytes:904554 (883.3 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1005 errors:0 dropped:0 overruns:0 frame:0
TX packets:1005 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:204718 (199.9 KiB) TX bytes:204718 (199.9 KiB)
wlan0 Link encap:Ethernet HWaddr b8:27:eb:24:39:05
inet6 addr: fe80::bb46:72dd:8193:b9e/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:497 errors:0 dropped:253 overruns:0 frame:0
TX packets:258 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:292200 (285.3 KiB) TX bytes:33448 (32.6 KiB)
root@RaspPi:/home/pi# iwconfig
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Frequency:2.452 GHz Access Point: Not-Associated
Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
lo no wireless extensions.
eth0 no wireless extensions.
its very weird how dmesg | tail shows that brcmfmac doesnt have power management on while iwconfig shows its on
auto lo
allow-hotplug lo
allow-hotplug eth0
auto eth0
allow-hotplug wlan0
auto wlan0
allow-hotplug wlan1
#controlgroup wheel
hostname
clientid
# or
#duid
persistent
option rapid_commit
option ntp_servers
slaac private
interface wlan0
interface eth0
update_config=1
country=NL
network={
key_mgmt=WPA-PSK
disabled=0
update2:
Tx-Power=31 dBm
Encryption key:off
Power Management:on
