JacekQ
Capture video from webcam without monitor connected.
Fri Sep 14, 2012 8:08 am
I'm trying to capture video from webcam after RPi starts.
When I type this command in console:
ffmpeg -loglevel quiet -v quiet -f video4linux2 -s 320x240 -i /dev/video0 -r 30 -t 00:00:30 /home/pi/webcam`date +%j%H%M%S`.mpg
everything is fine - 30 seconds video is captured and saved to /home/pi/webcam[date].mpg file.
When I put this command into /etc/rc.local, after reboot again video is captured.
But when I connect to RPi only webcam and power supply after boot webcam is working but ignore 30 seconds limitation. When I turn off RPi file /home/pi/webcam[date].mpg is created but it has 0 bytes size.
I think the problem is disconnected HDMI and/or ffmpeg trying to write some informations on console even with -loglevel quiet -v quiet.
How can I capture video with time limit after RPi boot.
OS: 2012-08-16-wheezy-raspbian
Best regards,
Jacek Q.
Mrtin
Re: Capture video from webcam without monitor connected.
Fri Sep 14, 2012 10:28 am
Do you get any logging output with 'debug' in stead of 'quiet'? Check /var/log/debug, /var/log/messages.
Martijn
Martijn
JacekQ
Fri Sep 14, 2012 9:39 pm
I've done one reboot with everything connected and second reboot only with webcam.
In second case the /var/log/debug has one more line (the last one - ntpd signal_no_reset):
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] On node 0 totalpages: 61440
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] free_area_init_node: node 0, pgdat c05efc50, node_mem_map c06c0000
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]   Normal zone: 480 pages used for memmap
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]   Normal zone: 60960 pages, LIFO batch:15
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0
Sep 14 22:35:22 raspberrypi kernel: [    1.820624] Module dwc_common_port init
Sep 14 22:35:22 raspberrypi kernel: [    1.905555] Registered led device: mmc0::
Sep 14 22:35:22 raspberrypi kernel: [    1.935337] Registered led device: led0
Sep 14 22:35:24 raspberrypi ntpd[1372]: signal_no_reset: signal 17 had flags 4000000
/var/log/messages with all connected
Sep 14 22:32:17 raspberrypi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Sep 14 22:32:17 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="1289" x-info="http://www.rsyslog.com"] start
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Initializing cgroup subsys cpu
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Linux version 3.1.9+ (dc4@dc4-arm-01) (gcc version 4.7.1 20120402 (prerelease) (crosstool-NG 1.15.2) ) #272 PREEMPT Tue Aug 7 22:51:44 BST 2012
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Machine: BCM2708
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Memory policy: ECC disabled, Data cache writeback
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60960
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708.boardrev=0x2 bcm2708.serial=0x8488671b smsc95xx.macaddr=B8:27:EB:88:67:1B dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Memory: 240MB = 240MB total
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Memory: 236680k/236680k available, 9080k reserved, 0K highmem
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]     vmalloc : 0xcf800000 - 0xd8000000   ( 136 MB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xcf000000   ( 240 MB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]       .text : 0xc0008000 - 0xc058cd80   (5652 kB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]       .init : 0xc058d000 - 0xc05bf000   ( 200 kB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]       .data : 0xc05c0000 - 0xc05f13d8   ( 197 kB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000]        .bss : 0xc05f13fc - 0xc06bf60c   ( 825 kB)
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] NR_IRQS:245
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] Console: colour dummy device 80x30
Sep 14 22:32:17 raspberrypi kernel: [    0.000000] console [tty1] enabled
Sep 14 22:32:17 raspberrypi kernel: [    0.001267] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Sep 14 22:32:17 raspberrypi kernel: [    0.060195] pid_max: default: 32768 minimum: 301
Sep 14 22:32:17 raspberrypi kernel: [    0.060803] Mount-cache hash table entries: 512
Sep 14 22:32:17 raspberrypi kernel: [    0.061436] Initializing cgroup subsys cpuacct
Sep 14 22:32:17 raspberrypi kernel: [    0.061553] Initializing cgroup subsys devices
Sep 14 22:32:17 raspberrypi kernel: [    0.061603] Initializing cgroup subsys freezer
Sep 14 22:32:17 raspberrypi kernel: [    0.061645] Initializing cgroup subsys blkio
Sep 14 22:32:17 raspberrypi kernel: [    0.061758] CPU: Testing write buffer coherency: ok
Sep 14 22:32:17 raspberrypi kernel: [    0.061891] ftrace: allocating 14914 entries in 44 pages
Sep 14 22:32:17 raspberrypi kernel: [    0.133653] hw perfevents: enabled with v6 PMU driver, 3 counters available
Sep 14 22:32:17 raspberrypi kernel: [    0.135666] devtmpfs: initialized
Sep 14 22:32:17 raspberrypi kernel: [    0.142774] NET: Registered protocol family 16
Sep 14 22:32:17 raspberrypi kernel: [    0.144685] vc-mem: mm_vc_mem_phys_addr = 0x00000000
Sep 14 22:32:17 raspberrypi kernel: [    0.144747] vc-mem: mm_vc_mem_size      = 0x10000000 (256 MiB)
Sep 14 22:32:17 raspberrypi kernel: [    0.145259] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Sep 14 22:32:17 raspberrypi kernel: [    0.145330] hw-breakpoint: maximum watchpoint size is 4 bytes.
Sep 14 22:32:17 raspberrypi kernel: [    0.145377] mailbox: Broadcom VideoCore Mailbox driver
Sep 14 22:32:17 raspberrypi kernel: [    0.145489] bcm2708_vcio: mailbox at f200b880
Sep 14 22:32:17 raspberrypi kernel: [    0.145596] bcm_power: Broadcom power driver
Sep 14 22:32:17 raspberrypi kernel: [    0.145641] bcm_power_open() -> 0
Sep 14 22:32:17 raspberrypi kernel: [    0.145671] bcm_power_request(0, 8)
Sep 14 22:32:17 raspberrypi kernel: [    0.646367] bcm_mailbox_read -> 00000080, 0
Sep 14 22:32:17 raspberrypi kernel: [    0.646413] bcm_power_request -> 0
Sep 14 22:32:17 raspberrypi kernel: [    0.646443] Serial: AMBA PL011 UART driver
Sep 14 22:32:17 raspberrypi kernel: [    0.646638] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
Sep 14 22:32:17 raspberrypi kernel: [    0.962664] console [ttyAMA0] enabled
Sep 14 22:32:17 raspberrypi kernel: [    0.986333] bio: create slab <bio-0> at 0
Sep 14 22:32:17 raspberrypi kernel: [    0.991764] SCSI subsystem initialized
Sep 14 22:32:17 raspberrypi kernel: [    0.995948] usbcore: registered new interface driver usbfs
Sep 14 22:32:17 raspberrypi kernel: [    1.001606] usbcore: registered new interface driver hub
Sep 14 22:32:17 raspberrypi kernel: [    1.007313] usbcore: registered new device driver usb
Sep 14 22:32:17 raspberrypi kernel: [    1.013331] Switching to clocksource stc
Sep 14 22:32:17 raspberrypi kernel: [    1.027434] Switched to NOHz mode on CPU #0
Sep 14 22:32:17 raspberrypi kernel: [    1.036284] FS-Cache: Loaded
Sep 14 22:32:17 raspberrypi kernel: [    1.039670] CacheFiles: Loaded
Sep 14 22:32:17 raspberrypi kernel: [    1.060654] NET: Registered protocol family 2
Sep 14 22:32:17 raspberrypi kernel: [    1.065584] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    1.074067] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    1.081584] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    1.088289] TCP: Hash tables configured (established 8192 bind 8192)
Sep 14 22:32:17 raspberrypi kernel: [    1.094671] TCP reno registered
Sep 14 22:32:17 raspberrypi kernel: [    1.097880] UDP hash table entries: 256 (order: 0, 4096 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    1.103770] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    1.110649] NET: Registered protocol family 1
Sep 14 22:32:17 raspberrypi kernel: [    1.116020] RPC: Registered named UNIX socket transport module.
Sep 14 22:32:17 raspberrypi kernel: [    1.122201] RPC: Registered udp transport module.
Sep 14 22:32:17 raspberrypi kernel: [    1.126933] RPC: Registered tcp transport module.
Sep 14 22:32:17 raspberrypi kernel: [    1.131695] RPC: Registered tcp NFSv4.1 backchannel transport module.
Sep 14 22:32:17 raspberrypi kernel: [    1.138494] bcm2708_dma: DMA manager at cf808000
Sep 14 22:32:17 raspberrypi kernel: [    1.148911] vc-mem: Videocore memory driver
Sep 14 22:32:17 raspberrypi kernel: [    1.154002] audit: initializing netlink socket (disabled)
Sep 14 22:32:17 raspberrypi kernel: [    1.159566] type=2000 audit(0.780:1): initialized
Sep 14 22:32:17 raspberrypi kernel: [    1.273175] VFS: Disk quotas dquot_6.5.2
Sep 14 22:32:17 raspberrypi kernel: [    1.277376] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Sep 14 22:32:17 raspberrypi kernel: [    1.285337] FS-Cache: Netfs 'nfs' registered for caching
Sep 14 22:32:17 raspberrypi kernel: [    1.292013] msgmni has been set to 462
Sep 14 22:32:17 raspberrypi kernel: [    1.298575] io scheduler noop registered
Sep 14 22:32:17 raspberrypi kernel: [    1.302551] io scheduler deadline registered (default)
Sep 14 22:32:17 raspberrypi kernel: [    1.308086] io scheduler cfq registered
Sep 14 22:32:17 raspberrypi kernel: [    1.312234] BCM2708FB: registering framebuffer (1920x1080@16)
Sep 14 22:32:17 raspberrypi kernel: [    1.318937] bcm2708_fb_set_par info(ce8ed400) 1920x1080 (1920x1080), 0, 16
Sep 14 22:32:17 raspberrypi kernel: [    1.333914] BCM2708FB: start = cfc00000,4f585000 width=1920, height=1080, bpp=16, pitch=3840 size=4177920 success=0
Sep 14 22:32:17 raspberrypi kernel: [    1.364023] Console: switching to colour frame buffer device 240x67
Sep 14 22:32:17 raspberrypi kernel: [    1.416051] BCM2708FB: register framebuffer (0)
Sep 14 22:32:17 raspberrypi kernel: [    1.421584] kgdb: Registered I/O driver kgdboc.
Sep 14 22:32:17 raspberrypi kernel: [    1.437982] brd: module loaded
Sep 14 22:32:17 raspberrypi kernel: [    1.447340] loop: module loaded
Sep 14 22:32:17 raspberrypi kernel: [    1.451661] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
Sep 14 22:32:17 raspberrypi kernel: [    1.459816] vcos: [1]: vchiq_init_state: called
Sep 14 22:32:17 raspberrypi kernel: [    1.473389] usbcore: registered new interface driver smsc95xx
Sep 14 22:32:17 raspberrypi kernel: [    1.479450] cdc_ncm: 04-Aug-2011
Sep 14 22:32:17 raspberrypi kernel: [    1.482913] usbcore: registered new interface driver cdc_ncm
Sep 14 22:32:17 raspberrypi kernel: [    1.488790] dwc_otg: version 2.90b 6-MAY-2010 (platform bus)
Sep 14 22:32:17 raspberrypi kernel: [    1.495000] Core Release: 2.80a
Sep 14 22:32:17 raspberrypi kernel: [    1.498371] Setting default values for core params
Sep 14 22:32:17 raspberrypi kernel: [    1.503337] Finished setting default values for core params
Sep 14 22:32:17 raspberrypi kernel: [    1.509386] cf840008 -> 1
Sep 14 22:32:17 raspberrypi kernel: [    1.712102] Using Buffer DMA mode
Sep 14 22:32:17 raspberrypi kernel: [    1.715529] Periodic Transfer Interrupt Enhancement - disabled
Sep 14 22:32:17 raspberrypi kernel: [    1.721630] Multiprocessor Interrupt Enhancement - disabled
Sep 14 22:32:17 raspberrypi kernel: [    1.727502] dwc_otg bcm2708_usb: DWC OTG Controller
Sep 14 22:32:17 raspberrypi kernel: [    1.732595] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Sep 14 22:32:17 raspberrypi kernel: [    1.740166] dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
Sep 14 22:32:17 raspberrypi kernel: [    1.745863] Init: Port Power? op_state=1
Sep 14 22:32:17 raspberrypi kernel: [    1.749961] Init: Power Port (0)
Sep 14 22:32:17 raspberrypi kernel: [    1.753449] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Sep 14 22:32:17 raspberrypi kernel: [    1.760511] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 14 22:32:17 raspberrypi kernel: [    1.767978] usb usb1: Product: DWC OTG Controller
Sep 14 22:32:17 raspberrypi kernel: [    1.772821] usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
Sep 14 22:32:17 raspberrypi kernel: [    1.778682] usb usb1: SerialNumber: bcm2708_usb
Sep 14 22:32:17 raspberrypi kernel: [    1.784443] hub 1-0:1.0: USB hub found
Sep 14 22:32:17 raspberrypi kernel: [    1.788505] hub 1-0:1.0: 1 port detected
Sep 14 22:32:17 raspberrypi kernel: [    1.801212] usbcore: registered new interface driver uas
Sep 14 22:32:17 raspberrypi kernel: [    1.814287] Initializing USB Mass Storage driver...
Sep 14 22:32:17 raspberrypi kernel: [    1.827197] usbcore: registered new interface driver usb-storage
Sep 14 22:32:17 raspberrypi kernel: [    1.840941] USB Mass Storage support registered.
Sep 14 22:32:17 raspberrypi kernel: [    1.853656] usbcore: registered new interface driver libusual
Sep 14 22:32:17 raspberrypi kernel: [    1.867734] mousedev: PS/2 mouse device common for all mice
Sep 14 22:32:17 raspberrypi kernel: [    1.881062] cpuidle: using governor ladder
Sep 14 22:32:17 raspberrypi kernel: [    1.892882] cpuidle: using governor menu
Sep 14 22:32:17 raspberrypi kernel: [    1.904718] sdhci: Secure Digital Host Controller Interface driver
Sep 14 22:32:17 raspberrypi kernel: [    1.918667] sdhci: Copyright(c) Pierre Ossman
Sep 14 22:32:17 raspberrypi kernel: [    1.930843] bcm_power_open() -> 1
Sep 14 22:32:17 raspberrypi kernel: [    1.942509] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
Sep 14 22:32:17 raspberrypi kernel: [    1.958184] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
Sep 14 22:32:17 raspberrypi kernel: [    1.971848] sdhci-pltfm: SDHCI platform and OF driver helper
Sep 14 22:32:17 raspberrypi kernel: [    1.987198] usbcore: registered new interface driver usbhid
Sep 14 22:32:17 raspberrypi kernel: [    2.006450] usbhid: USB HID core driver
Sep 14 22:32:17 raspberrypi kernel: [    2.040483] TCP cubic registered
Sep 14 22:32:17 raspberrypi kernel: [    2.067486] Initializing XFRM netlink socket
Sep 14 22:32:17 raspberrypi kernel: [    2.085823] mmc0: problem reading SD Status register.
Sep 14 22:32:17 raspberrypi kernel: [    2.098734] NET: Registered protocol family 17
Sep 14 22:32:17 raspberrypi kernel: [    2.127694] Registering the dns_resolver key type
Sep 14 22:32:17 raspberrypi kernel: [    2.140442] mmc0: new SDHC card at address d555
Sep 14 22:32:17 raspberrypi kernel: [    2.167586] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Sep 14 22:32:17 raspberrypi kernel: [    2.183865] mmcblk0: mmc0:d555 SD04G 3.79 GiB
Sep 14 22:32:17 raspberrypi kernel: [    2.201577]  mmcblk0: p1 p2
Sep 14 22:32:17 raspberrypi kernel: [    2.237771] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Sep 14 22:32:17 raspberrypi kernel: [    2.253981] VFS: Mounted root (ext4 filesystem) on device 179:2.
Sep 14 22:32:17 raspberrypi kernel: [    2.269536] Freeing init memory: 200K
Sep 14 22:32:17 raspberrypi kernel: [    2.327584] usb 1-1: new high speed USB device number 2 using dwc_otg
Sep 14 22:32:17 raspberrypi kernel: [    2.548128] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Sep 14 22:32:17 raspberrypi kernel: [    2.562757] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 14 22:32:17 raspberrypi kernel: [    2.578908] hub 1-1:1.0: USB hub found
Sep 14 22:32:17 raspberrypi kernel: [    2.591536] hub 1-1:1.0: 3 ports detected
Sep 14 22:32:17 raspberrypi kernel: [    2.877760] usb 1-1.1: new high speed USB device number 3 using dwc_otg
Sep 14 22:32:17 raspberrypi kernel: [    3.008249] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Sep 14 22:32:17 raspberrypi kernel: [    3.026165] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 14 22:32:17 raspberrypi kernel: [    3.044800] smsc95xx v1.0.4
Sep 14 22:32:17 raspberrypi kernel: [    3.123479] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:88:67:1b
Sep 14 22:32:17 raspberrypi kernel: [    3.257888] usb 1-1.2: new high speed USB device number 4 using dwc_otg
Sep 14 22:32:17 raspberrypi kernel: [    3.483781] usb 1-1.2: New USB device found, idVendor=046d, idProduct=09a4
Sep 14 22:32:17 raspberrypi kernel: [    3.498923] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Sep 14 22:32:17 raspberrypi kernel: [    3.514365] usb 1-1.2: SerialNumber: B3D0EC20
Sep 14 22:32:17 raspberrypi kernel: [    3.607883] usb 1-1.3: new full speed USB device number 5 using dwc_otg
Sep 14 22:32:17 raspberrypi kernel: [    3.750831] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52e
Sep 14 22:32:17 raspberrypi kernel: [    3.780230] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Sep 14 22:32:17 raspberrypi kernel: [    3.817649] usb 1-1.3: Product: USB Receiver
Sep 14 22:32:17 raspberrypi kernel: [    3.837602] usb 1-1.3: Manufacturer: Logitech
Sep 14 22:32:17 raspberrypi kernel: [    3.870112] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
Sep 14 22:32:17 raspberrypi kernel: [    3.917834] generic-usb 0003:046D:C52E.0001: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-bcm2708_usb-1.3/input0
Sep 14 22:32:17 raspberrypi kernel: [    3.977785] input: Logitech USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input1
Sep 14 22:32:17 raspberrypi kernel: [    4.017052] generic-usb 0003:046D:C52E.0002: input,hiddev0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-bcm2708_usb-1.3/input1
Sep 14 22:32:17 raspberrypi kernel: [    7.885157] Linux video capture interface: v2.00
Sep 14 22:32:17 raspberrypi kernel: [    8.267841] uvcvideo: Found UVC 1.00 device <unnamed> (046d:09a4)
Sep 14 22:32:17 raspberrypi kernel: [    8.498546] input: UVC Camera (046d:09a4) as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input2
Sep 14 22:32:17 raspberrypi kernel: [    8.683790] usbcore: registered new interface driver uvcvideo
Sep 14 22:32:17 raspberrypi kernel: [    8.789700] USB Video Class driver (1.1.1)
Sep 14 22:32:17 raspberrypi kernel: [    9.258357] usbcore: registered new interface driver snd-usb-audio
Sep 14 22:32:17 raspberrypi kernel: [   14.872131] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Sep 14 22:32:17 raspberrypi kernel: [   15.079154] ### snd_bcm2835_alsa_probe c05c88e0 ############### PROBING FOR bcm2835 ALSA device (0):(1) ###############
Sep 14 22:32:17 raspberrypi kernel: [   15.099680] Creating card...
Sep 14 22:32:17 raspberrypi kernel: [   15.112365] Creating device/chip ..
Sep 14 22:32:17 raspberrypi kernel: [   15.132600] Adding controls ..
Sep 14 22:32:17 raspberrypi kernel: [   15.157641] Registering card ....
Sep 14 22:32:17 raspberrypi kernel: [   15.184090] bcm2835 ALSA CARD CREATED!
Sep 14 22:32:17 raspberrypi kernel: [   15.218677] ### BCM2835 ALSA driver init OK ###
Sep 14 22:32:17 raspberrypi kernel: [   21.887991] set volume quirk for QuickCam E3500
Sep 14 22:32:17 raspberrypi kernel: [   23.156112] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
Sep 14 22:32:19 raspberrypi kernel: [   28.065327] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
/var/log/messages with webcam
Sep 14 22:35:22 raspberrypi kernel: imklog 5.8.11, log source = /proc/kmsg started.
Sep 14 22:35:22 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="1244" x-info="http://www.rsyslog.com"] start
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Initializing cgroup subsys cpu
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Linux version 3.1.9+ (dc4@dc4-arm-01) (gcc version 4.7.1 20120402 (prerelease) (crosstool-NG 1.15.2) ) #272 PREEMPT Tue Aug 7 22:51:44 BST 2012
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Machine: BCM2708
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Memory policy: ECC disabled, Data cache writeback
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60960
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Kernel command line: dma.dmachans=0x3c bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708.boardrev=0x2 bcm2708.serial=0x8488671b smsc95xx.macaddr=B8:27:EB:88:67:1B dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Memory: 240MB = 240MB total
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Memory: 236680k/236680k available, 9080k reserved, 0K highmem
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]     vmalloc : 0xcf800000 - 0xd8000000   ( 136 MB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xcf000000   ( 240 MB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]       .text : 0xc0008000 - 0xc058cd80   (5652 kB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]       .init : 0xc058d000 - 0xc05bf000   ( 200 kB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]       .data : 0xc05c0000 - 0xc05f13d8   ( 197 kB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000]        .bss : 0xc05f13fc - 0xc06bf60c   ( 825 kB)
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] NR_IRQS:245
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] Console: colour dummy device 80x30
Sep 14 22:35:22 raspberrypi kernel: [    0.000000] console [tty1] enabled
Sep 14 22:35:22 raspberrypi kernel: [    0.001265] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Sep 14 22:35:22 raspberrypi kernel: [    0.060194] pid_max: default: 32768 minimum: 301
Sep 14 22:35:22 raspberrypi kernel: [    0.060805] Mount-cache hash table entries: 512
Sep 14 22:35:22 raspberrypi kernel: [    0.061442] Initializing cgroup subsys cpuacct
Sep 14 22:35:22 raspberrypi kernel: [    0.061557] Initializing cgroup subsys devices
Sep 14 22:35:22 raspberrypi kernel: [    0.061605] Initializing cgroup subsys freezer
Sep 14 22:35:22 raspberrypi kernel: [    0.061647] Initializing cgroup subsys blkio
Sep 14 22:35:22 raspberrypi kernel: [    0.061760] CPU: Testing write buffer coherency: ok
Sep 14 22:35:22 raspberrypi kernel: [    0.061892] ftrace: allocating 14914 entries in 44 pages
Sep 14 22:35:22 raspberrypi kernel: [    0.133651] hw perfevents: enabled with v6 PMU driver, 3 counters available
Sep 14 22:35:22 raspberrypi kernel: [    0.135676] devtmpfs: initialized
Sep 14 22:35:22 raspberrypi kernel: [    0.142779] NET: Registered protocol family 16
Sep 14 22:35:22 raspberrypi kernel: [    0.144677] vc-mem: mm_vc_mem_phys_addr = 0x00000000
Sep 14 22:35:22 raspberrypi kernel: [    0.144739] vc-mem: mm_vc_mem_size      = 0x10000000 (256 MiB)
Sep 14 22:35:22 raspberrypi kernel: [    0.145250] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Sep 14 22:35:22 raspberrypi kernel: [    0.145321] hw-breakpoint: maximum watchpoint size is 4 bytes.
Sep 14 22:35:22 raspberrypi kernel: [    0.145368] mailbox: Broadcom VideoCore Mailbox driver
Sep 14 22:35:22 raspberrypi kernel: [    0.145481] bcm2708_vcio: mailbox at f200b880
Sep 14 22:35:22 raspberrypi kernel: [    0.145584] bcm_power: Broadcom power driver
Sep 14 22:35:22 raspberrypi kernel: [    0.145630] bcm_power_open() -> 0
Sep 14 22:35:22 raspberrypi kernel: [    0.145661] bcm_power_request(0, 8)
Sep 14 22:35:22 raspberrypi kernel: [    0.646355] bcm_mailbox_read -> 00000080, 0
Sep 14 22:35:22 raspberrypi kernel: [    0.646400] bcm_power_request -> 0
Sep 14 22:35:22 raspberrypi kernel: [    0.646431] Serial: AMBA PL011 UART driver
Sep 14 22:35:22 raspberrypi kernel: [    0.646620] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
Sep 14 22:35:22 raspberrypi kernel: [    0.962468] console [ttyAMA0] enabled
Sep 14 22:35:22 raspberrypi kernel: [    0.986150] bio: create slab <bio-0> at 0
Sep 14 22:35:22 raspberrypi kernel: [    0.991581] SCSI subsystem initialized
Sep 14 22:35:22 raspberrypi kernel: [    0.995754] usbcore: registered new interface driver usbfs
Sep 14 22:35:22 raspberrypi kernel: [    1.001407] usbcore: registered new interface driver hub
Sep 14 22:35:22 raspberrypi kernel: [    1.007109] usbcore: registered new device driver usb
Sep 14 22:35:22 raspberrypi kernel: [    1.013124] Switching to clocksource stc
Sep 14 22:35:22 raspberrypi kernel: [    1.027230] Switched to NOHz mode on CPU #0
Sep 14 22:35:22 raspberrypi kernel: [    1.036049] FS-Cache: Loaded
Sep 14 22:35:22 raspberrypi kernel: [    1.039435] CacheFiles: Loaded
Sep 14 22:35:22 raspberrypi kernel: [    1.060423] NET: Registered protocol family 2
Sep 14 22:35:22 raspberrypi kernel: [    1.065356] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    1.073840] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    1.081359] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    1.088061] TCP: Hash tables configured (established 8192 bind 8192)
Sep 14 22:35:22 raspberrypi kernel: [    1.094444] TCP reno registered
Sep 14 22:35:22 raspberrypi kernel: [    1.097651] UDP hash table entries: 256 (order: 0, 4096 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    1.103541] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    1.110420] NET: Registered protocol family 1
Sep 14 22:35:22 raspberrypi kernel: [    1.115781] RPC: Registered named UNIX socket transport module.
Sep 14 22:35:22 raspberrypi kernel: [    1.121962] RPC: Registered udp transport module.
Sep 14 22:35:22 raspberrypi kernel: [    1.126694] RPC: Registered tcp transport module.
Sep 14 22:35:22 raspberrypi kernel: [    1.131456] RPC: Registered tcp NFSv4.1 backchannel transport module.
Sep 14 22:35:22 raspberrypi kernel: [    1.138256] bcm2708_dma: DMA manager at cf808000
Sep 14 22:35:22 raspberrypi kernel: [    1.148674] vc-mem: Videocore memory driver
Sep 14 22:35:22 raspberrypi kernel: [    1.153768] audit: initializing netlink socket (disabled)
Sep 14 22:35:22 raspberrypi kernel: [    1.159330] type=2000 audit(0.780:1): initialized
Sep 14 22:35:22 raspberrypi kernel: [    1.272914] VFS: Disk quotas dquot_6.5.2
Sep 14 22:35:22 raspberrypi kernel: [    1.277113] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Sep 14 22:35:22 raspberrypi kernel: [    1.285071] FS-Cache: Netfs 'nfs' registered for caching
Sep 14 22:35:22 raspberrypi kernel: [    1.291751] msgmni has been set to 462
Sep 14 22:35:22 raspberrypi kernel: [    1.298300] io scheduler noop registered
Sep 14 22:35:22 raspberrypi kernel: [    1.302273] io scheduler deadline registered (default)
Sep 14 22:35:22 raspberrypi kernel: [    1.307806] io scheduler cfq registered
Sep 14 22:35:22 raspberrypi kernel: [    1.311953] BCM2708FB: registering framebuffer (720x480@16)
Sep 14 22:35:22 raspberrypi kernel: [    1.318296] bcm2708_fb_set_par info(ce8ed400) 720x480 (720x480), 0, 16
Sep 14 22:35:22 raspberrypi kernel: [    1.324011] BCM2708FB: start = cf900000,4f585000 width=720, height=480, bpp=16, pitch=1440 size=691200 success=0
Sep 14 22:35:22 raspberrypi kernel: [    1.329086] Console: switching to colour frame buffer device 90x30
Sep 14 22:35:22 raspberrypi kernel: [    1.366547] BCM2708FB: register framebuffer (0)
Sep 14 22:35:22 raspberrypi kernel: [    1.374627] kgdb: Registered I/O driver kgdboc.
Sep 14 22:35:22 raspberrypi kernel: [    1.393273] brd: module loaded
Sep 14 22:35:22 raspberrypi kernel: [    1.405079] loop: module loaded
Sep 14 22:35:22 raspberrypi kernel: [    1.411883] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
Sep 14 22:35:22 raspberrypi kernel: [    1.422527] vcos: [1]: vchiq_init_state: called
Sep 14 22:35:22 raspberrypi kernel: [    1.441444] usbcore: registered new interface driver smsc95xx
Sep 14 22:35:22 raspberrypi kernel: [    1.450062] cdc_ncm: 04-Aug-2011
Sep 14 22:35:22 raspberrypi kernel: [    1.456139] usbcore: registered new interface driver cdc_ncm
Sep 14 22:35:22 raspberrypi kernel: [    1.464644] dwc_otg: version 2.90b 6-MAY-2010 (platform bus)
Sep 14 22:35:22 raspberrypi kernel: [    1.473550] Core Release: 2.80a
Sep 14 22:35:22 raspberrypi kernel: [    1.479550] Setting default values for core params
Sep 14 22:35:22 raspberrypi kernel: [    1.487101] Finished setting default values for core params
Sep 14 22:35:22 raspberrypi kernel: [    1.495764] cf840008 -> 1
Sep 14 22:35:22 raspberrypi kernel: [    1.701134] Using Buffer DMA mode
Sep 14 22:35:22 raspberrypi kernel: [    1.707063] Periodic Transfer Interrupt Enhancement - disabled
Sep 14 22:35:22 raspberrypi kernel: [    1.715655] Multiprocessor Interrupt Enhancement - disabled
Sep 14 22:35:22 raspberrypi kernel: [    1.724252] dwc_otg bcm2708_usb: DWC OTG Controller
Sep 14 22:35:22 raspberrypi kernel: [    1.732055] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
Sep 14 22:35:22 raspberrypi kernel: [    1.742294] dwc_otg bcm2708_usb: irq 75, io mem 0x00000000
Sep 14 22:35:22 raspberrypi kernel: [    1.750663] Init: Port Power? op_state=1
Sep 14 22:35:22 raspberrypi kernel: [    1.757350] Init: Power Port (0)
Sep 14 22:35:22 raspberrypi kernel: [    1.763295] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Sep 14 22:35:22 raspberrypi kernel: [    1.772834] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Sep 14 22:35:22 raspberrypi kernel: [    1.782749] usb usb1: Product: DWC OTG Controller
Sep 14 22:35:22 raspberrypi kernel: [    1.790142] usb usb1: Manufacturer: Linux 3.1.9+ dwc_otg_hcd
Sep 14 22:35:22 raspberrypi kernel: [    1.798516] usb usb1: SerialNumber: bcm2708_usb
Sep 14 22:35:22 raspberrypi kernel: [    1.806778] hub 1-0:1.0: USB hub found
Sep 14 22:35:22 raspberrypi kernel: [    1.813318] hub 1-0:1.0: 1 port detected
Sep 14 22:35:22 raspberrypi kernel: [    1.821027] usbcore: registered new interface driver uas
Sep 14 22:35:22 raspberrypi kernel: [    1.829065] Initializing USB Mass Storage driver...
Sep 14 22:35:22 raspberrypi kernel: [    1.836742] usbcore: registered new interface driver usb-storage
Sep 14 22:35:22 raspberrypi kernel: [    1.845397] USB Mass Storage support registered.
Sep 14 22:35:22 raspberrypi kernel: [    1.852946] usbcore: registered new interface driver libusual
Sep 14 22:35:22 raspberrypi kernel: [    1.861872] mousedev: PS/2 mouse device common for all mice
Sep 14 22:35:22 raspberrypi kernel: [    1.870191] cpuidle: using governor ladder
Sep 14 22:35:22 raspberrypi kernel: [    1.876829] cpuidle: using governor menu
Sep 14 22:35:22 raspberrypi kernel: [    1.883459] sdhci: Secure Digital Host Controller Interface driver
Sep 14 22:35:22 raspberrypi kernel: [    1.892256] sdhci: Copyright(c) Pierre Ossman
Sep 14 22:35:22 raspberrypi kernel: [    1.899431] bcm_power_open() -> 1
Sep 14 22:35:22 raspberrypi kernel: [    1.906072] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
Sep 14 22:35:22 raspberrypi kernel: [    1.916747] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
Sep 14 22:35:22 raspberrypi kernel: [    1.925573] sdhci-pltfm: SDHCI platform and OF driver helper
Sep 14 22:35:22 raspberrypi kernel: [    1.935822] usbcore: registered new interface driver usbhid
Sep 14 22:35:22 raspberrypi kernel: [    1.944116] usbhid: USB HID core driver
Sep 14 22:35:22 raspberrypi kernel: [    1.959731] TCP cubic registered
Sep 14 22:35:22 raspberrypi kernel: [    1.965526] Initializing XFRM netlink socket
Sep 14 22:35:22 raspberrypi kernel: [    1.972582] NET: Registered protocol family 17
Sep 14 22:35:22 raspberrypi kernel: [    1.981839] Registering the dns_resolver key type
Sep 14 22:35:22 raspberrypi kernel: [    1.991333] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Sep 14 22:35:22 raspberrypi kernel: [    2.007759] Waiting for root device /dev/mmcblk0p2...
Sep 14 22:35:22 raspberrypi kernel: [    2.055935] mmc0: new SDHC card at address d555
Sep 14 22:35:22 raspberrypi kernel: [    2.077980] mmcblk0: mmc0:d555 SD04G 3.79 GiB
Sep 14 22:35:22 raspberrypi kernel: [    2.087098]  mmcblk0: p1 p2
Sep 14 22:35:22 raspberrypi kernel: [    2.139795] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Sep 14 22:35:22 raspberrypi kernel: [    2.153532] VFS: Mounted root (ext4 filesystem) on device 179:2.
Sep 14 22:35:22 raspberrypi kernel: [    2.163977] Freeing init memory: 200K
Sep 14 22:35:22 raspberrypi kernel: [    2.217367] usb 1-1: new high speed USB device number 2 using dwc_otg
Sep 14 22:35:22 raspberrypi kernel: [    2.438030] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
Sep 14 22:35:22 raspberrypi kernel: [    2.447729] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 14 22:35:22 raspberrypi kernel: [    2.460908] hub 1-1:1.0: USB hub found
Sep 14 22:35:22 raspberrypi kernel: [    2.469775] hub 1-1:1.0: 3 ports detected
Sep 14 22:35:22 raspberrypi kernel: [    2.757641] usb 1-1.1: new high speed USB device number 3 using dwc_otg
Sep 14 22:35:22 raspberrypi kernel: [    2.887995] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Sep 14 22:35:22 raspberrypi kernel: [    2.898662] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 14 22:35:22 raspberrypi kernel: [    2.912209] smsc95xx v1.0.4
Sep 14 22:35:22 raspberrypi kernel: [    2.983452] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:88:67:1b
Sep 14 22:35:22 raspberrypi kernel: [    3.097632] usb 1-1.2: new high speed USB device number 4 using dwc_otg
Sep 14 22:35:22 raspberrypi kernel: [    3.313680] usb 1-1.2: New USB device found, idVendor=046d, idProduct=09a4
Sep 14 22:35:22 raspberrypi kernel: [    3.324341] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=2
Sep 14 22:35:22 raspberrypi kernel: [    3.334899] usb 1-1.2: SerialNumber: B3D0EC20
Sep 14 22:35:22 raspberrypi kernel: [    6.934181] Linux video capture interface: v2.00
Sep 14 22:35:22 raspberrypi kernel: [    7.190843] uvcvideo: Found UVC 1.00 device <unnamed> (046d:09a4)
Sep 14 22:35:22 raspberrypi kernel: [    7.381915] input: UVC Camera (046d:09a4) as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input0
Sep 14 22:35:22 raspberrypi kernel: [    7.567611] usbcore: registered new interface driver uvcvideo
Sep 14 22:35:22 raspberrypi kernel: [    7.576533] USB Video Class driver (1.1.1)
Sep 14 22:35:22 raspberrypi kernel: [    8.045705] usbcore: registered new interface driver snd-usb-audio
Sep 14 22:35:22 raspberrypi kernel: [   13.403604] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Sep 14 22:35:22 raspberrypi kernel: [   13.589715] ### snd_bcm2835_alsa_probe c05c88e0 ############### PROBING FOR bcm2835 ALSA device (0):(1) ###############
Sep 14 22:35:22 raspberrypi kernel: [   13.607040] Creating card...
Sep 14 22:35:22 raspberrypi kernel: [   13.613263] Creating device/chip ..
Sep 14 22:35:22 raspberrypi kernel: [   13.620508] Adding controls ..
Sep 14 22:35:22 raspberrypi kernel: [   13.626587] Registering card ....
Sep 14 22:35:22 raspberrypi kernel: [   13.642551] bcm2835 ALSA CARD CREATED!
Sep 14 22:35:22 raspberrypi kernel: [   13.654814] ### BCM2835 ALSA driver init OK ###
Sep 14 22:35:22 raspberrypi kernel: [   19.734590] set volume quirk for QuickCam E3500
Sep 14 22:35:23 raspberrypi kernel: [   24.961366] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
Sep 14 22:36:28 raspberrypi kernel: [   90.314274] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
I've moved ffmpeg command to .profile and after reboot with webcam only I use ssh to shutdown RPi and after login I saw this message:
ffmpeg version 0.8.2-6:0.8.2-1+rpi1+b1, Copyright (c) 2000-2011 the Libav develo
pers
  built on Jun 27 2012 01:07:05 with gcc 4.6.3
  configuration: --extra-version='6:0.8.2-1+rpi1+b1' --arch=arm --prefix=/usr --
libdir=/usr/lib/arm-linux-gnueabihf --enable-vdpau --enable-bzlib --enable-frei0
r --enable-gnutls --enable-libcdio --enable-libgsm --enable-libschroedinger --en
able-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-z
lib --enable-libvpx --enable-runtime-cpudetect --enable-libfreetype --enable-lib
pulse --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enabl
e-swscale --enable-x11grab --enable-libdirac --enable-libmp3lame --enable-librtm
p --enable-libx264 --enable-libxvid --enable-libdc1394 --shlibdir=/usr/lib/arm-l
inux-gnueabihf --enable-shared --disable-static
  libavutil    51. 22. 1 / 51. 22. 1
  libavcodec   53. 35. 0 / 53. 35. 0
  libavformat  53. 21. 0 / 53. 21. 0
  libavdevice  53.  2. 0 / 53.  2. 0
  libavfilter   2. 15. 0 /  2. 15. 0
  libswscale    2.  1. 0 /  2.  1. 0
  libpostproc  52.  0. 0 / 52.  0. 0
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future
release. Please use avconv instead.
[video4linux2 @ 0x1357220] [4]Capabilities: 4000001
[video4linux2 @ 0x1357220] Cannot find a proper format for codec_id 0, pix_fmt -
1.
/dev/video0: Input/output error
Best regards,
Jacek Q.
Mrtin
Sat Sep 15, 2012 4:36 am
It looks like this is why ffmpeg doesn't start up:
[video4linux2 @ 0x1357220] Cannot find a proper format for codec_id 0, pix_fmt -1.
I don't know enough about it to help you further there, sorry.
Have you considered using mjpg-streamer or motion, to use with your webcam? My experience is that they are easier to setup than ffserver/ffmpeg...
Martijn
JacekQ
Sat Sep 15, 2012 9:15 am
Thank you for your help.
I'll try to force codec for ffmpeg and will see what happen.
Can you tell me how to install mjpg-streamer. I try apt-get but I've got error Unable to locate package.
Now I will try to use motion.
Best regards,
Jacek Q.
JacekQ
Sat Sep 15, 2012 6:18 pm
ffmpeg with -vcodec parameter not working :(
Best regards,
Jacek Q.
JacekQ
Tue Sep 18, 2012 8:07 pm
Solved,
This is probably not the simplest way but it works.
  • Set up Raspberry Pi to start lxde after boot (sudo raspi-config)
  • Create directory ~/.config/autostart
  • Create file ~/.config/autostart/auto.desktop
[Desktop Entry]
Encoding=UTF-8
Name= Record
Comment=Capture video
Exec=lxterminal --command "/home/pi/videos/record"
Terminal=true
  • Install guvcview (sudo apt-get install guvcview)
  • Create directory ~/videos
  • Create file ~/videos/record and make it executable (chmod +x ~/videos/record)
rm -f ~/videos/movie.avi
guvcview -s 320x240 -t 300 -n ~/videos/movie.avi --exit_on_close --no_display
After reboot Raspberry Pi will try to record 300 seconds video.
Best regards,
Jacek Q.
sumith
Thu Sep 20, 2012 11:28 am
I am using raspberry pi with Debian Wheezy. I installed OpenCv 2.3.1. I can take images with my logitech hd 720p usb web cam using openCv program but failed to take video. it shows error:
OpenCV Error: Unsupported format or combination of formats (Gstreamer Opencv backend doesn't support this codec acutally.)
But when I enter the command
It takes the video.
i can't understand what is the problem. I need a solution. Could you help me?
Fensterbank
Sun Sep 23, 2012 6:55 pm
I don't know, if this helps anyone of you with the problems, but I build a solution for me last night, which works great.
The video is recorded with 30 fps on a remote server, which builds a simple jpeg-driven "Live Stream".
But the main part, the recording of the webcam is a simple ffmpeg-command, which you can find here:
https://github.com/Fensterbank/RaspCam/ ... /webcam.sh
Details of my project can you see here, if you understand german. :)
http://bolvin.de/raspcam/
sumith
Tue Sep 25, 2012 5:32 am
Thanks for your reply.
I found a similar problem when I tried to create video using images which I already stored in a folder. using cvCreateVideoWriter..
However I will try with this..
If you have any solution to above issue, please reply me.
Thanks again.
f32mark
Tue Sep 25, 2012 6:11 am
JacekQ wrote: T
JacekQ, I can confirm I had motion working on a headless Pi. Unfortunately I'm waiting for a replacement (stupidly ordered in from RS) as I broke the SC card reader on the original. From memory, it was pretty straight forward once I'd tuned motion.conf.
Pajoe
Tue Sep 25, 2012 11:40 pm
Please share what you have working, I am very much interested in learning more about the Raspberry Pi using motion to record video. I have another Raspberry Pi on order as I would like to try to do this and possibly using a python program written to push the recorded videos to a Tivo for recording/viewing, I think it would be great having the ability to view a wireless usb security video as an option on our Tivo. I still have xbmc on a card in case I want to go back to that but now sending recorded video to the Tivo is more interesting.
Currently I have a Raspberry pi with the JDK running an older version of Galleon, a java media server for Tivo and it does well with internet web cams but with the python programs pytivo & streambaby I might be able to use actual video and record it as well.
thanks in advance
joe
On edit: One of the things I really like about the Raspberry Pi is that once you get something working you can clone it on a different SD card and it will work on another Raspberry Pi with a few changes.
JacekQ
Wed Sep 26, 2012 9:46 am
f32mark wrote:JacekQ, I can confirm I had motion working on a headless Pi. [cut] From memory, it was pretty straight forward once I'd tuned motion.conf.
Now I have new raspbian image installed and I have to install motion again. Last time Motion was working but I don't remember that I can't capture video or video quality was very poor or I can't set it to just capture video for specified time without motion reocognition.
Best regards,
Jacek Q.
