1. Does my charger supply enough? It is 5 volts and 1 amp. If not, what do I need? I will not buy the Pi Hut's ridiculously priced power supply.
2. Does a Kindle 3's work? It is 5.5 volts.
FYI: Multimeter reading (with Palm Trio): 4.99
Thank you!
Ah. I see. Win32 Disk Imager isn't working for me though. The device is blank. Also, how would I use "dd"?JeremyF wrote:No green light = SD card not img'd correctly
No idea about "dd". But Win32 disk imager can be picky about SD slots, or your machine's SD slot is picky about SD cards.jeff wrote: Win32 Disk Imager isn't working for me though. The device is blank. Also, how would I use "dd"?
'dd' is a Linux command, not available in Windows.jeff wrote:Ah. I see. Win32 Disk Imager isn't working for me though. The device is blank. Also, how would I use "dd"?JeremyF wrote:No green light = SD card not img'd correctly
I do realize "dd" is a bash Unix command (not Linux, get your facts right), because I also have a Mac, if that is needed. My card reader does support SDHC, but I don't know about Win32 Disk Imager...drgeoff wrote:'dd' is a Linux command, not available in Windows.jeff wrote:Ah. I see. Win32 Disk Imager isn't working for me though. The device is blank. Also, how would I use "dd"?JeremyF wrote:No green light = SD card not img'd correctly
Are you sure that your SD card reader slot supports SDHC cards?
Whilst we're in uber pedant mode, "dd" isn't much to do with BASH either.jeff wrote:
Meh, mainly UNIX.pluggy wrote:Whilst we're in uber pedant mode, "dd" isn't much to do with BASH either.jeff wrote:
