rp108
Can't connect to xrdp server with Win Desktop
Sat Jan 28, 2017 7:41 pm
I have RPi 2
Raspian Jessie 1-11-2017
I can ping PI on my LAN.
I can SSH into Pi from Win7 machine.
I have User rob who is in adm group.
When I attempt to connect with rob I get error as shown in the attached
image.
It seems strange that it says I am connecting to 127.0.0.1 (me) but in a
youtube training video it shows the same thing, but the youtube vid is
successful at connecting.
I thought that maybe the xrdp server was not running, but other posts on this
site indicate that xrdp is always running.
Any help is MUCH appreciated.
Thanks,
rp108
rp108
Re: Can't connect to xrdp server with Win Desktop
Sat Jan 28, 2017 7:43 pm
I am not sure if the image will be readable, so here is the text in the error message:
Connecting to sesman ip 127.0.0.1 port 3350
sesman connect ok
sending login info ......
xrdp_process_login_response: login successful ......
started connecting
connecting to 127.0.0.1:5910
error - problem connecting
Sat Jan 28, 2017 7:45 pm
rp108 wrote:I have RPi 2
image.
Thanks,
rp108
There is a conflict between XRDP and RealVNC in Raspbian Jessie, see the Blog:
https://www.raspberrypi.org/blog/introducing-pixel
Please note that if you already use xrdp to remotely access your Pi, this conflicts with the RealVNC server, so you shouldn’t install both at once. If you’re updating an existing image, don’t run the sudo apt-get install realvnc-vnc-server line in the instructions below. If you want to use xrdp on a clean image, first uninstall the RealVNC server with sudo apt-get purge realvnc-vnc-server before installing xrdp. (If the above paragraph means nothing to you, then you probably aren’t using xrdp, so you don’t have to worry about any of it!)
rp108
Sat Jan 28, 2017 8:10 pm
Thanks Fruitoftheloom,
Not sure what to do.
I installed xrdp on a fresh install of Jessie.
That install, I believe, also installed the VNC server.
I have read posts that says that xrdp NEEDS the VNC server.
The blog post you referenced left me a bit in a quandary.
If I purge VNC, should I expect xrdp, then, to work?
Many thanks !
rp108
klricks
Sat Jan 28, 2017 8:35 pm
rp108 wrote:Thanks Fruitoftheloom,
Many thanks !
rp108
If you want to use xrdp then you have to remove RealVNC as explained in the blog.
However IMO why not use the installed RealVNC instead? RealVNC is MUCH improved over xrdp / Remote desktop.
You only need to download the viewer app from here: https://www.realvnc.com/download/viewer/
To use RealVNC you must remove xrdp from the RPi.
rp108
Sat Jan 28, 2017 10:42 pm
Ooooops,
It's not free.
Already removed xrdp.
OOOppps.
Thanks for replying,
rp108
klricks
Sat Jan 28, 2017 11:00 pm
rp108 wrote:Ooooops,
It's not free.
OOOppps.
rp108
Not sure what you mean????????????
The viewer is free and here is download page: https://www.realvnc.com/download/viewer/
Note you use the Windows version. The RPi version is what is already installed in Rasbian.
The Windows version doesn't' even require an install. Just run the EXE.
Edit:
Sorry for the confusion: The Web site is confusing.... You need the VNC Viewer software not VNC Connect. The VNC viewer is free and never expires. I edited my previous post to give a better link......
rp108
Sun Jan 29, 2017 1:55 am
Thank-you so much for continuing to assist.
I created a new iso, just in case the removal process for xrdp caused problems.
I have the VNC viewer now.
When I attempt to connect to the PI with the Viewer, I get:
The Connection was refused by the computer.
Any ideas?
Does the VNC server on the Pi need to be turned on?
Thanks again,
rp108
rp108
Sun Jan 29, 2017 2:07 am
OK !
Whoopeee doo
Got it working with raspi-config.
Hope it works next time at boot!
Thanks so much for sticking with me.
If you ever need free Electronic Engineering advice, look me up.
Best to you,
rp108
Sun Jan 29, 2017 9:40 am
rp108 wrote:Thank-you so much for continuing to assist.
Any ideas?
Thanks again,
rp108
You do not use a .ISO, the without NoobS Operating Systems are in .IMG format !!
