For better performance I have to use Jessie Lite with RPi Zero but I also need a Touch LCD attached.
The LCD is working fine with the correct rotation but the touch functionality is rotated 90' counterclockwise, so if I slide my finger UP pointer slides LEFT. I have tried too many methods, none worked, so I am posting for your help.
FYI, It is for an open source smart thermostat we develop for some time, HestiaPi (http://www.hestiapi.com).
Here is what I have done after update&upgrade on latest Jessie Lite
sudo apt-get install --no-install-recommends xserver-xorg xinit xserver-xorg-video-fbdev lxde lxde-common lightdm
sudo apt-get install git build-essential xorg-dev xutils-dev x11proto-dri2-dev libltdl-dev libtool automake libdrm-dev
git clone https://github.com/ssvb/xf86-video-fbturbo.git
cd xf86-video-fbturbo
autoreconf -vi
./configure --prefix=/usr
make
sudo make install
Section "Device"
Identifier "Allwinner A10/A13 FBDEV"
Driver "fbturbo"
Option "fbdev" "/dev/fb1"
Option "SwapbuffersWait" "true"
EndSection
sudo reboot
sudo apt-get install policykit-1 hal
sudo reboot
wget http://www.hestiapi.com/LCD-show.tar.gz
tar xvf LCD-show.tar.gz
cd LCD-show/
sudo ./LCD35-show
[email protected]:~ $ lsmod
Module Size Used by
fb_ili9486 3213 2
fbtft 32615 1 fb_ili9486
syscopyarea 3161 1 fbtft
sysfillrect 3716 1 fbtft
sysimgblt 2422 1 fbtft
fb_sys_fops 1677 1 fbtft
ads7846 12525 0
hwmon 4552 1 ads7846
r8188eu 454315 0
joydev 9194 0
evdev 11650 6
cfg80211 500089 1 r8188eu
rfkill 21397 2 cfg80211
i2c_bcm2708 5740 0
spi_bcm2835 7424 0
bcm2835_gpiomem 3823 0
bcm2835_wdt 4133 0
w1_gpio 4534 0
wire 31801 1 w1_gpio
cn 5860 1 wire
uio_pdrv_genirq 3718 0
uio 10230 1 uio_pdrv_genirq
ipv6 367671 34
[email protected]:~ $ dmesg | grep spi
[ 17.179026] ads7846 spi0.1: touchscreen, irq 177
[ 17.191827] input: ADS7846 Touchscreen as /devices/platform/soc/20204000.spi/spi_master/spi0/spi0.1/input/input2
[ 18.738973] graphics fb1: fb_ili9486 frame buffer, 480x320, 300 KiB video memory, 4 KiB DMA buffer memory, fps=33, spi0.0 at 16 MHz
