NorwegianClassic
Bash: kivy: command not found?
Sat Jan 14, 2017 5:07 pm
Hi there!
I'm trying to install Beautiful Soup 4 to use in my kivy app for my rpi 3, but I can quite get it too work.
When I use
kivy -m pip install bs4
it returns bash: kivy: command not found.
I have tried to set the PYTHONPATH.
I saw that /usr/lib/python2.7/dist-packages/kivy doesn't exist, can this be a part of the problem?
Re: Bash: kivy: command not found?
Sat Jan 14, 2017 5:16 pm
Is kivy installed?
Try
sudo apt-get update
sudo apt-get -y install python-kivy
NorwegianClassic
Sat Jan 14, 2017 5:51 pm
Yes I have. I tried the commands you posted just to be sure, and tried $kivy -m pip install bs4, but still no luck.
I can run the demos, so kivy works. But when I run my program that uses bs4, it returns:
bs4.FeatureNotFound: Couldn't find a tree builder with the features you requested: lxml. Do you need to install a parser library?
Sat Jan 14, 2017 6:01 pm
That message looks like you haven't got lxml installed (a quick google confirmed this)
sudo apt-get install python-lxml
NorwegianClassic
Sat Jan 14, 2017 6:40 pm
Thank you, that solved it! I thought bs4 and lxml did the same thing, so I thought I didn't need it! :D
