I JUST TRIED:
apt-get install python-mysql.connector
But got this error:
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main python-mysql.connector all 1.2.3-2
Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... -2_all.deb Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I tried apt-get update but failed similarly
Please help.
My original sense hat Pi SD Card died and I need to install a new Raspbian + python + mysql asap to reduce the down time of recording the air pressure.
Thanks in advance.
Re: is the raspian mirror server down?
It appears it is down- It was working about an hour or so ago. Give it a little time and try again.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
OK - I was about to post, asking if this was a systemic problem or just a "middle of the night problem" - i.e., a "try again later".
Here's the message I get when doing apt-get update:
root@jessie:/home/pi# apt-get update
Err http://mirrordirector.raspbian.org jessie InRelease
Err http://mirrordirector.raspbian.org jessie Release.gpg
Unable to connect to mirrordirector.raspbian.org:http: [IP: 5.153.225.207 80]
Get:1 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
Get:2 http://archive.raspberrypi.org jessie/main Sources [54.8 kB]
Hit http://archive.raspberrypi.org jessie/ui Sources
Get:3 http://archive.raspberrypi.org jessie/main armhf Packages [136 kB]
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Fetched 214 kB in 6s (31.0 kB/s)
Reading package lists... Done
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/InRelease
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg Unable to connect to mirrordirector.raspbian.org:http: [IP: 5.153.225.207 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
If this post appears in the wrong forums category, my apologies.
I'm having the same issue trying to install OpenVPN, booting from a fresh install of the 2017-01-11 release where the one and only setting that's been changed was to enable SSH.
Guess it's time to fire up a game and give this a shot tomorrow
There appears to be a glitch in the Matrix !!
My other Linux machine is a ChromeBox
Yup not working for me as well.
Same for me
This is the error:
Anyone know if there is a work around mirror?
This is the error:
Just done a fresh install.Cannot initiate the connection to mirrordirector.raspbian.org:80 (2001:41c9:1:3ce::11). - connect (101: Network is unreachable) [IP: 2001:41c9:1:3ce::11 80]
You could (temporarily) change the URL in /etc/apt/sources.list to one of the mirrors: https://www.raspbian.org/RaspbianMirrorskazz wrote:Anyone know if there is a work around mirror?
It's back up...
it is finally normal now.
Not quite. Still reporting an issue for Jessie/ui sources
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
IIRC 'ui' is only on the RPF repo, not the Raspbian...SteveSpencer wrote:Not quite. Still reporting an issue for Jessie/ui sources
I don't get any errors on that BTW
To be clear,
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main Sources
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Err http://archive.raspberrypi.org jessie/ui Sources
406 Not Acceptable [IP: 46.235.227.11 80]
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
W: Failed to fetch http://archive.raspberrypi.org/debian/dists/jessie/ui/source/Sources 406 Not Acceptable [IP: 46.235.227.11 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Steve S
Too bad. I turned out it was only partially normal. When I tried
apt-get install libmysqlclient-dev
it got another error:
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... u1_all.deb 404 Not Found [IP: 5.153.225.207 80]
Hope the admin notice this error and fix it soon.
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Looks like the server is triksadecaphobic. Judging by today's date.
Or even friggatriskaidekaphobic / paraskevidekatriaphobicDougieLawson wrote:Looks like the server is triksadecaphobic. Judging by today's date.
looks like ther is a problem today
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... ce/Sources 406 Not Acceptable [IP: 93.93.128.230 80]
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Looks okay from this end.Paulwood wrote:looks like ther is a problem today
- ZzyzxWolfe
- Contact: ICQ Yahoo Messenger AOL
Paulwood wrote: ↑Wed Jan 18, 2017 1:32 pmlooks like ther is a problem today
With the "406 Not Acceptable" error with apt-get, it seems to happen when apt tries to resume a partial download and the server doesn't support it.
If you get the "406 Not Acceptable" error, you can fix it by deleting the partially downloaded files from inside /var/lib/apt/lists/partial.
You can delete the partial downloads by running:
sudo rm /var/lib/apt/lists/partial/*
sudo apt-get update
Hope this helps!
Cheers,
Zzyzx
“Don't lose your mind trying to set it free...”
http://mirrordirector.raspbian.org/raspbian/ is not working for me at the moment, so tried:DirkS wrote: ↑Fri Jan 13, 2017 11:06 amYou could (temporarily) change the URL in /etc/apt/sources.list to one of the mirrors: https://www.raspbian.org/RaspbianMirrorskazz wrote:Anyone know if there is a work around mirror?
deb http://raspbian.mirrors.wvstateu.edu/raspbian/ stretch main contrib non-free rpi
but that got a 404 on stretch/armhf
and then it also stuck on connecting to archive.raspberrypi.org
guess I'll have to go to work after all. I was contemplating "hookey" today.
