puddingandPi
Display not detecting RPi (solved)
Tue Sep 11, 2012 9:55 pm
Can anyone help?
I have an HDMI to DVI cable going from my RPi to a Philips 192e1 display. The display doesn't detect the RPi...
I have OS installed on the SD card, I've followed the instructions and have variously turned off monitor and Pi in order to get them to register... no luck. and I can't find anything on the forum that helps me.
thanks
JeremyF
Re: Display not detecting RPi
Tue Sep 11, 2012 10:08 pm
Did you try hdmi_force_hotplug=1 in config.txt?
http://elinux.org/RPi_config.txt http://elinux.org/R-Pi_ConfigurationFile
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
puddingandPi
Wed Sep 12, 2012 7:16 am
Thanks Jeremyf
I haven't tried that, and I don't really understand what you mean. I can't see anything my RPi is doing so can I do this (however it is done) via a pc?
Cheers for your patience
puddingandPi
Wed Sep 12, 2012 7:21 am
No need to reply Jeremyf. I looked at the links you sent me and all is crystal. Cheers buddy.
PPi
