reinstalling raspbian on the same sd card?
Posted: Tue Jan 10, 2017 5:37 pm
by Zalkiaent
My raspberry pi 2 will not boot right, and the idiot I was, put it on automatic boot.
I don't have any more sd cards, so I need to reinstall the os on the same sd card.
If anyone can help me out here, It would mean a lot.
Thank you!
-Zalk
Re: reinstalling raspbian on the same sd card?
Posted: Tue Jan 10, 2017 5:47 pm
by B.Goode
Easy!
Just imagine that microSD card had never been used with a Raspberry Pi before.
Visit
https://www.raspberrypi.org/downloads/raspbian/ and download
RASPBIAN JESSIE WITH PIXEL
Follow the linked document to install it.
https://www.raspberrypi.org/documentati ... /README.md
That's all. (Installation from a . img file automatically destroys the previous content and formatting of the card and gives you a clean freshly installed OS - no other preparatory steps are needed.)
Of course, any configuration, scripts or other work you have saved on the microSD card will also be destroyed as part of the same process.
Posted: Tue Jan 10, 2017 7:57 pm
by syrisara
What Windows version do you use?
In short,
Go to command prompt, Windows.
Type diskpart
Type list disk
See what disk is the sdcard to burn image on. Example disk 4.
Type select disk 4
Be sure you now have the right disk selected. Again be sure! You will get no warning.
Type clean
Type exit
Your sdcard is now without partitions.
Download sdformat. Or use Windows.
Select your disk and format.
Now use win32diskimager to burn your new image.
Hope this helps.
Posted: Tue Jan 10, 2017 9:08 pm
by B.Goode
Why are the preceding steps necessary? After 5 years of user experience the Raspberry Pi Foundation don't seem to feel it is something they should include in their documentation.
Posted: Sat Jan 14, 2017 5:59 pm
by Zalkiaent
B.Goode wrote:Easy!
Visit
Thank's, I am gonna give this a shot!
Posted: Sat Jan 14, 2017 9:12 pm
by Zalkiaent
B.Goode wrote:Easy!
Visit
It work's! Thank's for the help!
Posted: Sat Jan 14, 2017 9:26 pm
by B.Goode
Well done.
All I did was point you to the 'official' documentation by the Raspberry Pi Foundation...
Posted: Wed Sep 11, 2019 5:39 pm
by yeej2
B.Goode wrote: ↑Tue Jan 10, 2017 5:47 pm
Easy!
Visit
If I have a minecraft server on mine, would it delete everything my friends and I have done on the game?
Posted: Wed Sep 11, 2019 8:25 pm
by B.Goode
yeej2 wrote: ↑Wed Sep 11, 2019 5:39 pm
Easy!
Visit
That would come under the heading of "
any configuration, scripts or other work you have saved on the microSD card will also be destroyed as part of the same process."
So Yes,
everything previously on the microSD card
will be deleted.
Of course, since you have resurrected a topic nearly three years old, the advice to download and install Raspbian Jessie is no longer appropriate as that OS has been twice superceded. At the time of writing in September 2019 the current supported Raspberry Pi Operating System is Raspbian Buster.
Posted: Wed Sep 11, 2019 8:37 pm
by Andyroo
I would also add that formatting the SD card does nothing but wear it out faster
With Etcher the partition table and format are all overwritten in one step
Posted: Wed Sep 11, 2019 8:46 pm
by HawaiianPi
Yes. Writing a new image will overwrite anything previously on the card (your server and all related data will be gone). You should get a new SD card and write Raspbian to that, then copy your Minecraft folder and any other data or scripts your server needs from the old card to the new one.
