Muskokajohn
Bluetooth speaker Paired, but no sound
Wed Jan 04, 2017 3:55 pm
My new Pi 3 is awesome, but I cant get any sound over Bluetooth. I have tried different Bluetooth speakers and headphones, but no luck. I have the Pi3 hooked up to a small LED TV via HDMI, and when viewing say a YouTube video, I get sound through the TV Speakers. I click on the Bluetooth icon, add device no problem. Right click the Audio icon and my Bluetooth speaker is there. I click on the speaker and my speaker responds that it is now paired, but still no sound. I installed Pulse Audio along with it's Bluetooth module, but still the same. What am I missing. I read other threads that say this is all you have to do.
Muskokajohn
Re: Bluetooth speaker Paired, but no sound
Fri Jan 06, 2017 11:05 pm
I just loaded the Pulse Audio manager
sudo apt-get update && sudo apt-get install paman
More control, but still no sound after pairing to speaker. The "monitor volume" for the speaker selected shows "0".
Any suggestions?
youness
Wed Jan 11, 2017 10:44 am
Don't use any Graphical tool to set Bluetooth sound.
Do it by CLI commands with pacmd and bluetoothctl.
soydepr
Mon Apr 03, 2017 8:08 pm
how can you elaborate
youness
Thu Feb 08, 2018 2:23 pm
Check this post that explains how to do it:
https://youness.net/raspberry-pi/how-to ... berry-pi-3
HawaiianPi
Thu Feb 08, 2018 11:50 pm
Turn off normal audio by commenting out the line
dtparam=audio=on
in config.txt. I had a lot of trouble getting Bluetooth audio working until I did that. Now it just works by default, because it's the only audio interface active. Works with default ALSA, no need to install anything extra.
Not that great for watching video, though. On my Pi3B the audio drifts in and out of sync and sometimes stutters when watching HD video. Fine for music. Speakers are Edifier Exclaim Connect (e10bt).
klricks
Fri Feb 09, 2018 12:56 am
Never could get BT audio working on the first release of Rasbian Stretch even after update/upgrade.
After starting with a fresh install of the latest Rasbian Stretch 29 Nov., my BT speakers just worked with nothing else installed and no config changes. No problem switching between BT, HDMI or analog sound.
Douglas6
Fri Feb 09, 2018 1:03 am
That's my experience as well.
HawaiianPi
Fri Feb 09, 2018 1:23 am
The problem I had was that Raspbian always defaults to HDMI or analog audio. I could not get the Bluetooth audio setting to stick, and always had to manually switch it back to Bluetooth after a reboot. Since I had nothing other than Bluetooth speakers, the solution was to disable the default sound driver.
klricks
Fri Feb 09, 2018 1:35 am
Don't remember if I had that problem before? It works perfectly now. The audio selection is persistent after reboot.
youness
Fri Feb 09, 2018 3:06 pm
I didn't follow Raspbian updates, but I think that now everything is set to work out-of-box, auto switch to latest device, no disconnection after idle...etc. Good end.
youness
Fri Feb 09, 2018 3:07 pm
Maybe because of bluealsa that didn't let you connect BT audio with PulseAudio, you had to end it first as explained in the link.
daafit
Sun Mar 25, 2018 10:06 pm
When I put a hash # in front of hdmi.force.hotplug=1 in the config.txt it finaly worked !!!!
