raspguy
Bluetooth Issue
Mon Jan 02, 2017 8:40 pm
Raspberry pi3
latest Jessie
I have successfully paired my vizio Bluetooth speaker. However, when I am trying to select the speaker as my audio input by right clicking the audio icon, I get the following error:
Failed to connect to a device
          GDBus.Error.org.bluez.Error.NotReady
          Resource Not Ready. Try to connect again
I have tried to install and reinstall pi-bluetooth and audiopulse, but couldn't able to solve the issue
recklessfb
Re: Bluetooth Issue
Tue Jan 03, 2017 2:47 am
Can you try running
pulseaudio --start
before right clicking the speaker icon?
Also, you should already have pulseaudio-module-bluetooth installed. If not install it and then repeat the above.
Good luck.
Douglas6
Re: Bluetooth Issue
Tue Jan 03, 2017 1:56 pm
If you have blueman installed, uninstall it.
nightshark
Re: Bluetooth Issue
Tue Jan 03, 2017 2:04 pm
Douglas6 wrote:If you have blueman installed, uninstall it.
Is Blueman installed by default? I am having similar issues when the connection goes idle. I can't reconnect without rebooting.
Douglas6
Re: Bluetooth Issue
Tue Jan 03, 2017 2:17 pm
nightshark wrote:Is Blueman installed by default?
No, it's not.
nightshark
Re: Bluetooth Issue
Tue Mar 21, 2017 2:53 pm
Has anyone else had this issue? I am still having trouble with it.
