I got an Raspberry Pi3 which works fine on the TV but when it comes to connecting it to a no name FHD 50hz 21.5 monitor I get a no signal tag
I tried to play with the config.txt but no luck, any ideas?
Hi did you get this problem sorted,I have to same sort of problem,pi3 works fine on HD TV ,but keep getting out of range error when pluged into my 17 inch 1024x768 60hz 4:3 monitor,i read and looked at config.txt file but I am a noob with pi and dont want to brick it.
