Help needed - boot problems
Posted: Wed Dec 28, 2016 5:19 pm
by gdw35
I have managed to get myself into a right mess.
A few days ago I got my Pi out for the first time in a while wanting to play some retro games. Everything was working just fine until I decided to do some updates. The SD card I have was set up with Raspbian Wheezy distribution. After updating RetroPie I was told that I needed to update to a later version of Raspbian to allow it to run so this is when my troubles started.
I followed the process to upgrade the distribution. Both running "apt-get update" and "apt-get upgrade" pointing to the Jessie distribution worked just fine however when running "apt-get dist-upgrade" an error was encountered when attempting to upgrade vsftp and the update aborted. I tried re-running several times but each time it failed when attempting to update vsftp. In frustration I ran the command "apt-get remove vsftp" and then tried running the upgrade again. This time nothing was processed so I thought it was all OK to reboot. Bad idea.
On reboot I was just shown the rainbow screen, nothing else. Removing the SD card and having a look on my Mac showed that the boot directory was empty. I tried renaming boot.bak to boot but this just ended up with the same result.
In frustration I reformatted the SD card. I did make a back up of the SD card with my Mac early in the year so I thought I could just restore it and start again. I now get an error when I attempt to restore the backup image onto the card. Here is the message:
bash-3.2# dd bs=1m if=Grants-Pi-SD-080215.img of=/dev/rdisk3
dd: /dev/rdisk3: Input/output error
60907+0 records in
60906+0 records out
63864569856 bytes transferred in 4022.555946 secs (15876614 bytes/sec)
After this failure I eject the card from my Mac and then reinsert it. Both partitions are accessible, both called "Untitled". If I then eject the SD card and try it in my Pi the Pi will start to boot and then fails stating that it cannot mount the disk. Putting the car back in my Mac only the BOOT partition mounts. The other partition is visible in Disk Utility but is not being mounted.
I suspect that there is an issue with the main partition of the SD card. How can I fix this with my Mac. Any help would be appreciated as I do not want to lose everything I have done.
Re: Help needed - boot problems
Posted: Wed Dec 28, 2016 6:22 pm
by B.Goode
Might the restoration of the backup work if you restore to a target microSD card that is 'one size larger' than the original? (ie. if your original was an 8G card will it restore correctly to an 16G card?)
Posted: Wed Dec 28, 2016 6:33 pm
by gdw35
B.Goode wrote:Might the restoration of the backup work if you restore to a target microSD card that is 'one size larger' than the original? (ie. if your original was an 8G card will it restore correctly to an 16G card?)
Thanks for your reply. SD card and image are 64GB, really not wanting to go out and buy a 128GB card. Besides, the image (backup), I have was made from the SD card I am trying to restore to (on Mac).
Posted: Wed Dec 28, 2016 6:38 pm
by DougieLawson
You can get an X86 linux system running with the PIXEL X86 DVD or USB ISO.
http://sirlagz.net/2013/03/10/script-au ... downsizer/
Posted: Wed Dec 28, 2016 6:57 pm
by B.Goode
Sadly, it looks as though a block on the SD card has failed (become unwritable) since the backup was taken, so there isn't room to reinstate the original data.
A more convoluted solution, still involving the purchase of a usb card reader, is to do a fresh installation of Raspbian onto the SD card and then using that system as your workstation mount the image of the backup and extract any important files or resize (shrink) the backup.
A variation on this, as @Dougie Lawson has suggested, is to boot a conventional laptop with the new Pixel for x86 in live CD mode and use that to recover your work.
Posted: Wed Dec 28, 2016 7:03 pm
by gdw35
Thanks all for help.
Current status is that I am now able to mount both partitions on my Mac and have full access to both. I guess that is good new. Fortunately I have ExtFS for Mac installed so am able to mount and check ext partitions. When I do a check of the main ext3 partition I get an error, as follows:
Verifying file system.
Checking volume /dev/rdisk3s2...
Step 1: Checking inodes, blocks, and sizes
Step 2: Checking directory structure
Step 3: Checking directory connectivity
Step 4: Checking reference counts
Step 5: Checking group summary information
ERROR read bitmaps: while retrying to read bitmaps
ERROR Check aborted
Check finished
     60.10 GB total disk space.
         0 KB in 106586 files.
         0 KB in 11181 directories.
         0 KB in bad blocks in 0 fragments.
         4 KB in each allocation unit.
  15753984 total allocation units on volume.
  12893400 allocation units available on volume (49.18 GB).
No repairs were necessary for volume /dev/rdisk3s2.
File system check exit code is 0.
No options to do a repair.
Boot is still failing on Pi when trying to mount main partition.
I guess my only option now is to reformat and install a new distribution and then try and remember everything I have to reinstall to get my Pi back to what it was before. Unless anyone else has some bright ideas.
