vnc viewers timing out on RPi3 (raspbian)
Posted: Tue Dec 27, 2016 9:01 pm
by bkorst
Greetings all,
This is an edited version of the original message, since a solution was found. This topic does not involve RealVNC, as I was trying to connect "directly", without having to create a third-party account somewhere. When the problem was noticed, I tried tightvnc, tigervnc, ultravnc and the server connection via finder on a mac. All of them timed out upon attempting to connect to the pi.
To summarize for those in this situation, check if there is a firewall running on the pi via the command iptables. As another post at stack exchange discusses, this problem is typically observed either because of a typo on the ip address or about packets being dropped. My problem was the latter.
I have a RPi3 with raspbian, connected via router to a windows pc. I could ping it and have no problem with ssh. Despite having server and viewer running in their respective platforms, the viewer connection timed out at every attempt. I have no extra monitor, keyboard or mouse, so I must connect headless.
The error I kept getting was:
Error in TightVNC Viewer: A connection attempt failed bacause the connected party did
not properly respond after a period of time, or established connection failed because
connected host has failed to respond.
Here is the sequence of events leading to observing the problem.
1) downloaded latest raspbian, made the necessary modifications to the image to
get wifi and ssh going. On the router, I use DHCP with a table tying MACs to IPs
(restrited IP address list on the router), so the IP never changes. All devices
are visible via advanced ip scanner (downloaded from the internet). I can ping the pi
from cygwin (on a pc) or from the command shell on a mac. SSH works fine via Putty between laptop pc and RPi3.
2) using raspi-config, changed password, enabled vnc, set to boot via graphic interface (later changed to command shell).
3) Installed tightvncserver, ran update and upgrade. **Mistakenly installed ufw**. Reboot. Logged back in via ssh.
4) Ran vncserver :1 -- at this point tried to connect. **there is not much sense in enabling vnc via raspi-config and trying to run tightvncserver. If one wants to run tightvnc server, one should have the vnc at boot from raspi-config disabled (you can likely have the two at different ports, but that is another story)..
On the PC side, installed tightvnc viewer. Later tried UltraVNC viewer as well. On a Mac, I tried tiger vnc and the built-in connection via finder. The viewers were attempted one at a time. They all time out on both PC and Mac. Meanwhile, ssh runs fine. This meant to me -- mistakenly -- that there was no firewall, since ssh was running fine all along.
5) I tried different ports for the server (except 0), to no avail. For the heck of it, I took the vnc job down via kill -9, and tried to run the command tightvncserver :1 instead. Tried to connect, timed out.
6) checking with ps axg | grep vnc -- output shows everything is running as it should. At this point used the same command to see if ufw (the firewall) was running. Nothing shown for the firewall, but it *was* running. Tried to connect, time out.
6) At this point I was attempting the rotating machine gun approach. Following a nice tutorial from xhantor (on this forum), which sets up vnc service upon power up. This makes sense by itself, not along everything else I was running.
I created a new file:
/etc/systemd/system/vncserver@.service with
[Unit]
Description=Remote desktop service (VNC)
After=syslog.target network.target
[Service]
Type=forking
User=pi
PAMName=login
PIDFile=/home/pi/.vnc/%H:%i.pid
ExecStartPre=-/usr/bin/vncserver -kill :%i > /dev/null 2>&1
ExecStart=/usr/bin/vncserver -depth 24 -geometry 1280x800 :%i
ExecStop=/usr/bin/vncserver -kill :%i
[Install]
WantedBy=multi-user.target
Ran systemctl daemon-reload
Ran systemctl enable vncserver@1.service
Reboot, log back in with ssh (fine)
7) checked the log file related to the port open, in .vnc -- log was complaining of the absence of .Xresources file. I created an empty one, rebooted and tried again, and the log file no longer showed complaint.
At this point, after hints of my mistakes, I took down the conflicting vnc services and checked whether there was a firewall running via command line --> iptables -L -nv (there was a firewall active) Took down the firewall via sudo ufw disable.
Connected and it worked.
Hopefully this will help someone else facing the same predicament. Thanks to @Milliways (stack exchange) for the clues that lead to the solution.
Cheers!
