VascoFerraz
Error: Timeout was reached
Sat Dec 24, 2016 2:20 pm
Any ideas what is going on?
pi@raspberrypi-3:~ $ sudo apt-get update
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Reading package lists... Done
pi@raspberrypi-3:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  libxml2
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 705 kB of archives.
After this operation, 4,096 B disk space will be freed.
Do you want to continue? [Y/n] Y
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libxml2 armhf        2.9.1+dfsg1-5+deb8u4 [705 kB]
Fetched 705 kB in 2s (303 kB/s)
Reading changelogs... Done
(Reading database ... 112056 files and directories currently installed.)
Preparing to unpack .../libxml2_2.9.1+dfsg1-5+deb8u4_armhf.deb ...
Unpacking libxml2:armhf (2.9.1+dfsg1-5+deb8u4) over (2.9.1+dfsg1-5+deb8u3) ..        .
Setting up libxml2:armhf (2.9.1+dfsg1-5+deb8u4) ...
Processing triggers for libc-bin (2.19-18+deb8u6) ...
Thank you so much,
Vasco Ferraz
Vasco Ferraz
Re: Error: Timeout was reached
Sat Dec 24, 2016 2:50 pm
Your network is broken.
VascoFerraz
Sat Dec 24, 2016 6:41 pm
Solved with:
sudo aptitude -f
Then:
Actions -> Update package list
Actions -> Cancel pending actions
Actions -> Clean package cache
Vasco Ferraz
VascoFerraz
Mon May 08, 2017 4:54 pm
I am experiencing again this issue and I have no idea how to solve it.
Vasco Ferraz
loadbang
Wed Jun 07, 2017 5:45 pm
I'm getting this across three RPi3's I have.
Tried 'apt-get clean', 'dpkg --configure -a', 'apt-get -f install'. Still get this error, but with different packages on each RPi.
Preparing to unpack .../perl_5.20.2-3+deb8u7_armhf.deb ...
Unpacking perl (5.20.2-3+deb8u7) over (5.20.2-3+deb8u6) ...
dpkg: error processing archive /var/cache/apt/archives/perl_5.20.2-3+deb8u7_armhf.deb (--unpack):
 unable to create `/usr/share/man/man1/c2ph.1.gz.dpkg-new' (while processing `./usr/share/man/man1/c2ph.1.gz'): Structure needs cleaning
Processing triggers for man-db (2.7.0.2-5) ...
